Bu motor servo mu step mi?
13 Ocak 2012
Merhaba
Bu motor hakkında bilgisi olan var mıdır? Nasıl sürülebilir? Yapacağım projelerde kullanmak istiyorum bu konularda yardımcı olursanız sevinirim.
Seri numarasından arattım ama pek bilgi bulamadım.
Siemens 1AD5006-1BS90-PB​
    185.9 KB · Görüntüleme: 164
    245.7 KB · Görüntüleme: 184
Merhaba
Siemens 1AD5006-1BS90-PB Motor Servo Bir Motordur.
Kaynak (Siemens Resmi Web Sitesinden Alıntıdır) :
The 1AD5006-1BS90-PB is an asynchronous servo motor that is well-suited for a variety of industrial applications. It has a continuous torque rating of 6 Nm and a peak torque rating of 12 Nm. It is also very efficient, with an efficiency rating of up to 90%.
The 1AD5006-1BS90-PB is an asynchronous motor, which means that it does not rely on a physical connection between the rotor and the stator to create torque. Instead, the rotor is induced to rotate by a rotating magnetic field in the stator. This makes asynchronous motors more efficient and reliable than step motors.
Servo motors are typically used in closed-loop control systems, where the position of the motor is constantly monitored and adjusted to match a desired setpoint. Step motors, on the other hand, are typically used in open-loop control systems, where the motor is simply commanded to move a certain number of steps.
The 1AD5006-1BS90-PB is a high-performance servo motor that is well-suited for a variety of industrial applications. It is a good choice for applications that require high torque, efficiency, and reliability.
Cevap için çok teşekkür ederim. peki nasıl sürebilirim bu motoru. hangi sürücü kartı ile?
Emir Mahmut
