Bilgisayarım geç açılıyor
at formatı kesin çözüm :)
Soru soran arkadaş neden sistem konfigürasyonunu yazmıyor. Belki MMX bir makine kullanıyordur ?
Driverları kurdum diyor ! performans testine sokmuş mu acaba ?
Herkes ezbere bildiklerini yardımcı olmak babında paylaşıyor ama sorunun çözülmesine katkı sağlamıyor.
Lütfen dxdiag çıktısını ve anakart marka ve modelini yazınız.
Dxdiag çıktı örneği aşağıda yazılıdır.
Kod:
System Information
Time of this report: 4/2/2014, 11:32:08
       Machine name: Burada PC adı yazar
   Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_qfe.130503-0418)
           Language: Turkish (Regional Setting: Turkish)
System Manufacturer: 75V80
       System Model: 775VM800
               BIOS: Default System BIOS
          Processor: Intel(R) Pentium(R) 4 CPU 3.20GHz (2 CPUs)
             Memory: 1984MB RAM
          Page File: 733MB used, 3146MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.5512 32bit Unicode
DxDiag Notes
  DirectX Files Tab: No problems found.
      Display Tab 1: No problems found.
        Sound Tab 1: The file cmuda.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL).  You may be able to get a WHQL logo'd driver from the hardware manufacturer.
          Music Tab: No problems found.
          Input Tab: No problems found.
        Network Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (n/a)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
        Card name: VIA/S3G UniChrome Pro IGP
     Manufacturer: VIA/S3G
        Chip type: VIA/S3G UniChrome Pro IGP
         DAC type: Internal
       Device Key: Enum\PCI\VEN_1106&DEV_3344&SUBSYS_33441849&REV_01
   Display Memory: 64.0 MB
     Current Mode: 1280 x 1024 (32 bit) (60Hz)
          Monitor: Tak ve Kullan Monitör
  Monitor Max Res: 1600,1200
      Driver Name: vtdisp.dll
   Driver Version: 6.14.0010.0226 (English)
      DDI Version: 9 (or higher)
Driver Attributes: Final Retail
 Driver Date/Size: 6/1/2005 19:06:44, 3494400 bytes
      WHQL Logo'd: Yes
  WHQL Date Stamp: n/a
              VDD: YOK
         Mini VDD: vtmini.sys
    Mini VDD Date: 6/1/2005 19:06:54, 227712 bytes
Device Identifier: {D7B71FE6-7004-11CF-1B7B-4E13A0C2CB35}
        Vendor ID: 0x1106
        Device ID: 0x3344
        SubSys ID: 0x33441849
      Revision ID: 0x0001
      Revision ID: 0x0001
      Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
 Deinterlace Caps: n/a
         Registry: OK
     DDraw Status: Enabled
       D3D Status: Enabled
       AGP Status: Enabled
DDraw Test Result: Not run
 D3D7 Test Result: Not run
 D3D8 Test Result: Not run
 D3D9 Test Result: Not run
Sound Devices
            Description: C-Media Wave Device
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID: PCI\VEN_1106&DEV_3059&SUBSYS_97611849&REV_60
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: cmuda.sys
         Driver Version: 5.12.0001.0049 (English)
      Driver Attributes: Final Debug
            WHQL Logo'd: No
          Date and Size: 5/12/2005 14:21:08, 1332544 bytes
            Other Files:
        Driver Provider: C-Media Inc.
         HW Accel Level: Full
              Cap Flags: 0xF5F
    Min/Max Sample Rate: 100, 100000
Static/Strm HW Mix Bufs: 33, 32
 Static/Strm HW 3D Bufs: 33, 32
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: Yes, Yes
   I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): Yes
               Registry: OK
      Sound Test Result: Not run
Sound Capture Devices
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x41
           Format Flags: 0xCC0
DirectMusic
        DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
     DLS Version: 1.00.0016.0002
    Acceleration: n/a
           Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
                  C-Media Wave Device, Software (Kernel Mode), Output, DLS, Internal
                  Microsoft Ses E                  Microsoft GS Wavetable SW Synth [Benzetimli], Hardware (Not Kernel Mode), Output, No DLS, Internal
        Registry: OK
DirectInput Devices
      Device Name: Fare
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Klavye
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
Poll w/ Interrupt: No
         Registry: OK
USB Devices
+ USB Kök Hub
| Vendor/Product ID: 0x1106, 0x3038
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 4/13/2008 21:45:37, 59520 bytes
| Driver: usbd.sys, 11/22/2001 15:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ HID Klavye Ayg| Vendor/Product ID: 0x046D, 0xC315
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 4/14/2008 18:40:51, 14592 bytes
| Driver: kbdclass.sys, 4/14/2008 18:40:50, 24704 bytes
+ Terminal Server Klavye Sürücüsü
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 4/14/2008 19:01:17, 40840 bytes
+ Microsoft USB Wheel Mouse Optical
| Vendor/Product ID: 0x045E, 0x0040
| Matching Device ID: hid\vid_045e&pid_0040
| Service: mouhid
| Driver: mouclass.sys, 4/14/2008 18:33:21, 23168 bytes
| Driver: mouhid.sys, 11/22/2001 15:00:00, 12160 bytes
+ Terminal Server Fare Sürücüsü
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.6311)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Yerel A
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 99.1 GB
Total Space: 152.6 GB
File System: NTFS
      Model: SAMSUNG SP1604N
      Drive: E:
      Model: Generic STEALTH DVD SCSI CdRom Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (Turkish), 4/13/2008 21:40:46, 62976 bytes
System Devices
     Name: VIA CPU to AGP2.0/AGP3.0 Controller
Device ID: PCI\VEN_1106&DEV_B198&SUBSYS_00000000&REV_00\3&267A616A&0&08
   Driver: C:\WINDOWS\system32\DRIVERS\VIAAGP1.SYS, 5.01.0000.3442 (English), 7/2/2003 04:42:00, 27904 bytes
     Name: PCI standart host CPU köprüsü
Device ID: PCI\VEN_1106&DEV_7314&SUBSYS_00000000&REV_00\3&267A616A&0&07
   Driver: n/a
Device ID: PCI\VEN_1106&DEV_4314&SUBSYS_00000000&REV_00\3&267A616A&0&04
   Driver: n/a
     Name: VIA/S3G UniChrome Pro IGP
Device ID: PCI\VEN_1106&DEV_3344&SUBSYS_33441849&REV_01\4&354AEA31&0&0008
   Driver: C:\WINDOWS\system32\DRIVERS\vtmini.sys, 6.14.0010.0226 (English), 6/1/2005 19:06:54, 227712 bytes
   Driver: C:\WINDOWS\system32\vtdisp.dll, 6.14.0010.0226 (English), 6/1/2005 19:06:44, 3494400 bytes
   Driver: C:\WINDOWS\system32\vticd.dll, 6.14.0010.0226 (English), 6/1/2005 19:09:14, 1875968 bytes
   Driver: C:\WINDOWS\help\VTDspChs.hlp, 5/24/2005 02:36:10, 21495 bytes
   Driver: C:\WINDOWS\help\VTDspCht.hlp, 5/24/2005 02:36:10, 22757 bytes
   Driver: C:\WINDOWS\help\VTDspJpn.hlp, 5/24/2005 02:36:10, 22880 bytes
   Driver: C:\WINDOWS\help\VTDspKor.hlp, 5/24/2005 02:36:10, 24087 bytes
   Driver: C:\WINDOWS\help\VTDspWst.hlp, 5/24/2005 02:36:08, 231153 bytes
   Driver: C:\WINDOWS\help\VTDspTha.hlp, 5/24/2005 02:36:10, 19348 bytes
   Driver: C:\WINDOWS\help\VTDspWs2.hlp, 5/24/2005 02:36:10, 170426 bytes
   Driver: C:\WINDOWS\help\VTGm2WST.hlp, 1/11/2005 06:34:16, 141071 bytes
   Driver: C:\WINDOWS\help\VTGm2CHS.hlp, 1/11/2005 06:34:18, 17574 bytes
   Driver: C:\WINDOWS\help\VTGm2CHT.hlp, 1/11/2005 06:34:18, 17536 bytes
   Driver: C:\WINDOWS\help\VTGm2JPN.hlp, 1/11/2005 06:34:16, 16594 bytes
   Driver: C:\WINDOWS\help\VTGm2KOR.hlp, 1/11/2005 06:34:16, 19233 bytes
   Driver: C:\WINDOWS\help\VTGm2Tha.hlp, 1/11/2005 06:34:16, 18524 bytes
   Driver: C:\WINDOWS\help\VTGm2Ws2.hlp, 1/11/2005 06:34:16, 104672 bytes
   Driver: C:\WINDOWS\help\VTin2wst.hlp, 12/8/2004 09:03:06, 61136 bytes
   Driver: C:\WINDOWS\help\VTin2chs.hlp, 12/8/2004 09:03:06, 9295 bytes
   Driver: C:\WINDOWS\help\VTin2cht.hlp, 12/8/2004 09:03:06, 9280 bytes
   Driver: C:\WINDOWS\help\VTin2jpn.hlp, 12/8/2004 09:03:06, 9670 bytes
   Driver: C:\WINDOWS\help\VTin2kor.hlp, 12/8/2004 09:03:06, 10217 bytes
   Driver: C:\WINDOWS\help\VTIn2Tha.hlp, 12/8/2004 09:03:06, 9285 bytes
   Driver: C:\WINDOWS\help\VTin2ws2.hlp, 12/8/2004 09:03:06, 49083 bytes
   Driver: C:\WINDOWS\help\VTovlwst.hlp, 3/18/2005 17:29:34, 70288 bytes
   Driver: C:\WINDOWS\help\VTovlchs.hlp, 1/11/2005 03:23:58, 10559 bytes
   Driver: C:\WINDOWS\help\VTovlcht.hlp, 1/11/2005 03:23:58, 10515 bytes
   Driver: C:\WINDOWS\help\VTovljpn.hlp, 1/11/2005 03:23:58, 10533 bytes
   Driver: C:\WINDOWS\help\VTovlkor.hlp, 1/11/2005 03:23:58, 11385 bytes
   Driver: C:\WINDOWS\help\VTOvlTha.hlp, 1/11/2005 03:23:58, 8660 bytes
   Driver: C:\WINDOWS\help\VTOvlWs2.hlp, 1/11/2005 03:23:58, 50925 bytes
   Driver: C:\WINDOWS\system32\VTDisply.cfg, 5/24/2005 02:36:36, 63489 bytes
   Driver: C:\WINDOWS\system32\VTDispl2.cfg, 5/24/2005 02:36:38, 56619 bytes
   Driver: C:\WINDOWS\system32\VTDispl3.cfg, 5/24/2005 02:36:38, 52037 bytes
   Driver: C:\WINDOWS\system32\VTDisply.dll, 2.00.0058.0523 (English), 5/24/2005 02:36:30, 581632 bytes
   Driver: C:\WINDOWS\system32\VTGamma2.dll, 2.00.0021.0308 (English), 3/11/2005 17:45:46, 360448 bytes
   Driver: C:\WINDOWS\system32\VTGamma2.cfg, 1/11/2005 06:34:40, 48406 bytes
   Driver: C:\WINDOWS\system32\VTGama_2.cfg, 1/11/2005 06:34:40, 35496 bytes
   Driver: C:\WINDOWS\system32\VTInfo2.dll, 2.00.0026.0308 (English), 3/11/2005 17:43:08, 262144 bytes
   Driver: C:\WINDOWS\system32\VTInfo2.cfg, 12/8/2004 02:12:38, 44076 bytes
   Driver: C:\WINDOWS\system32\VTovrlay.dll, 2.00.0023.0308 (English), 3/11/2005 17:36:40, 397312 bytes
   Driver: C:\WINDOWS\system32\VTovrlay.cfg, 10/8/2004 06:21:52, 60337 bytes
   Driver: C:\WINDOWS\system32\VTOvrly2.cfg, 10/8/2004 06:21:52, 33451 bytes
   Driver: C:\WINDOWS\system32\VTTimer.exe, 2.00.0001.0307 (English), 3/8/2005 03:33:28, 53248 bytes
   Driver: C:\WINDOWS\system32\VModes.exe, 1.00.0000.0002 (English), 4/18/2005 11:15:08, 40960 bytes
   Driver: C:\WINDOWS\system32\VTTrayp.exe, 2.00.0036.0308 (English), 3/11/2005 17:33:28, 147456 bytes
   Driver: C:\WINDOWS\system32\VTTrayp.cfg, 1/11/2005 07:27:42, 47889 bytes
   Driver: C:\WINDOWS\system32\VTTrayP2.cfg, 1/11/2005 07:27:42, 34954 bytes
   Driver: C:\WINDOWS\help\VTtpwst.hlp, 1/11/2005 07:33:24, 106088 bytes
   Driver: C:\WINDOWS\help\VTTPChs.hlp, 1/11/2005 07:33:24, 14728 bytes
   Driver: C:\WINDOWS\help\VTTPCht.hlp, 1/11/2005 07:33:24, 14406 bytes
   Driver: C:\WINDOWS\help\VTTPJpn.hlp, 1/11/2005 07:33:24, 13609 bytes
   Driver: C:\WINDOWS\help\VTTPKor.hlp, 1/11/2005 07:33:24, 16213 bytes
   Driver: C:\WINDOWS\help\VTTPTha.hlp, 1/11/2005 07:33:24, 11044 bytes
   Driver: C:\WINDOWS\help\VTTPWs2.hlp, 1/11/2005 07:33:24, 88693 bytes
     Name: VIA Standard PCI to ISA Bridge
Device ID: PCI\VEN_1106&DEV_3227&SUBSYS_00000000&REV_00\3&267A616A&0&88
   Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (Turkish), 4/14/2008 18:40:22, 37376 bytes
     Name: VIA Standard Host Bridge
Device ID: PCI\VEN_1106&DEV_3208&SUBSYS_00000000&REV_00\3&267A616A&0&03
   Driver: n/a
     Name: VIA SATA RAID Controller
Device ID: PCI\VEN_1106&DEV_3149&SUBSYS_31491849&REV_80\3&267A616A&0&78
   Driver: C:\WINDOWS\system32\DRIVERS\viamraid.sys, 5.01.2600.0430 (English), 6/20/2005 18:53:20, 60928 bytes
     Name: VIA USB Genel Host Denetleyicisi
Device ID: PCI\VEN_1106&DEV_3104&SUBSYS_31041849&REV_86\3&267A616A&0&84
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/13/2008 21:45:35, 30208 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/13/2008 21:45:36, 143872 bytes
   Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (Turkish), 4/14/2008 19:00:27, 74240 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 21:45:37, 59520 bytes
   Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/14/2008 19:00:19, 7168 bytes
     Name: VIA Compatable Fast Ethernet BaDevice ID: PCI\VEN_1106&DEV_3065&SUBSYS_30651849&REV_78\3&267A616A&0&90
   Driver: C:\WINDOWS\system32\DRIVERS\fetnd5.sys, 2.66.0000.0290 (English), 8/17/2001 22:13:08, 27165 bytes
     Name: C-Media AC97 Audio Device
Device ID: PCI\VEN_1106&DEV_3059&SUBSYS_97611849&REV_60\3&267A616A&0&8D
   Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.5512 (Turkish), 4/14/2008 19:00:20, 4096 bytes
   Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.5512 (Turkish), 4/14/2008 19:00:58, 129536 bytes
   Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.5512 (Turkish), 4/13/2008 22:16:36, 141056 bytes
   Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/13/2008 21:45:14, 60160 bytes
   Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/13/2008 22:19:42, 146048 bytes
   Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.5512 (Turkish), 4/13/2008 21:45:16, 49408 bytes
   Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/14/2008 19:00:58, 23552 bytes
   Driver: C:\WINDOWS\system32\drivers\cmuda.sys, 5.12.0001.0049 (English), 5/12/2005 14:21:08, 1332544 bytes
   Driver: C:\WINDOWS\system32\udaprop.dll, 1.00.0002.0002 (English), 4/24/2003 13:29:08, 32768 bytes
   Driver: C:\WINDOWS\system32\cmuda.dll, 5.12.0001.0162 (Chinese), 5/12/2005 11:23:28, 167936 bytes
   Driver: C:\WINDOWS\system32\cmirmdrv.dll, 2/18/2003 18:26:28, 28672 bytes
   Driver: C:\WINDOWS\system32\cmirmdrv.exe, 1.00.0000.0016 (English), 4/23/2004 15:02:10, 233472 bytes
   Driver: C:\WINDOWS\system\cmids3d.dll, 1.00.0000.0000 (Chinese), 4/29/2002 15:04:40, 917504 bytes
   Driver: C:\WINDOWS\system\cmicnfg.cpl, 1.00.0041.0016 (Chinese), 9/3/2004 12:31:00, 2596864 bytes
   Driver: C:\WINDOWS\system\SmWizard.exe, 1.00.0002.0003 (English), 2/17/2004 10:51:56, 1458176 bytes
   Driver: C:\WINDOWS\system32\a3d.dll, 4.12.0001.2008 (English), 11/23/2001 12:08:20, 712704 bytes
   Driver: C:\WINDOWS\system32\Audio3D.dll, 4.12.0001.2008 (English), 11/23/2001 12:08:20, 712704 bytes
     Name: VIA Rev 5 or later USB Universal Host Controller
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_30381849&REV_81\3&267A616A&0&83
   Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.5512 (English), 4/13/2008 21:45:35, 20608 bytes
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_30381849&REV_81\3&267A616A&0&82
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_30381849&REV_81\3&267A616A&0&81
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_30381849&REV_81\3&267A616A&0&80
Device ID: PCI\VEN_1106&DEV_2314&SUBSYS_00000000&REV_00\3&267A616A&0&02
   Driver: n/a
Device ID: PCI\VEN_1106&DEV_1314&SUBSYS_00000000&REV_00\3&267A616A&0&01
   Driver: n/a
     Name: VIA Bus Master IDE Denetleyici
Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_05711849&REV_06\3&267A616A&0&79
   Driver: C:\WINDOWS\system32\DRIVERS\viaide.sys, 1.00.0001.0001 (English), 4/13/2008 21:40:31, 5376 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.5512 (Turkish), 4/13/2008 21:40:29, 24960 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.5512 (English), 4/13/2008 21:40:30, 96512 bytes
Device ID: PCI\VEN_1106&DEV_0314&SUBSYS_00000000&REV_00\3&267A616A&0&00
   Driver: n/a
DirectX Components
   ddraw.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:17 279552 bytes
 ddrawex.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:17 27136 bytes
   dxapi.sys: 5.01.2600.0000 English Final Retail 11/22/2001 15:00:00 10496 bytes
    d3d8.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:17 1179648 bytes
 d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:17 8192 bytes
    d3d9.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:17 1689088 bytes
   d3dim.dll: 5.01.2600.0000 English Final Retail 11/22/2001 15:00:00 436224 bytes
d3dim700.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:17 824320 bytes
 d3dramp.dll: 5.01.2600.0000 English Final Retail 11/22/2001 15:00:00 590336 bytes
   d3drm.dll: 5.01.2600.0000 English Final Retail 11/22/2001 15:00:00 350208 bytes
  d3dxof.dll: 5.01.2600.0000 English Final Retail 11/22/2001 15:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 11/22/2001 15:00:00 34816 bytes
   dplay.dll: 5.00.2134.0001 Turkish Final Retail 11/22/2001 15:00:00 33040 bytes
  dplayx.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:18 229888 bytes
dpmodemx.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:18 23552 bytes
 dpwsock.dll: 5.00.2134.0001 English Final Retail 11/22/2001 15:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:18 57856 bytes
dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:36 29696 bytes
  dpnsvr.exe: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:36 17920 bytes
   dpnet.dll: 5.03.2600.6311 English Final Retail 11/2/2012 05:02:32 375296 bytes
dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:58:59 3072 bytes
 dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/14/2008 18:58:59 3072 bytes
 dpvoice.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:18 211968 bytes
dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:36 83456 bytes
  dpvvox.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:18 116736 bytes
  dpvacm.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:18 21504 bytes
dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:18 35328 bytes
dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:18 60928 bytes
dpserial.dll: 5.00.2134.0001 Turkish Final Retail 11/22/2001 15:00:00 53520 bytes
  dinput.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:17 160768 bytes
 dinput8.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:17 183808 bytes
   dimap.dll: 5.01.2600.0000 English Final Retail 11/22/2001 15:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 Turkish Final Retail 11/22/2001 15:00:00 394752 bytes
     joy.cpl: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:57 69120 bytes
   gcdef.dll: 5.01.2600.0000 Turkish Final Retail 11/22/2001 15:00:00 76800 bytes
     pid.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:23 35328 bytes
  dsound.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:18 367616 bytes
dsound3d.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:18 1293824 bytes
  dswave.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:18 19456 bytes
   dsdmo.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:18 181248 bytes
dsdmoprp.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:18 71680 bytes
  dmusic.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:18 104448 bytes
  dmband.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:17 28672 bytes
dmcompos.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:17 61440 bytes
   dmime.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:17 181248 bytes
dmloader.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:17 35840 bytes
 dmstyle.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:18 105984 bytes
 dmsynth.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:18 103424 bytes
dmscript.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:17 82432 bytes
  system.dll: 1.01.4322.2503 English Final Retail 7/11/2013 15:42:17 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 12/18/2012 13:41:42 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 12/18/2012 13:41:42 577024 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 12/18/2012 13:41:43 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 12/18/2012 13:41:43 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 12/18/2012 13:41:43 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 12/18/2012 13:41:43 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 12/18/2012 13:41:41 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 12/18/2012 13:41:42 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 12/18/2012 13:41:41 223232 bytes
   dx7vb.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:18 619008 bytes
   dx8vb.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:18 1227264 bytes
 dxdiagn.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:18 2113536 bytes
   mfc40.dll: 4.01.0000.6151 English Beta Retail 9/18/2010 09:53:23 954368 bytes
   mfc42.dll: 6.02.8081.0000 English Final Retail 2/8/2011 16:34:00 978944 bytes
 wsock32.dll: 5.01.2600.5512 Turkish Final Retail 4/14/2008 19:00:28 23040 bytes
amstream.dll: 6.05.2600.5512 English Final Retail 4/14/2008 19:00:16 70656 bytes
 devenum.dll: 6.05.2600.5512 Turkish Final Retail 4/14/2008 19:00:17 59904 bytes
  dxmasf.dll: 6.04.0009.1133 Turkish Final Retail 4/14/2008 19:00:18 498742 bytes
mciqtz32.dll: 6.05.2600.5512 Turkish Final Retail 4/14/2008 19:00:20 35328 bytes
 mpg2splt.ax: 6.05.2600.6333 English Final Retail 1/2/2013 09:48:58 148992 bytes
   msdmo.dll: 6.05.2600.5512 English Final Retail 4/14/2008 19:00:21 14336 bytes
  encapi.dll: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:19 20480 bytes
    qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
    qcap.dll: 6.05.2600.5512 Turkish Final Retail 4/14/2008 19:00:23 192512 bytes
     qdv.dll: 6.05.2600.5512 Turkish Final Retail 4/14/2008 19:00:23 279040 bytes
    qdvd.dll: 6.05.2600.6169 Turkish Final Retail 11/3/2011 18:28:30 386560 bytes
   qedit.dll: 6.05.2600.6404 Turkish Final Retail 6/4/2013 10:22:56 562688 bytes
qedwipes.dll: 6.05.2600.5512 English Final Retail 4/13/2008 20:21:32 733696 bytes
  quartz.dll: 6.05.2600.6333 Turkish Final Retail 1/2/2013 09:48:58 1292288 bytes
 strmdll.dll: 4.01.0000.3938 Turkish Final Retail 8/26/2009 11:15:36 247326 bytes
 iac25_32.ax: 2.00.0005.0053 English Final Retail 4/14/2008 19:00:57 199680 bytes
  ir41_32.ax: 4.51.0016.0003 English Final Retail 4/14/2008 19:00:57 848384 bytes
 ir41_qc.dll: 4.30.0062.0002 English Final Retail 4/14/2008 19:00:20 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 4/14/2008 19:00:20 338432 bytes
 ir50_32.dll: 5.2562.0015.0055 English Final Retail 4/14/2008 19:00:20 755200 bytes
 ir50_qc.dll: 5.00.0063.0048 English Final Retail 4/14/2008 19:00:20 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 4/14/2008 19:00:20 183808 bytes
   ivfsrc.ax: 5.10.0002.0051 English Final Retail 4/14/2008 19:00:57 154624 bytes
mswebdvd.dll: 6.05.2600.5857 Turkish Final Retail 8/5/2009 12:00:10 204800 bytes
      ks.sys: 5.03.2600.5512 Turkish Final Retail 4/13/2008 22:16:36 141056 bytes
  ksproxy.ax: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:58 129536 bytes
  ksuser.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:20 4096 bytes
  stream.sys: 5.03.2600.5512 Turkish Final Retail 4/13/2008 21:45:16 49408 bytes
mspclock.sys: 5.03.2600.5512 Turkish Final Retail 4/13/2008 21:39:50 5376 bytes
   mspqm.sys: 5.01.2600.5512 Turkish Final Retail 4/13/2008 21:39:52 4992 bytes
 mskssrv.sys: 5.03.2600.5512 Turkish Final Retail 4/13/2008 21:39:52 7552 bytes
  swenum.sys: 5.03.2600.5512 Turkish Final Retail 4/13/2008 21:39:53 4352 bytes
   mstee.sys: 5.03.2600.5512 Turkish Final Retail 4/13/2008 21:39:50 5504 bytes
   ipsink.ax: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:58 16384 bytes
mpeg2data.ax: 6.05.2600.5512 English Final Retail 4/14/2008 19:00:57 118272 bytes
  ndisip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 21:46:22 10880 bytes
streamip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 21:46:22 15232 bytes
msvidctl.dll: 6.05.2600.5512 Turkish Final Retail 4/14/2008 19:00:22 1428992 bytes
    slip.sys: 5.03.2600.5512 English Final Retail 4/13/2008 21:46:24 11136 bytes
nabtsfec.sys: 5.03.2600.5512 English Final Retail 4/13/2008 21:46:26 85248 bytes
ccdecode.sys: 5.03.2600.5512 English Final Retail 4/13/2008 21:46:24 17024 bytes
  vbisurf.ax: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:57 30208 bytes
   msyuv.dll: 5.03.2600.5908 English Final Retail 11/27/2009 20:12:59 17920 bytes
 kstvtune.ax: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:58 61952 bytes
   ksxbar.ax: 5.03.2600.5512 English Final Retail 4/14/2008 19:00:58 43008 bytes
 kswdmcap.ax: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:58 91136 bytes
vfwwdm32.dll: 5.01.2600.5512 Turkish Final Retail 4/14/2008 19:00:28 54272 bytes
wstcodec.sys: 5.03.2600.5512 English Final Retail 4/13/2008 21:46:24 19200 bytes
wstdecod.dll: 5.03.2600.5512 Turkish Final Retail 4/14/2008 19:00:28 50688 bytes
DirectShow Filters
WDM Akar VBI Codec:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.5512
CC 0x00200000,2,1,,5.03.2600.5512
WST Codec,0x00200000,1,1,,5.03.2600.5512
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.6333
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.5512
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.6333
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.6333
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.6333
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.6333
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6333
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.6333
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.06.0000.0052
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.6333
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6333
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.6333
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.5512
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.6333
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.6333
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.6169
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.6333
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.5512
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.6333
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.5512
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4504
File writer,0x00200000,1,0,qcap.dll,6.05.2600.5512
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.6169
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.6169
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.6333
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.6333
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.5512
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.6404
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.6404
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.5512
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.6169
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6333
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.6333
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.6333
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.6333
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.6333
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.5512
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.6333
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.6333
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.6333
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.5512
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.6333
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.6333
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM AkTee/Sink-to-Sink Dönü0x00200000,1,1,,5.03.2600.5512
WDM AkMicrosoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Çekirdek GS Wavetable Birle0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DLS Sentezleyici,0x00200000,1,1,,5.03.2600.5512
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.5512
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.5512
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.6333
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.5512
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.5512
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.5512
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.5512
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.6333
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6333
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.6333
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.6333
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.6333
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.6333
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.6333
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.6333
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.6333
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.6333
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.6333
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.6333
Audio Capture Sources:
C-Media Wave Device,0x00200000,0,0,qcap.dll,6.05.2600.5512
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.6333
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.6333
WDM AkC-Media Wave Device,0x00200000,2,2,,5.03.2600.5512
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.5512
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM AkMicrosoft Çekirdek Dalga Ses Kar0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,
Encrypt/Tag,0x00200000,0,0,encdec.dll,
XDS Codec,0x00200000,0,0,encdec.dll,
Audio Renderers:
C-Media Wave Device,0x00200000,1,0,quartz.dll,6.05.2600.6333
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.6333
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.6333
DirectSound: C-Media Wave Device,0x00200000,1,0,quartz.dll,6.05.2600.6333
WDM AkC-Media Wave Device,0x00200000,8,2,,5.03.2600.5512
BDA Receiver Component:
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.5512
Arkadaş ım bu sistem dökümü seninse ki olmasada önemli değil 32 bit işletim sistemi kullanıp da bir sürü ıvır zıvır program yüklüyse bilgisayar ında birde o ıvır zıvır programlar açılışta çalıştır a ayarlıysa makinan geç açılır tavsiyem başngıç ayarla rını değiltir eklentileri sil yada devre dışı yap kesin çözüm istersen Windows 8.1 pro kur office 2013 makinan yeniden doğar
öncelikle şunu sorayım pc nin boot ayarı harddisk olarak mı şeçili eğer cd yada flopyy yada usb seçil ise sırasıyla bunları dener enson harddiskten yükleme yapar bu da açılmada süreyi uzatır.ben format sonrası boot seçeneğini cd den hdd ye almayı unuttum yaklaşık 25 sn gecikmeli açılıyordu pc
Buderusss
