Raspberry pi Gtk penceresi
İlk önce gtk nın nasıl çalıştığını öğrenmen lazım. sonra kendine uyarlayacaksın. Basit form uygulamalarına başlaman gerek
Bu kodları mesafe hcsr04 ile mesafa ölçümü için nasıl uyarlayabilirim
#include <gtk/gtk.h>
#include <string.h>
GtkWidget *window;
GtkWidget *button_01;
GtkWidget *button_02;
GtkWidget *label0;
GtkWidget *label1;
GtkWidget *label2;
static void print_hello (GtkWidget *widget, gpointer data)
gtk_label_set_text(GTK_LABEL(label0),(const gchar*) "MECHATRONIC");
static void activate (GtkApplication *app, gpointer user_data)
window = gtk_application_window_new (app);;
button_01 = gtk_button_new_with_label("This is button 01");
g_signal_connect (button_01, "clicked", G_CALLBACK (print_hello), NULL);
button_02 = gtk_button_new_with_label("This is button 02");
g_signal_connect (button_02, "clicked", G_CALLBACK (print_hello), NULL);
label0 = gtk_label_new("hello 0");
label1 = gtk_label_new("hello 1");
label2 = gtk_label_new("hello 2");
GtkWidget *main_box = gtk_box_new (GTK_ORIENTATION_VERTICAL, 25);
GtkCssProvider *cssProvider = gtk_css_provider_new();
gtk_css_provider_load_from_path(cssProvider, "theme.css", NULL);
gtk_style_context_add_provider_for_screen(gdk_screen_get_default(),
GTK_STYLE_PROVIDER(cssProvider),
GTK_STYLE_PROVIDER_PRIORITY_USER);
gtk_box_set_homogeneous (GTK_BOX (main_box), TRUE);
gtk_container_add (GTK_CONTAINER (window), main_box);
gtk_container_add (GTK_CONTAINER (main_box), button_01);
gtk_container_add (GTK_CONTAINER (main_box), label0);
gtk_container_add (GTK_CONTAINER (main_box), label1);
gtk_container_add (GTK_CONTAINER (main_box), label2);
gtk_container_add (GTK_CONTAINER (main_box), button_02);
g_signal_connect(window, "destroy", G_CALLBACK(gtk_main_quit), NULL);
gtk_widget_show_all (window);
int main (int argc, char **argv)
GtkApplication *app;
int status;
app = gtk_application_new ("org.gtk.example", G_APPLICATION_FLAGS_NONE);
g_signal_connect (app, "activate", G_CALLBACK (activate), NULL);
status = g_application_run (G_APPLICATION (app), argc, argv);
g_object_unref (app);
return status;
delta2366
