IC-PROG dan Pıc e Nasıl programı atacağım ?
uatam
17 Mar 2010
Merhaba pic programlamaya yeni başlayacağım .programı yazdım seri port girişli programlayıcıya nasıl (pic e) nasıl yükleyeceğim Mplab 5.70 var ama 16f628a seçemiyorum 16f628 var .ne yappmam gerekir ?teşekür ederim
628 e göre oluşturdugun hex dosyasını 628a ya yükle sorun çıkmaz...
sorun çıkmaz ama bir şey soracağım açılırken hata veriyormu priviged instruction gibi?
HAYIR ÖYLE BİR HATA VERMİYOR . MPLAB 8.10 A BU PROGRAMI YAZIYORUM HATA VERİYOR .KİTAPTA GÖRDÜĞÜMÜN AYNISINI YAPIYORUM AMA OLMUYOR .PROGRAM BU
;===PROG1.ASM====
LIST P=16F628A
INCLUDE "P16F628A.INC"
_CONFIG _XT_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _BODEN_OFF & _LVP_OFF & _DATA_CP_OFF & _CP_OFF
ORG h'0000' ;
CLRF PORTB ;
BANKSEL TRISB ;
CLRF TRISB ;
BANKSEL PORTB ;
BASLA
MOVLW h'55' ;
MOVWF PORTB ;
DONGU
GOTO DONGU ;
END ;
ASSEMBLY İLE YAZDIM.
HATASI DA BU
Debug build of project `C:\Documents and Settings\WindowsXP\Desktop\deneme\PROG1A.disposable_mcp' started.
Preprocessor symbol `__DEBUG' is defined.
Mon Jun 14 13:14:33 2010
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Documents and Settings\WindowsXP\Desktop\deneme\PROG1A.mcs".
Clean: Done.
Executing: "C:\Documents and Settings\WindowsXP\Desktop\MPASM Suite\MPASMWIN.exe" /q /p16F628A "PROG1A.ASM" /l"PROG1A.lst" /e"PROG1A.err" /d__DEBUG=1
Warning[207] C:\DOCUMENTS AND SETTINGS\WINDOWSXP\DESKTOP\DENEME\PROG1A.ASM 4 : Found label after column 1. (_CONFIG)
Error[122] C:\DOCUMENTS AND SETTINGS\WINDOWSXP\DESKTOP\DENEME\PROG1A.ASM 4 : Illegal opcode (_XT_OSC)
Message[302] C:\DOCUMENTS AND SETTINGS\WINDOWSXP\DESKTOP\DENEME\PROG1A.ASM 9 : Register in operand not in bank 0. Ensure that bank bits are correct.
Error[173] C:\DOCUMENTS AND SETTINGS\WINDOWSXP\DESKTOP\DENEME\PROG1A.ASM 17 : Source file path exceeds 62 characters (C:\DOCUMENTS AND SETTINGS\WINDOWSXP\DESKTOP\MPASM SUITE\P16F628A.INC)
Halting build on first failure as requested.
Debug build of project `C:\Documents and Settings\WindowsXP\Desktop\deneme\PROG1A.disposable_mcp' failed.
BUILD FAILED
asm kodunun sonunda ; olmaz diye bilşiyorum o c dilinde konuluyor belki ondandır.
Tblade
