Asm Kodu...
mgokce
7 Kas 2009
bu programda hatayı bulamadım yardımcı olunursa sevinirim...
list p=16f84, f=inhx8m,
INCLUDE P16f84.INC
; Defining: variables in RAM memory
include d:\pic\dim\dimprom.asm
; Program code
#define STISAK_KASNJENJE .50
#define VREDNOST_MAX .200
#define VREDNOST_MIN .4
ORG 0000h ; Reset vector.
Init bcf INTCON,GIE ; hardware initialization
clrf STATUS ; turn off interapt
clrf PORTB ;
goto InitNext ;
ORG 0004h ; Interrupt vector.
goto Main_init
; Main program
Main_init
movlw 0x03
movwf PORTB
movlw VREDNOST_MAX
movwf Vrednost
movlw 0xff
movwf Smer
;test call Tastaturamain
; goto test
Main_prvi
call Tastaturamain
btfss PORTA,1 ; waiting for histerezis
goto Main_prvi
;initialization of first half-period
bcf PORTB,1
clrf TMR0
Prvapetlja
btfss PORTA,1 ; check + half-periode
goto Main_drugi
movf Vrednost,W
subwf TMR0,W
btfss STATUS,C ; is TMR0-Vrednpost <0 ?
goto Prvapetlja
;turn on - PALI
bsf PORTB,1
call Ukljuci
Prvpetcekaj
btfsc PORTA,1
goto Prvpetcekaj ; + period is still going
bcf PORTB,1
Main_drugi
call Tastaturamain
btfsc PORTA,2
goto Main_drugi
;inicijalization of second half-periode
bcf PORTB,1
clrf TMR0
Drugapetlja
btfsc PORTA,2
goto Main_prvi
movf Vrednost,W
subwf TMR0,W
btfss STATUS,C
goto Drugapetlja
;turn on
bsf PORTB,1
call Ukljuci
Drugapetljacekaj
btfss PORTA,2
goto Drugapetljacekaj
bcf PORTB,1
goto Main_prvi
Ukljuci
;software compensation starts here
movlw .150
subwf Vrednost,W ;compensation of histerezis
btfsc STATUS,C
return
;software compensation ends here, this 4 lines can be removed
movlw b'00001111'
movwf PORTB
movlw b'00000000'
bsf STATUS,RP0
movwf TRISB
bcf STATUS,RP0
nop
nop
nop
nop
nop
nop
nop
movlw b'00000001'
bsf STATUS,RP0
movwf TRISB
bcf STATUS,RP0
return
; sub-program for taster switch
Tastaturamain
movf PORTA,W
andlw b'00000001' ;filter for zero bit
movwf Sad ;puts in Sad and after that puts in Pre
andwf Pre,W ;this is for taster switch debounsing
movwf Stanje ;
movf Sad,W
movwf Pre ;if two succesive reading of RA0 are logical 1
btfss Juce,0 ;taster-switch is pushed, then variable Stanje gets
goto Tastkraj ;value 1;
btfss Stanje,0
goto Tastprekinutpritisak ;check push button is released
;The new and previous reading of pushbutton switch are 1, pushbutton is pressed
movlw STISAK_KASNJENJE
subwf Stisak,W ;pushbutton is not released
btfss STATUS,C ;checks how long it was keept pushed
goto Tastparanput ;even and odd, to slow down counting
;light on
decf Stisak,F
movlw 0xff
xorwf Speedcontrol,F
movf Speedcontrol,F
btfss STATUS,Z
goto Tastparanput
;odd pass, only for slow down
btfss Smer,0 ;check the positive direction
goto Tastnegativansmer ;negative direction
;positive direction
movlw VREDNOST_MAX
subwf Vrednost,W
btfss STATUS,Z
goto Tastnijemaxdim
;count off, change direction
clrf Smer
decf Vrednost,F
Tastnijemaxdim
incf Vrednost,F
Tastparanput
incf Stisak,F
Tastkraj
movf Stanje,W
movwf Juce
Tastend
return
Tastnegativansmer
movlw VREDNOST_MIN
subwf Vrednost,W
btfss STATUS,Z
goto Tastnegativansmerkraj
movlw 0xff ;change direction in case of count off
movwf Smer
incf Vrednost,F
;negative direction,
decf Vrednost,F
goto Tastparanput
movlw STISAK_KASNJENJE ;taster is released, check time to pass
subwf Stisak,W ;keeping taster switch pressed
btfsc STATUS,Z ;
goto Tastprekinutpritisakpreskok
movlw VREDNOST_MIN
movwf Vrednost
btfsc Smer,0
movlw VREDNOST_MAX
movwf Vrednost
movlw 0xff
xorwf Smer,F
clrf Stisak
goto Tastkraj
; initialization
InitNext clrf PORTA ;
bsf STATUS,RP0 ;
movlw b'00000001' ; RB1-RB7,are outputs, RB0 input
movwf TRISB ;
movlw b'00011111' ; RA0-RA4 are inputs.
movwf TRISA
movlw b'10000101' ; Configure OPTION register
movwf OPTION_REG ;
bcf STATUS,RP0 ;
clrf TMR0 ; TMR0 = 0.
movlw b'00000000' ; Configure INTCON register
movwf INTCON ; 7-GIE, 6-EEIE, 5-T0IE, 4-INTE
; 3-RBIE, 2-TOIF, 1-INTF, RBIF
movlw 0ch ;
movwf FSR ; clear RAM
MoreMem clrf INDF ;
incf FSR,F ;
movlw 4fh ;
xorwf FSR,W
btfss STATUS,Z
goto MoreMem
goto Main_init ;
END
Öncelikle parametre ve değişken isimlerinin Slovence yazılmış olan bir kodu bulduğunuz için helal olsun size. :)
İlk olarak şunu sorayım;
Elinizde "include d:\pic\dim\dimprom.asm" tanımlamasında geçen dimprom.asm dosyası var mı?
Zira kodda o asm dosyası da kullanılıyor.
evet o dasyada mevcut... ben anlamamıştım hangi dil olduğunu ama öğrendim bunu bende kendimi tebrik ettim :D:D
Bence proje lisans amacı gütmüyorsa, projeyi tümden zipleyip bir siteye yükleyin ve bağlantıyı burada paylaşın.
Eğer yapabileceğim bir şeyse, sorunu çözer, burada tekrardan paylaşırım. ;)
Aslında ödev var oda şu uzaktan kontrol dimmer kontrol devresi proteusta devreyi hazırladım ama picte zayıf olduğum için bu programdan yararlanmam lazım :S aslında program 16f48 e göre hazırlanmış ben 16f628 kullandım devrede... programı 16f628 e göre dizayn edilebilir diye düşünüyorum ancak programı derlediğimde hata veriyor... onu bulamadığım için dizayn işlemini düşünemiyorum.... öneriniz varsa hemen uygulayacağım hocam...
Kusura bakma, cevabım biraz geç oldu.
Ben de şuan PIC18F452 ile geliştirdiğim bir proje ile uğraşıyorum.
SD Card konusunda sinir etti beni. :)
PIC16F84A'dan, PIC16F628A'ya geçişte bir sorun yaşayacağını sanmıyorum.
Ancak dediğim gibi devreyi görmem lazım, amacını tam olarak anlamam lazım ki, ona göre yardımcı olayım.
@mgokce
Eklediğiniz dimmer devresinin asm kodunu düzeltmekle uğraşmayın çok hata ve eksik var.
1-)Kaynak kodun olduğu 1-2 site var.Ancak siteler uçmuş çoktan
2-)
-include d:\pic\dim\dimprom.asm dosyası var mı?
3-)-include d:\pic\dim\dimprom.asm dosyası olsa bile kopyala-yapıştır yapılan kodda kodlar birbirine girmiş.
Devrenin asm dosyası ve dimprom.asm düzgün haliyle mevcutsa düzeltmeler için paylaşmanız gerekmektedir veya başka devre arayınız
@mgokce
2-)
Dediklerinize aynen katılıyorum. :)
Hazırlamış olduğum devre bu şekilde bi kaç ufak hata olabilir. ama hatttıla bu şekilde ... uzaktan kontrollü bir lamba devresi olarak 16f628A kullandım... eksik olan pice program atmak...
Sen PIC'i mi programlayamıyorsun?
Yoksa PIC'e programlanacak yazılımı mı geliştiremiyorsun?
Xte13
