picc ile programlama picle ugrasanlar bir bilgi verebilr mi.
elktro
26 Eki 2008
bu program fırcasz dc motor da hız kontrolü aşamalrında ne ler yapılmış komutlr ne işe yaryo bilen varsa paylaşablrmi
Kod:
 *                        Software License Agreement                   *
 *    The software supplied herewith by Microchip Technology           *
 *    Incorporated (the "Company") for its dsPIC controller            *
 *    is intended and supplied to you, the Company's customer,         *
 *    for use solely and exclusively on Microchip dsPIC                *
 *    products. The software is owned by the Company and/or its        *
 *    supplier, and is protected under applicable copyright laws. All  *
 *    rights are reserved. Any use in violation of the foregoing       *
 *    restrictions may subject the user to criminal sanctions under    *
 *    applicable laws, as well as to civil liability for the breach of *
 *    the terms and conditions of this license.                        *
 *    THIS SOFTWARE IS PROVIDED IN AN "AS IS" CONDITION.  NO           *
 *    WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING,    *
 *    BUT NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND    *
 *    FITNESS FOR A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE     *
 *    COMPANY SHALL NOT, IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL,  *
 *    INCIDENTAL OR CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.  *
 *    Author: Steve Bowling                                            *
 *    Filename:       mc_dev_board.c	                               *
 *    Date:           11/01/06                                         *
 *    File Version:   3.00                                             *
 *    Tools used: MPLAB IDE  -> 7.43                                   *
 *                Compiler  -> 2.03                                    *
 *    Linker File:    p30f6010a.gld                                     *
 *	Code Description
 *  This code demonstrates the features of the dsPIC motor control
 *  development board and 3-phase power modules.
 *  The code can be programmed to drive different motor types depending
 *  on the buttons pressed on the PCB.  The following motors are
 *  supported:
 *	1.  open loop control of AC induction motor using V/Hz algorithm
 *  2.  open loop control of BLDC motor using hall-effect sensors
 *  3.  open loop control of brush DC motor.
 Revison History:
 Version 2.00:
 -Code modified to include C implementation of SVM() function.  SVM
  routine now allows full modulation range over previous version.
 -Mode selection interface modified to wait for key press at reset.
#include <p30F6010a.h>
#include "hardware.h"
#include "xlcd.h"
#include "svm.h"
/************************Configuration Bits***************************/
_FOSC(CSW_FSCM_OFF & XT_PLL4);
_FWDT(WDT_OFF);
_FBORPOR(PBOR_OFF & MCLR_EN);
_FGS(CODE_PROT_OFF);
/*********************** START OF DEFINITIONS *******************/
// These are the counting periods for the medium and slow speed events.
// Count variables are decremented at each PWM interrupt.
#define	SLOW_EVENT_PERIOD	1600		// 100msec period for 16KHz PWM
#define	MEDIUM_EVENT_PERIOD	72			// 5msec period for 16KHz PWM
// Constants required by ACIM software
// These are the definitions used to derive the maximum modulation
// frequency.
// First, specify the max modulation frequency that you want.
#define	MAX_MOD_FREQ	60
// Next, specify the frequency of the PWM carrier
#define PWM_MOD_FREQ	16000
// Finally, specify the resolution of the modulation phase angle.
// This is how many counts it takes to complete one modulation
// electrical cycle.
#define	MOD_ANGLE_RES		65536
// Now, compute the modulation frequency limit value.  This
// constant will be used to limit the speed demand variable.
#define MOD_FREQ_LIMIT	(MAX_MOD_FREQ*MOD_ANGLE_RES)/PWM_MOD_FREQ
//  These constants define the slope of the Volts-Hertz profile
// and the lower and upper modulation index shelves.
#define V_HZ_SLOPE				200
#define	LOW_AMPLITUDE_LIMIT		2000
#define	HIGH_AMPLITUDE_LIMIT	32000
#define AMPLITUDE_POT_LIMIT		HIGH_AMPLITUDE_LIMIT/V_HZ_SLOPE
// Constants required by BLDC motor software
// The following definitions are the values that will be written to
// the OVDCON register to acheive the various BLDC commutation states.
// The commutation state is determined by reading the value of the
// hall effect sensors on the motor.
// States 0 and 7 are invalid states and therefore all PWM outputs
// are disabled.
// For soft
// switching, the top device is modulated, while the bottom device
// is always on.
#define  	STATE0  0x0000
#define		STATE1 	0x0210
#define		STATE2 	0x2004
#define		STATE3 	0x0204
#define		STATE4 	0x0801
#define		STATE5 	0x0810
#define  	STATE6  0x2001
#define  	STATE7  0x0000
#define BLDC_SPEED_LIMIT 900
// Constants required by DC motor software
#define BDC_SPEED_LIMIT	400
// Software flags
// This bit structure provides status flags for the software
volatile struct {
		unsigned 	:1;
        unsigned   	Reverse:1;
        unsigned   	Button1:1;
        unsigned   	Button2:1;
        unsigned   	Button3:1;
        unsigned   	Button4:1;
        unsigned    DirChange:1;
        unsigned    Accelerate:1;
        unsigned  	PWMFault:1;
        unsigned  	Restart:1;
        unsigned  	:1;
        unsigned    :1;
        unsigned   	:1;
        unsigned   	PWMEvent:1;
        unsigned   	MediumEvent:1;
        unsigned    SlowEvent:1;
} Flags;
// This bit structure provides mode flags for the software
volatile struct {
		unsigned 	ACIMTest:1;
        unsigned   	ACIM:1;
        unsigned   	BLDC:1;
        unsigned   	BDC:1;
        unsigned   	:1;
        unsigned   	:1;
        unsigned    :1;
        unsigned    :1;
        unsigned  	:1;
        unsigned  	:1;
        unsigned  	:1;
        unsigned    :1;
        unsigned   	:1;
        unsigned   	:1;
        unsigned   	:1;
        unsigned    :1;
} Mode;
// System variables
// This is a software counter used to time slower system events, such as
// button polling, etc.
unsigned int SlowEventCount, MediumEventCount;
// This variable is used as a software counter to turn the voltage boost
// circuit switch on and off.
unsigned int BoostCount;
// This variable holds the A/D potentiometer reading that controls speed.
unsigned int Speed, OldSpeed;
unsigned int temp;
// Variables required by ACIM software
// This variable holds the V/Hz slope for the ACIM profile.
unsigned int V_Hz_Slope;
// Phase and Amplitude are the two input variables to the PWM modulation
// function.
unsigned int Amplitude, Phase;
// Variables required for BLDC code
// This array holds the commutation states for the OVDCON register.
unsigned int BLDCstates[] = {STATE0, STATE1, STATE2, STATE3, STATE4, STATE5, STATE6, STATE7};
// The hall effect sensor states are read from the I/O port and stored
// in HallState.  HallState is used as an index to the BLDCstates
// array.
unsigned char HallState;
// System functions
void Setup(void);		// Initializes dsPIC and peripherals
int ReadADC(unsigned int channel);
void __attribute__((__interrupt__)) _PWMInterrupt(void);
void Delay(unsigned int count);
// Functions required by ACIM software
void Modulate(int volts, unsigned int angle);
// Code functions
main ( void )
Setup();
while(1)
	ClrWdt();		// Clear the watchdog timer
	// This code is executed after each PWM interrupt occurs.
	// The PWM ISR sets PWMflag to signal the interrupt.
	if(Flags.PWMEvent)
		// Run this code if driving an AC motor
		if(Mode.ACIM || Mode.ACIMTest)
			// The Speed variable is added or subtracted from the Phase
			// variable to control the modulation frequency.
			if(Flags.Reverse) 	Phase -= Speed;
			else				Phase += Speed;
			// Write the duty cycles to the PWM module by calling the SVM
			// routine.
			SVM(Amplitude,Phase);
		// Run this code if driving a BLDC motor
		if(Mode.BLDC)
			if(!Flags.PWMFault)
				// Read the hall effect sensors on PORTD
				HallState = (unsigned char)(PORTD >> 8) & 0x07;
				// Update the PWM override register with the appropriate commutation
				// state.
				if(Flags.Reverse)
					OVDCON = BLDCstates[7 - HallState];
				else
					OVDCON = BLDCstates[HallState];
		// Run this code if driving a brush DC motor
		if(Mode.BDC)
		// Clear the WDT in the PWM event loop
		ClrWdt();
		Flags.PWMEvent = 0;
		}		// end if(PWMEvent)
	// Medium speed event handler executes every 5msec
	if(Flags.MediumEvent)
		// This is the 'motion profile'.  If a direction change is
		// requested, this code will ramp down the speed setting,
		// reverse the motor, then slowly ramp it back up.
		if(Flags.DirChange)
			if(Flags.Accelerate)
				// If we're not back to original speed, then accelerate
				if(Speed != OldSpeed) Speed++;
				// If back at original speed, clear the DirChange flag and turn off LED
				else
					Flags.DirChange = 0;
					LED4 = 0;
			// If decelerating and speed is non-zero, slow down
			else if(Speed) Speed--;
			// Has the speed ramped down to 0?
			// If so, set the acceleration flag and reverse the direction.
			else if(!Speed)
				Flags.Accelerate = 1;
				Flags.Reverse = ~Flags.Reverse;
		if(Flags.Restart)
			if(Speed == OldSpeed) Flags.Restart = 0;
			else	Speed++;
		// Get the motor speed setting from the potentiometer on AN7
		if(!Flags.DirChange && !Flags.Restart)
			Speed = ReadADC(7);
			if(Mode.ACIM || Mode.ACIMTest) Speed >>= 2;
		if(Mode.ACIMTest)
			// In test mode, the V_Hz slope is determined by the voltage
			// on AN12.
			V_Hz_Slope = ReadADC(12) >> 1;
		else
			// In the normal ACIM mode, the V/Hz slope is set by a constant.
			V_Hz_Slope = V_HZ_SLOPE;
		// The following code handles the V/Hz profile for the ACIM modes
			// Limit the frequency range.
			if(Speed > MOD_FREQ_LIMIT) Speed = MOD_FREQ_LIMIT;
			// The following code limits the Amplitude variable that is
			// sent to  the modulaton routine.
			if(V_Hz_Slope == 0) Amplitude = 0;
			else
				// Calculate the maximum speed input setting that will not
				// exceed the amplitude limit when multiplied by the
				// V_Hz_Slope variable.
				temp = HIGH_AMPLITUDE_LIMIT/V_Hz_Slope;
				// If the speed input is greater than this, set the Amplitude
				// variable at its maximum limit.
				// Otherwise, multiply the speed input by the VHz slope to
				// get the modulation amplitude.
				if(Speed > temp)
					Amplitude = HIGH_AMPLITUDE_LIMIT;
				else
					Amplitude = Speed*V_Hz_Slope;
				if(Amplitude < LOW_AMPLITUDE_LIMIT)
					Amplitude = LOW_AMPLITUDE_LIMIT;
		if(Mode.BLDC)
			// Limit the maximum duty cycle
			if(Speed > BLDC_SPEED_LIMIT) Speed = BLDC_SPEED_LIMIT;
			// Write the new PWM duty cycles.
			PDC1 = Speed;
			PDC2 = Speed;
			PDC3 = Speed;
		if(Mode.BDC)
			// Limit the range of duty cycles.
			if(Speed > BDC_SPEED_LIMIT) Speed = BDC_SPEED_LIMIT;
			// Write the duty cycles to the PWM module.
			if(Flags.Reverse)
				PDC1 = PTPER - Speed;
				PDC2 = PTPER + Speed;
			else
				PDC1 = PTPER + Speed;
				PDC2 = PTPER - Speed;
			}     // end if(Mode.BDC)
		// This is the main loop code that responds to a fault event
		// signalled by the fault ISR.  Here, we just turn on a status
		// LED to let the user know that the fault occurred.
		// The fault condition is reset when Button 1 is pressed.
		if(Flags.PWMFault)
			LED1 = 1;
		Flags.MediumEvent = 0;
		}		//end if(MediumEvent)
	// Slow event handler executes every 100msec
	if(Flags.SlowEvent)
		// These statements check to see if any of the buttons are pressed.
		// If so, a software flag is set so the button press can be debounced.
		if(BUTTON1)	Flags.Button1 = 1;
		if(BUTTON2)	Flags.Button2 = 1;
		if(BUTTON3)	Flags.Button3 = 1;
		if(BUTTON4)	Flags.Button4 = 1;
		// Button #1 resets a fault event.
		// If button #1 is pressed, a reset signal will be sent to the
		// power module to clear any fault LEDs that are lit.  Also,
		// the PWM channels are re-enabled.
		if(Flags.Button1)
			// Wait until the button is released before doing anything.
			if(!BUTTON1)
				if(Flags.PWMFault)
					// Reset the speed variable.  Save the old speed for use
					// in the restart profile.
					OldSpeed = Speed;
					Speed = 0;
					if(Mode.BDC)
						// Set the duty cycles back to 50%.
						PDC1 = PTPER;
						PDC2 = PTPER;
						PDC3 = PTPER;
					else
						PDC1 = 0;
						PDC2 = 0;
						PDC3 = 0;
					Flags.Restart = 1;
					// Turn the PWM output back on that was disabled in the FLTA ISR
					OVDCON = 0x3F00;
					// Turn off the status LED
					LED1 = 0;
					// Reset the power module.
					FAULT_RESET = 1;
					Nop();
					Nop();
					Nop();
					FAULT_RESET = 0;
					// Clear the PWM fault flag
					Flags.PWMFault = 0;
				// Clear the button status flag.
				Flags.Button1 = 0;
		// Button2 turns the voltage boost on and off
		if(Flags.Button2)
			LED2 = 1;
			if(!BUTTON2)
				LED2 = 0;
				if(IEC0bits.T1IE)
					IEC0bits.T1IE = 0;
					PFC_FIRE = 0;
					BRAKE_FIRE = 0;
				else if(Mode.ACIM || Mode.ACIMTest)
					IEC0bits.T1IE = 1;
					BRAKE_FIRE = 1;
				Flags.Button2 = 0;
		// Button3 doesn't do anything for this application
		if(Flags.Button3)
			LED3 = 1;
			if(!BUTTON3)
				LED3 = 0;
				Flags.Button3 = 0;
		// Button #4 is used to set the direction of the motor.
		if(Flags.Button4)
			// Start a direction change if one is not already in progress
			// and the speed setting is non-zero.
			if(!BUTTON4  && !Flags.DirChange && Speed)
				LED4 = 1;
				// Set the direction change flag.
				Flags.DirChange = 1;
				// Tell the motion profile to decelerate the motor
				Flags.Accelerate = 0;
				// Save the current Speed setting
				OldSpeed = Speed;
				Flags.Button4 = 0;
		Flags.SlowEvent = 0;
		}		// end if(SlowEvent)
   	}			// end while(1)
}				// end main
void Setup(void)
// Initialize system variables and flags.
Speed = 0;
OldSpeed = 0;
SlowEventCount = SLOW_EVENT_PERIOD;
MediumEventCount = MEDIUM_EVENT_PERIOD;
Mode.ACIM = 0;
Mode.ACIMTest = 0;
Mode.BLDC = 0;
Mode.BDC = 0;
// Initialize PORTs
PORTA = 0;
PORTB = 0;				// Initialize PORTs
PORTC = 0;
PORTD = 0;
PORTE = 0;
PORTG = 0;
TRISA = 0x39FF;
TRISB = 0xFFFF;
TRISC = 0xFFF5;			// RC1 is LCD R/W line
						// RC3 is LCD RS line
TRISD = 0xD7C0;			// RD13 is LCD enable line
						// RD11 is output for PWM_OUTPUT_ENABLE line
						// RD5 is PFC_FIRE line
						// RD4 is BRAKE_FIRE line
						// RD3:RD0 are LCD data lines
TRISE = 0xFDFF;			// RE9 is output for FAULT_RESET line
TRISG = 0xFFFF;
LED1 = 1;
LED2 = 1;
LED3 = 1;
LED4 = 1;
Delay(50000);
LED1 = 0;
LED2 = 0;
LED3 = 0;
LED4 = 0;
Delay(50000);
// Initialize the LCD display
OpenXLCD(FOUR_BIT&LINES_5X7);
Delay(50000);
while(BusyXLCD());
SetDDRamAddr(0);
putsXLCD("dsPIC30F MC Demo");
while(BusyXLCD());
SetDDRamAddr(0x40);
putsXLCD("S1-S4 slct mode ");
// Wait for a button to be pressed.
while(!BUTTON1 && !BUTTON2 && !BUTTON3 && !BUTTON4);
Delay(10000);
// Get software mode
if(BUTTON1 && !BUTTON2 && !BUTTON3 && !BUTTON4)
	LED1 = 1;
	while(BUTTON1);
	Delay(50000);
	Mode.ACIM = 1;
	SetDDRamAddr(0x40);
	putsXLCD("ACIM Mode 1     ");
	LED1 = 0;
else if(!BUTTON1 && BUTTON2 && !BUTTON3 && !BUTTON4)
	LED2 = 1;
	while(BUTTON2);
	Delay(50000);
	SetDDRamAddr(0x40);
	putsXLCD("ACIM Mode 2     ");
	Mode.ACIMTest = 1;
	LED2 = 0;
else if(!BUTTON1 && !BUTTON2 && BUTTON3 && !BUTTON4)
	LED3 = 1;
	while(BUTTON3);
	Delay(50000);
	SetDDRamAddr(0x40);
	putsXLCD("BLDC Mode       ");
	Mode.BLDC = 1;
	LED3 = 0;
else if(!BUTTON1 && !BUTTON2 && !BUTTON3 && BUTTON4)
	LED4 = 1;
	while(BUTTON4);
	Delay(50000);
	SetDDRamAddr(0x40);
	putsXLCD("Brush DC Mode   ");
	Mode.BDC = 1;
	LED4 = 0;
else
	Delay(50000);
	SetDDRamAddr(0x40);
	putsXLCD("no mode selected");
// Initialize PWM
	PTPER = 230;		// Value gives 16KHZ center aligned PWM at 7.38MIPS
	PDC1 = 0;
	PDC2 = 0;
	PDC3 = 0;
	PDC4 = 0;
	PWMCON1 = 0x0077;	// Enable PWM 1,2,3 pairs for complementary mode
	DTCON1 = 0x000F;	// Value provides 2us dead time at 7.38 MIPS
	DTCON2 = 0;
	FLTACON = 0x0007;	// Fault A enabled for latched mode on PWM1, 2, and 3
	FLTBCON = 0;		// Fault B not used.
	OVDCON	= 0x3F00;	// Enable PWM1H,1L, 2H, 2L, 3L, 3H for PWM
	PTCON = 0x8002;		// Enable PWM for center aligned operation
else if(Mode.BLDC)
	PTPER = 460;		// Value gives 16KHZ edge aligned PWM at 7.38MIPS
	PDC1 = 0;
	PDC2 = 0;
	PDC3 = 0;
	PDC4 = 0;
	PWMCON1 = 0x0777;	// Enable PWM 1,2,3 pairs for independent mode
	DTCON1 = 0;			// Dead time disabled
	DTCON2 = 0;
	PTCON = 0x8000;		// Enable PWM for edge aligned operation
else if(Mode.BDC)
	PDC1 = PTPER;
	PDC2 = PTPER;
	PDC3 = 0;
	PDC4 = 0;
	PWMCON1 = 0x0033;	// Enable PWM 1,2 pairs for complementary mode
	DTCON2 = 0;
	FLTACON = 0x0003;	// Fault A enabled for latched mode on PWM1, 2
	OVDCON	= 0x0F00;	// Enable PWM1H,1L, 2H, and 2L for PWM
else
	// If no mode is selected, the PWM timebase provides interrupt
	// generation only.  No PWM outputs are enabled.
IFS2bits.PWMIF = 0;
IEC2bits.PWMIE = 1;	// Enable PWM interrupts.
IFS2bits.FLTAIF = 0;// Clear the fault A interrupt flag.
IEC2bits.FLTAIE = 1;// Enable interrupts for Fault A
// Initialize ADC
ADCON1 = 0;
ADCON2 = 0;
ADCON3 = 0;
ADPCFG = 0x0003;
ADCHS = 0x0007;
ADCON1bits.ADON = 1;
// Reset any active faults on the motor control power module.
FAULT_RESET = 1;
Delay(10);
FAULT_RESET = 0;
// Configure Timer1, but don't enable interrupts
// Timer 1 is used to drive the PFC circuit
TMR1 = 0;
PR1 = 60;
T1CON = 0x8000;
IFS0bits.T1IF = 0;
IEC0bits.T1IE = 0;
// Enable the driver IC on the motor control PCB
PWM_OUTPUT_DISABLE = 0;
// Ensure PFC switch is off.
PFC_FIRE = 0;
// Turn brake off.
BRAKE_FIRE = 0;
// Ensure FLTA flag is cleared
int Delay;
if(channel > 0x000F) return(0);
ADCHS = channel;
ADCON1bits.SAMP = 1;
for(Delay = 0; Delay < 20; Delay++);
IFS0bits.ADIF = 0;
ADCON1bits.SAMP = 0;
while(!IFS0bits.ADIF);
return(ADCBUF0);
// The PWM ISR just sets a software flag to trigger SVM calculations
// in the main software loop.
SlowEventCount--;
if(SlowEventCount == 0)
	Flags.SlowEvent = 1;
MediumEventCount--;
if(MediumEventCount == 0)
	Flags.MediumEvent = 1;
Flags.PWMEvent = 1;
IFS2bits.PWMIF = 0;
// The FLTA ISR responds to events on the PWM fault pin.
// This ISR code just turns off all the PWM outputs via the OVDCON
// register and signals the main loop that a problem has occurred.
void __attribute__((__interrupt__)) _FLTAInterrupt(void)
// Keep all outputs disabled until we figure out what is going on!
OVDCON = 0;
PFC_FIRE = 0;
// Signal a fault to the main loop.
Flags.PWMFault = 1;
// Clear the FLTA interrupt flag.
// The Timer1 ISR is used to drive the voltage boost circuit
void __attribute__((__interrupt__)) _T1Interrupt(void)
if(++BoostCount > 4)
	PFC_FIRE = 1;
	BoostCount = 0;
else
	PFC_FIRE = 0;
// Clear the Timer1 interrupt flag.
IFS0bits.T1IF = 0;
// This is a generic delay routine
unsigned int j;
for(j=0;j<count;j++)
	ClrWdt();
// end of file
Bu istediğini kimse yapmaz. Hadi yaptı diyelim bu senin büyük ihtimal bir işine yaramaz. Bu kodu anlamak bir motor kontrolünün en son aşaması. Sistemi modelleyip analiz edip, sürücü devreyi ve kontrol algoritmasını tasarlayıp en son uygulama kısmına geçince mikrokontrolörler kullanarak sistemi gerçeklersin. İste o gerçekleme aşamasında böyle bir program yazman gerekir.
arifardaozdemir
Şu anda çevrimiçi üye yok.
