Opencv hatası
ceku7878
28 May 2020
matplotlib ve contrib yüklerken hata veriyor. nedeni ne olabilir?
Collecting matplotlib
Downloading matplotlib-3.3.4-cp36-cp36m-win_amd64.whl (8.5 MB)
ERROR: Exception:
Traceback (most recent call last):
File "C:\Program Files\Python36\lib\site-packages\pip\_vendor\urllib3\response.py", line 438, in _error_catcher
yield
File "C:\Program Files\Python36\lib\site-packages\pip\_vendor\urllib3\response.py", line 519, in read
data = self._fp.read(amt) if not fp_closed else b""
File "C:\Program Files\Python36\lib\site-packages\pip\_vendor\cachecontrol\filewrapper.py", line 62, in read
data = self.__fp.read(amt)
File "C:\Program Files\Python36\lib\http\client.py", line 449, in read
n = self.readinto(b)
File "C:\Program Files\Python36\lib\http\client.py", line 493, in readinto
n = self.fp.readinto(b)
File "C:\Program Files\Python36\lib\socket.py", line 586, in readinto
return self._sock.recv_into(b)
File "C:\Program Files\Python36\lib\ssl.py", line 1009, in recv_into
return self.read(nbytes, buffer)
File "C:\Program Files\Python36\lib\ssl.py", line 871, in read
return self._sslobj.read(len, buffer)
File "C:\Program Files\Python36\lib\ssl.py", line 631, in read
v = self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
During handling of the above exception, another exception occurred:
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\cli\base_command.py", line 164, in exc_logging_wrapper
status = run_func(*args)
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\cli\req_command.py", line 205, in wrapper
return func(self, options, args)
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\commands\install.py", line 339, in run
reqs, check_supported_wheels=not options.target_dir
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\resolution\resolvelib\resolver.py", line 93, in resolve
collected.requirements, max_rounds=try_to_avoid_resolution_too_deep
File "C:\Program Files\Python36\lib\site-packages\pip\_vendor\resolvelib\resolvers.py", line 482, in resolve
state = resolution.resolve(requirements, max_rounds=max_rounds)
File "C:\Program Files\Python36\lib\site-packages\pip\_vendor\resolvelib\resolvers.py", line 374, in resolve
failure_causes = self._attempt_to_pin_criterion(name)
File "C:\Program Files\Python36\lib\site-packages\pip\_vendor\resolvelib\resolvers.py", line 214, in _attempt_to_pin_criterion
criteria = self._get_updated_criteria(candidate)
File "C:\Program Files\Python36\lib\site-packages\pip\_vendor\resolvelib\resolvers.py", line 205, in _get_updated_criteria
self._add_to_criteria(criteria, requirement, parent=candidate)
File "C:\Program Files\Python36\lib\site-packages\pip\_vendor\resolvelib\resolvers.py", line 173, in _add_to_criteria
if not criterion.candidates:
File "C:\Program Files\Python36\lib\site-packages\pip\_vendor\resolvelib\structs.py", line 151, in __bool__
return bool(self._sequence)
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\resolution\resolvelib\found_candidates.py", line 155, in __bool__
return any(self)
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\resolution\resolvelib\found_candidates.py", line 143, in <genexpr>
return (c for c in iterator if id(c) not in self._incompatible_ids)
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\resolution\resolvelib\found_candidates.py", line 47, in _iter_built
candidate = func()
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\resolution\resolvelib\factory.py", line 206, in _make_candidate_from_link
version=version,
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\resolution\resolvelib\candidates.py", line 287, in __init__
version=version,
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\resolution\resolvelib\candidates.py", line 156, in __init__
self.dist = self._prepare()
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\resolution\resolvelib\candidates.py", line 225, in _prepare
dist = self._prepare_distribution()
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\resolution\resolvelib\candidates.py", line 292, in _prepare_distribution
return preparer.prepare_linked_requirement(self._ireq, parallel_builds=True)
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\operations\prepare.py", line 482, in prepare_linked_requirement
return self._prepare_linked_requirement(req, parallel_builds)
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\operations\prepare.py", line 528, in _prepare_linked_requirement
link, req.source_dir, self._download, self.download_dir, hashes
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\operations\prepare.py", line 217, in unpack_url
hashes=hashes,
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\operations\prepare.py", line 94, in get_http_url
from_path, content_type = download(link, temp_dir.path)
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\network\download.py", line 145, in __call__
for chunk in chunks:
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\cli\progress_bars.py", line 144, in iter
for x in it:
File "C:\Program Files\Python36\lib\site-packages\pip\_internal\network\utils.py", line 87, in response_chunks
decode_content=False,
File "C:\Program Files\Python36\lib\site-packages\pip\_vendor\urllib3\response.py", line 576, in stream
data = self.read(amt=amt, decode_content=decode_content)
File "C:\Program Files\Python36\lib\site-packages\pip\_vendor\urllib3\response.py", line 541, in read
raise IncompleteRead(self._fp_bytes_read, self.length_remaining)
File "C:\Program Files\Python36\lib\contextlib.py", line 99, in __exit__
self.gen.throw(type, value, traceback)
File "C:\Program Files\Python36\lib\site-packages\pip\_vendor\urllib3\response.py", line 443, in _error_catcher
raise ReadTimeoutError(self._pool, None, "Read timed out.")
pip._vendor.urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='files.pythonhosted.org', port=443): Read timed out.
pip install opencv-contrib-python-headless
Bununla çalıştırabildim. Aynı sorunu yaşayanlar deneyebilir.
Çalıştırdığımda şöyle bir hata alıyorum.
PS C:\Users\TOSHİBA> & "C:/Program Files/Python36/python.exe" c:/Users/TOSHIBA/Desktop/aaaaaaa.py
2021-12-20 18:35:06.830440: W tensorflow/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library 'cudart64_110.dll'; dlerror: cudart64_110.dll not found
2021-12-20 18:35:06.830599: I tensorflow/stream_executor/cuda/cudart_stub.cc:29] Ignore above cudart dlerror if you do not have a GPU set up on your machine.
2021-12-20 18:35:09.511651: W tensorflow/stream_executor/platform/default/dso_loader.cc:64] Could not load dynamic library 'nvcuda.dll'; dlerror: nvcuda.dll not found
2021-12-20 18:35:09.511826: W tensorflow/stream_executor/cuda/cuda_driver.cc:269] failed call to cuInit: UNKNOWN ERROR (303)
2021-12-20 18:35:09.515612: I tensorflow/stream_executor/cuda/cuda_diagnostics.cc:169] retrieving CUDA diagnostic information for host: DESKTOP-JR2EH3S
2021-12-20 18:35:09.515819: I tensorflow/stream_executor/cuda/cuda_diagnostics.cc:176] hostname: DESKTOP-JR2EH3S
2021-12-20 18:35:09.516443: I tensorflow/core/platform/cpu_feature_guard.cc:142] This TensorFlow binary is optimized with oneAPI Deep Neural Network Library (oneDNN) to use the following CPU instructions in performance-critical operations: AVX AVX2
To enable them in other operations, rebuild TensorFlow with the appropriate compiler flags.
File "c:/Users/TOSHIBA/Desktop/aaaaaaa.py", line 13, in <module>
input_video = Video(location_videofile)
File "C:\Program Files\Python36\lib\site-packages\fer\classes.py", line 31, in __init__
os.path.abspath(video_file)
AssertionError: Video file not found at C:\content\Video_One.mp4
ibrahimgrby
