Elektrik Sembolleri Autocad
Klavyeah
28 Ağu 2006
Abbreviations 16000-1 DWF DWG
Symbols - Site Work 16000-2 DWF DWG
Symbols - Single Line 16000-3 DWF DWG
Symbols - Rewiring and Demolition 16000-4 DWF DWG
Symbols - Receptacles 16000-5 DWF DWG
Symbols - General 16000-6 DWF DWG
Symbols - General 16000-7 DWF DWG
Symbols - General 16000-8 DWF DWG
Symbols - Fire Alarm System 16000-9 DWF DWG
Symbols - Telephone System 16000-10 DWF DWG
Symbols - Television System 16000-11 DWF DWG
Symbols - Radio System 16000-12 DWF DWG
Symbols - Nurse Call System 16000-13 DWF DWG
Symbols - Miscellaneous Alarm Systems 16000-14 DWF DWG
Symbols - Miscellaneous Communication Systems 16000-15 DWF DWG
Symbols - Code One System 16000-16 DWF DWG
General Notes 16000-17 DWF DWG
Notes: Demolition System 16000-18 DWF DWG
Typical Floor Slab Penetration Detail 16115-1 DWF DWG
Emergency Generator Elevation 16208-1 DWF DWG
Emergency Generator Exhaust 16208-2 DWF DWG
Emergency Generator Fuel Piping 16208-3 DWF DWG
Generator Control Panel 16208-4 DWF DWG
Remote Derangement Panel 16208-5 DWF DWG
Signal Manhole Details 16402-1 DWF DWG
Structural Details for Handholes 16402-2 DWF DWG
Power Manhole Details 16402-3 DWF DWG
Manhole Hardware 16402-4 DWF DWG
Duct Bank Details 16402-5 DWF DWG
Manhole Grounding Details 16402-6 DWF DWG
Isolated Power Panel (Typical) 16675-1 DWF DWG
Receptacle Assembly (Typical) 16675-2 DWF DWG
Schematic Wiring Diagram PBPU's, Style A1 or A2 16685-1 DWF DWG
Schematic Wiring Diagram PBPU's, Style B1 or B2 16685-2 DWF DWG
General Notes for PBPU's Styles A1 and A2, Type B1 or B2 16685-3 DWF DWG
Prefabricated Bedside Patient Unit, Style C, C1 and C2 16685-4 DWF DWG
General Notes for PBPU's Style C, C1, or C2 16685-5 DWF DWG
Nurses Console 16761-1 DWF DWG
Nurses Console 16761-2 DWF DWG
Schematic Wiring Diagram - Nurses Console 16761-3 DWF DWG
Control Equipment Diagram 16761-4 DWF DWG
Elevation "A" - Code One Alarm Clock, Ground Fault Meter and Receptacle 16761-5 DWF DWG
Clock, Code One Alarm, and Ground Fault Meter for use with Nurse Consoles 16761-6 DWF DWG
Nurse Call and Code One Call Unit 16761-7 DWF DWG
"Code One" Call Unit (Type 3A) 16761-8 DWF DWG
Code One Call Unit (Type 3B) 16761-9 DWF DWG
Code One Annuciator Panel 16761-10 DWF DWG
Nurse Call Staff Station 16761-11 DWF DWG
Typical Intensive Care Systems Elevation Diagram 16761-12 DWF DWG
I.V. Track Grounding Details 16761-13 DWF DWG
Gas Failure Alarm 16761-14 DWF DWG
Color Coding of Outlet Boxes for Each System
  • National-CAD-Standard-Details-Electrical.rar
    3 MB · Görüntüleme: 151
öncelikle teşekkür ederim ama bunlar hem ingilizce hemde tek tek link halinde onalrın türkçe olanlarını bulabilirsen sevinirim ;)
megep sitesinde ac ve dc makina var sana yardımcı olur inş
slm autocad öğrenmeye yeni başladım elektikle ilgili bana örnek bir bina veya kat projeleri lazım arkadşlar.Elinde projeler bulunan arkadaşar bana gönderebilirse sevinirim veya nerden temn edebilirim.
mrosleon
