s7 1200 -S7300 analog çıkışa rampalı komut gönderme
AhmetNuri
19 Nis 2007
merhaba
s7 1200 de analog cikisa rampali komut gonderme icin hazir bir fonksiyon var mi
analog cikisin birden bire degil belli bir yavaslikla acilmasni istiyprum.
Siemens Industry Online Support - Automation Service, Automation Support, Simatic Service, Simatic Support, Technical Support, Technical Consulting
Merhaba;
Siemens support'taki örnek V13 için yapılmış. V12 için örnek var mı elinizde. Support'ta bulamadım ben.
İyi Çalışmalar
Kod:
FUNCTION_BLOCK FB67
TITLE ='rate limiter'
AUTHOR : hdhosseini
VERSION : '1.0'
// Block Parameters
VAR_INPUT
    // Input Parameters
input:REAL;
rst:BOOL:=false;
step:REAL:=0.1; //100ms call
factor:REAL:=1.0;
high:REAL:=100;
low:REAL:=0;
END_VAR
VAR_IN_OUT
    // I/O Parameters
    first:BOOL:=true;
END_VAR
VAR_OUTPUT
    // Output Parameters
out:REAL;
END_VAR
VAR_TEMP
    // Temporary Variables
END_VAR
VAR
    // Static Variables
buffer:REAL:=0;
in:REAL;
END_VAR
    // Statement Section
    IF  rst=true THEN
      buffer:=0;
      //first:=true;
      out:=0;
      in:=0;
    ELSE
    IF first= true THEN
        buffer:=in;
        first:=false;
    END_IF;
     IF input >= high THEN
        in:=high;
    END_IF;
      IF input <= low THEN
        in:=low;
    END_IF;
          IF (input > low) AND (input<high) THEN
        in:=input;
    END_IF;
     IF in > (buffer+step) THEN
        buffer:= (buffer+(step* factor));
    END_IF;
     IF in < (buffer-step) THEN
        buffer:= (buffer-(step*factor));
    END_IF;
    IF in = buffer THEN
       buffer:=in;
        END_IF;
    out:= buffer;
    END_IF;
END_FUNCTION_BLOCK
Fatih Yalçınkaya
