amaka
- 13 Tem 2010
- 14
- 1
Oyun
500
Intel Celeron 430 1.8 GHz 800MHz 512KB .......... İşlemci .......... AMD Athlon II X2 250 3.0GHz
Biostar G41-M7 1333 FSB/DDR2 .......... Anakart .......... FOXCONN A6GMV Amd 690G DDR3 1333MHz
HIS HD5570 Fan 1 GB 128Bit DDR3 .......... Ekran Kartı .......... VTX3D Ati HD5570 1GB GDDR3 128Bit
A-DATA 2 GB 800 MHz DDR2 .......... Bellek .......... A-DATA 2 GB 800 MHz DDR2 RAM
Seagate 250 GB 7200 RPM 8MB SATA2 NCQ .......... Sabit Disk .......... WESTERN DIGITal Caviar Blue 320GB 16MB
AOPEN ES55-Y010 300W Atx .......... Kasa .......... AOPEN ES55-Y010 300W Atx
Tavsiyem: AMD
750
Intel Dual Core E5300 2.60 GHz .......... İşlemci .......... AMD Athlon II X3 445 3.1GHz
Biostar G41-M7 1333 FSB/DDR2 1066MHz .......... Anakart .......... GIGABYTE GA-MA74GMT-S2 AMD 740G DDR3
HIS HD5750 iCooler IV 1 GB 128Bit GDDR5 .......... Ekran Kartı .......... PALIT GTS450 Sonic Platinum 1GB DDR5 128Bit HDMI 1
2x A-DATA 2 GB 800 MHz DDR2 .......... Bellek .......... MACH XTREME MXD3V13332GS Value 2GB DDR3 1333MHz
WD 320 GB 7200 RPM 16MB SATA2 WD3200AAKS .......... Sabit Disk .......... SAMSUNG HD502HJ Spinpoint F3 500GB 7200Rpm
GIGABYTE GZ-X6BPD-100 Atx 420W Kasa.......... Kasa .......... GIGABYTE GZ-X6BPD-100 Atx 420W Kasa
Tavsiyem: AMD
1000
Intel Core i3 540 3.06 GHz 4MB 1156p (733MHz VGA) .......... İşlemci .......... AMD Athlon II X4 640 3.0GHz
ASUS P7H55-M LX H55 DDR3 1333MHz DVI Vga 16x mAtx .......... Anakart .......... Gigabyte GA-880GM-D2H Amd 880G DDR3
ZOTAC GTX460 Synergy 768MB GDDR5 192Bit HDMI 16x Z .......... Ekran Kartı .......... GIGABYTE GV-N460OC-1GI GTX460 OC 1GB DDR5 256Bit 1
G.SKILL F3-10600CL9D-4GBNT Value 4GB (2x2GB) DDR3 .......... Bellek .......... G.SKILL F3-10600CL9D-4GBNT Value 4GB (2x2GB) DDR3
SAMSUNG HD502HJ Spinpoint F3 500GB 7200Rpm SATA2 1 .......... Sabit Disk .......... SAMSUNG HD502HJ Spinpoint F3 500GB 7200Rpm SATA2 1
THERMALTAKE WingsRS 200 Piano Black MidTower 500W .......... Kasa .......... THERMALTAKE WingsRS 200 Piano Black MidTower 500W
Tavsiyem: INTEL
1250
Intel Core i3 540 3.06 GHz 4MB 1156p (733MHz VGA) .......... İşlemci .......... AMD Phenom II X4 925 2.8GHz
Gigabyte H55M-S2 /DDR3 .......... Anakart .......... Asus M4A88TD-M EVO/USB3 AMD 880G DDR3 Sata3 Usb3.0
MSI GTX460 Cyclone OC 1 GB 256Bit GDDR5 16X .......... Ekran Kartı .......... GIGABYTE GV-N460OC-1GI GTX460 OC 1GB DDR5 256Bit 1
2X Kingston 2 GB 1333 MHz DDR3 .......... Bellek .......... G.SKILL F3-10600CL9D-4GBNT Value 4GB (2x2GB) DDR3
WD 320 GB 7200 RPM 16MB .......... Sabit Disk .......... SAMSUNG HD103SJ Spinpoint F3 1TB 7200Rpm SATA2 32M
LC-POWER Pro-919B Aequitas Pro-Line Gaming Kasa 60 .......... Kasa .......... LC-POWER Pro-919B Aequitas Pro-Line Gaming Kasa 60
Tavsiyem: AMD
1500
INTEL Core i5-760 2.80GHz .......... İşlemci .......... AMD Phenom II 945 X4 (3.0 GHz) 8MB
ASUS P7P55 LX P55 DDR3 2200MHz 16x Lga1156 .......... Anakart .......... Asus M4A88TD-M / DDR3 2000MHz
Sapphire HD6870 1GB GDDR5 256Bit mDP HDMI 16x 2117 .......... Ekran Kartı .......... Sapphire HD6870 1GB GDDR5 256Bit mDP HDMI 16x 2117
G.SKILL F3-10600CL9D-4GBNT Value 4GB (2x2GB) DDR3 .......... Bellek .......... 2x A-DATA 2 GB 1333 MHz DDR3
SAMSUNG HD103SJ Spinpoint F3 1TB 7200Rpm SATA2 32M .......... Sabit Disk .......... WD 320 GB 7200 RPM 16MB
LC-POWER Pro-919B Aequitas Pro-Line Gaming Kasa 60 .......... Kasa ..........LC-POWER Pro-919B Aequitas Pro-Line Gaming Kasa 60
Tavsiyem: INTEL
1750
Intel Core i5 760 2.80 GHz 8MB 1156p .......... İşlemci .......... AMD Phenom II X6 1055T 2.8GHz
Asus P7P55 LX / DDR3 2200 S+GL+1394+RAID+16X 1156 .......... Anakart .......... ASUS M4A87TD/USB3 AMD 870 DDR3 2000MHz Sata3 16x A
HIS HD5870 iCooler V 1 GB 256Bit GDDR5 16X .......... Ekran Kartı .......... POWERCOLOR HD5870 PCS+ 1GB DDR5 256Bit HDMI 16X
2x A-DATA 2 GB 1333 MHz DDR3 RAM .......... Bellek ......... G.SKILL F3-10600CL9D-4GBNT Value 4GB (2x2GB) DDR3
WD 500 GB 7200 RPM 32MB SATA2 (Caviar Black ) .......... Sabit Disk .......... SAMSUNG HD502HJ Spinpoint F3 500GB 7200Rpm SATA2 1
LC-POWER Pro-919B Aequitas Pro-Line Gaming Kasa .......... Kasa .......... LC-POWER Pro-919B Aequitas Pro-Line Gaming Kasa
LC-POWER LC6650GP3 V2.3 Green Power 600W (650W Max) .. Güç Kaynağı.. LC-POWER LC6650GP3 V2.3 Green Power 600W (650W Max)
Tavsiyem: AMD
2000
Intel Core i5 760 2.80 GHz 8MB 1156p .......... İşlemci .......... AMD Phenom II X6 1055T (2.8 GHz)
Asus P7P55 LX / DDR3 2200 .......... Anakart .......... Gigabyte GA-880GA-UD3H AMD 880G DDR3
Palit GTX480 1536 MB 384Bit GDDR5 16X .......... Ekran Kartı .......... ZOTAC GeForce GTX480 1536MB GDDR5
2x A-DATA 2 GB 1333 MHz DDR3 .......... Bellek .......... G.SKILL F3-12800CL8D-4GBRM Ripjaws 4GB DDR3 1600Mh
WD 500 GB 7200 RPM 32MB SATA2 (Caviar Black ) .......... Sabit Disk .......... WESTERN DIGITAL WD1002FAEX Caviar Black 1TB 64MB
Tavsiyem: AMD
2000+
INTEL Core i7-950 3.06GHz .......... İşlemci .......... AMD Phenom II X6 1090T (3.2 GHz) 9MB 938p 125W BE
Gigabyte GA-X58A-UD7 DDR3 2200MHz Sata3 Usb3.0 Cor .......... Anakart .......... Asus Crosshair IV Formula / DDR3 S+V+GL+16X*4 938
SAPPHIRE HD5970 2GB GDDR5 512Bit 16x .......... Ekran Kartı .......... ATI PowerColor HD5970 2 GB 256Bit GDDR5 Dual DVI
G.SKILL Ripjaws 6GB DDR3 1600Mhz CL8 (3x2GB) F3-12 .......... Bellek .......... Kingston HyperX 4 GB (2*2) 1600 MHz DDR3 RAM CL9
INTEL 80GB X25-M SSD / Western Digital Caviar Blac .......... Sabit Disk .......... WD 1 TB 7200 RPM 32MB SATA2 (Caviar Black)
Cooler Master HAF X Siyah Big Tower XL-ATX Psu'suz .......... Kasa .......... Cooler Master HAF X Siyah Big Tower XL-ATX Psu'suz
THERMALTAKE Toughpower XT 875W .. Güç Kaynağı.. THERMALTAKE Toughpower XT 875W
Performans
Tavsiyem: INTEL
CF vs SLI
i7 950 .......... İşlemci .......... i7 950
Msi X58 Eclipse .......... Anakart .......... Msi X58 Eclipse
HD6870 CF .......... Ekran Kartı .......... GTX 480^2 SLI
Team Xtreem Low Voltage Series .......... Bellek .......... Team Xtreem Low Voltage Series
WD Caviar Black SATA2 1TB *2 (Raid 0) .......... Sabit Disk .......... WD Caviar Black SATA2 1TB *2 (Raid 0)
Lian Li V2000B PlusII .......... Kasa .......... Lian Li V2000B PlusII
High Power Rock Solid 1000W .......... Güç Kaynağı .......... High Power Rock Solid 1000W
Tavsiyem: Crossfire Sistem
Ofis - İnternet
Ekonomik
Intel Dual Core E5300 2.60 GHz 800MHz 2MB 775p .......... İşlemci .......... AMD Athlon II X2 245 (2.9GHz) 2MB (AM3 938Pin)
Foxconn G31MXP-K 1600 FSB/DDR2 800 .......... Anakart .......... Biostar TA785GE AMD785G/DDR2
2x Kingston 1 GB 800 MHz DDR2 RAM CL6 .......... Bellek .......... 2x Kingston 1 GB 800 MHz DDR2 RAM CL6
WD 320 GB 7200 RPM 16MB SATA2 WD3200AAKS .......... Sabit Disk .......... WD 320 GB 7200 RPM 16MB SATA2 WD3200AAKS
Aopen H340G 200W Slim Kasa Siyah/Gümüş.......... Kasa ..........Aopen H340G 200W Slim Kasa Siyah/Gümüş
Tavsiyem: INTEL
Performans
Intel Core i3 540 3.06 GHz 4MB 1156p (733MHz VGA) .......... İşlemci .......... AMD Phenom II 945 X4 (3.0 GHz) 8MB (AM3 938Pin)
Gigabyte H57M-USB3/DDR3 .......... Anakart .......... Asus M4A88TD-M EVO/USB3 /DDR3
2x A-DATA 2 GB 1333 MHz DDR3 .......... Bellek .......... 2x A-DATA 2 GB 1333 MHz DDR3
WD 1 TB 7200 RPM 32MB SATA2 (Caviar Black) .......... Sabit Disk .......... WD 1 TB 7200 RPM 32MB SATA2 (Caviar Black)
Aopen H500Y Y12 350W ATX Kasa (Siyah) .......... Kasa .......... Aopen H500Y Y12 350W ATX Kasa (Siyah)
Tavsiyem: AMD
Video İşleme - Grafik Tasarım
Ekonomik
Intel Core i5 760 2.80 GHz 8MB 1156p .......... İşlemci .......... AMD Phenom II X6 1055T (2.8 GHz) 9MB 938p 125W
Asus P7P55D-E LX / DDR3 .......... Anakart .......... Asus M4A87TD/USB3 /DDR3 2000MHz
PNY Quadro FX 580 512 MB 128Bit GDDR3 16X .......... Ekran Kartı .......... PNY Quadro FX 580 512 MB 128Bit GDDR3 16X
WD 500 GB 7200 RPM 32MB SATA2 (Caviar Black ) .......... Sabit Disk .......... WD 500 GB 7200 RPM 32MB SATA2 (Caviar Black )
Gigabyte Setto 1000 550w Atx Kasa Siyah .......... Kasa .......... Gigabyte Setto 1000 550w Atx Kasa Siyah
Tavsiyem: AMD
Performans
Intel Core i7 930 2.80 GHz 8MB 1366p .......... İşlemci .......... AMD Phenom II X6 1090T (3.2 GHz) 9MB 938p 125W BE
Asus P6T SE X58 6.4GT/s DDR3 .......... Anakart .......... Asus M4A88TD-M / DDR3 2000
PNY Quadro FX 3800 1 GB 256Bit GDDR3 16X .......... Ekran Kartı .......... PNY Quadro FX 3800 1 GB 256Bit GDDR3 16X
A-DATA 6 GB (3*2) 1600 MHz DDR3 OC. Triple Kit CL8 .......... Bellek .......... 2x 4 GB 1333 MHz DDR3
Tavsiyem: AMD
Film - Müzik - Download
Ekonomik
Intel Core2 Duo E7500 2.93 GHz 1066MHz 3MB .......... İşlemci .......... AMD Athlon II X2 250 (3GHz) 2MB (AM3 938Pin)
ZOTAC G41 ITX-A-E Mini ITX WiFi Anakart (Intel Cor .......... Anakart .......... SAPPHIRE Pure Mini 785G AMD AM3 Mini ITX Anakart (
2x TEAM Elite Serisi PC2 6400 DDR2 800MHz CL5 1GB .......... Bellek .......... 2x TEAM Elite Serisi PC2 6400 DDR2 800MHz CL5 1GB
DARK Mini Office 200W Güç Kaynaklı Mini-ITX HTPC K .......... Kasa .......... DARK Mini Office 200W Güç Kaynaklı Mini-ITX HTPC K
Tavsiyem: INTEL
Performans
Intel Core i3 540 3.06 GHz 4MB 1156p (733MHz VGA) .......... İşlemci .......... AMD Phenom II 560 X2 (3.3 GHz) 7MB 938p Black Ed.
ZOTAC H55 ITX-A-E Mini-ITX WiFi Anakart (Core i3/i .......... Anakart .......... SAPPHIRE Pure Mini 785G AMD AM3 Mini ITX Anakart (
2x TEAM Elite Serisi DDR3 1600MHz Low Voltage 2GB .......... Bellek .......... Kingston 2GB(2X1GB) DDR2 800MHZ
Tavsiyem: INTEL
