labview ve pid simulasyon,simview
ahmetbogus
11 Kas 2006
Norveçli Finn Haugen isimli bir bilim adamı tarafından hazırlanmış.
Güzel bir kaynak. ben çok faydalı buldum.
Kendisine teşekkür ederim.
not:
Bende Finn Haugen 'in LabVIEW ile yapmış oldugu çalışmalardan(endüstriel proses modellemesi ) C# ile endüstriel proses modellemesi yapmaya çalışmaktayım. Eger daha önce Endüstriyel proses modellemesi yapmış arkadaşlar var ise yaptıkları çalışmalar ile ilgili kısa bilgi verirse memnun olurum.
TechTeach: SimView
TechTeach: SimView
SimView is a set of freely available simulators in the area of engineering cybernetics (in a broad sense). SimView is produced by TechTeach.
SimView is based on:
Interactivity
Real-time simulations, which means that the responses are calculated and plotted on the screen in real time - or scaled real-time in some of the simulators.
Immediate graphical responses (e.g. animations) as a result of the user's parameter adjustments - just as in a real lab!
Prepared exercises with detailed instructions with focus on the main points
These features hopefully makes SimView an effective learning tool.
On the homepage of SimView you will find links to the homepage of each of the simulators. These homepages contains background information about the system to be which is simulated, and suggested exercises. The simulators can of course be used independent of there exercises.
SimView is being developed by me (Finn Haugen), and it is under continual development. Please do not hesitate to send me suggestions for improvements and new simulators (e-mail: [email protected]).
The simulators are developed in LabVIEW (version 8.5), which is produced by National Instruments. The simulators can be used without LabVIEW being installed, but in that case the feely available LabVIEW Run-Time Engine must be installed. Here you can find more information about the technical requirements for running SimView-simulators, including the Internet address (URL) to the LabVIEW Run-Time Engine.
Fatih Yalçınkaya
