perçin
#include "C:\Documents and Settings\perçin\Belgelerim\ccs c cod\12F675_triyak_kontrol.h"
///*********************** TRİYAK KONTROL ************************************//
#fuses INTRC_IO, NOWDT, NOMCLR, PROTECT, NOBROWNOUT
#include <math.h>
#use delay(clock=4000000)
#define timer 1
int16 adc;
int i=0;
#int_timer0
void zero_crossing()
set_timer0(timer);
set_adc_channel(0);
adc=read_adc();
if(input(pin_a1)==0)
i++;
while(input(pin_a1)==0)
{i=i;}
delay_us(adc*50);
output_high(pin_a2);
delay_us(11);
output_low(pin_a2);
void main()
setup_adc(ADC_CLOCK_INTERNAL );
setup_adc_ports( AN0_analog);
delay_ms(1);
set_adc_channel(0);
setup_timer_0(RTCC_INTERNAL | RTCC_DIV_1);
set_timer0(timer);
enable_interrupts(INT_TIMER0);
enable_interrupts(GLOBAL);
while(1);}
#include <math.h>
#define timer 1
int16 adc;
int i=0;
#int_timer0
set_timer0(timer);
set_adc_channel(0);
adc=read_adc();
i++;
{i=i;}
delay_us(adc*50);
delay_us(11);
output_low(pin_a2);
void main()
delay_ms(1);
set_adc_channel(0);
set_timer0(timer);
while(1);}
