Klavyeah
- Katılım
- 28 Ağu 2006
- Mesajlar
- 269
- Puanları
- 1
- Yaş
- 39
Elektrik Sembolleri Autocad
Abbreviations 16000-1 DWF DWG
Symbols - Site Work 16000-2 DWF DWG
Symbols - Single Line 16000-3 DWF DWG
Symbols - Rewiring and Demolition 16000-4 DWF DWG
Symbols - Receptacles 16000-5 DWF DWG
Symbols - General 16000-6 DWF DWG
Symbols - General 16000-7 DWF DWG
Symbols - General 16000-8 DWF DWG
Symbols - Fire Alarm System 16000-9 DWF DWG
Symbols - Telephone System 16000-10 DWF DWG
Symbols - Television System 16000-11 DWF DWG
Symbols - Radio System 16000-12 DWF DWG
Symbols - Nurse Call System 16000-13 DWF DWG
Symbols - Miscellaneous Alarm Systems 16000-14 DWF DWG
Symbols - Miscellaneous Communication Systems 16000-15 DWF DWG
Symbols - Code One System 16000-16 DWF DWG
General Notes 16000-17 DWF DWG
Notes: Demolition System 16000-18 DWF DWG
Typical Floor Slab Penetration Detail 16115-1 DWF DWG
Emergency Generator Elevation 16208-1 DWF DWG
Emergency Generator Exhaust 16208-2 DWF DWG
Emergency Generator Fuel Piping 16208-3 DWF DWG
Generator Control Panel 16208-4 DWF DWG
Remote Derangement Panel 16208-5 DWF DWG
Signal Manhole Details 16402-1 DWF DWG
Structural Details for Handholes 16402-2 DWF DWG
Power Manhole Details 16402-3 DWF DWG
Manhole Hardware 16402-4 DWF DWG
Duct Bank Details 16402-5 DWF DWG
Manhole Grounding Details 16402-6 DWF DWG
Isolated Power Panel (Typical) 16675-1 DWF DWG
Receptacle Assembly (Typical) 16675-2 DWF DWG
Schematic Wiring Diagram PBPU's, Style A1 or A2 16685-1 DWF DWG
Schematic Wiring Diagram PBPU's, Style B1 or B2 16685-2 DWF DWG
General Notes for PBPU's Styles A1 and A2, Type B1 or B2 16685-3 DWF DWG
Prefabricated Bedside Patient Unit, Style C, C1 and C2 16685-4 DWF DWG
General Notes for PBPU's Style C, C1, or C2 16685-5 DWF DWG
Nurses Console 16761-1 DWF DWG
Nurses Console 16761-2 DWF DWG
Schematic Wiring Diagram - Nurses Console 16761-3 DWF DWG
Control Equipment Diagram 16761-4 DWF DWG
Elevation "A" - Code One Alarm Clock, Ground Fault Meter and Receptacle 16761-5 DWF DWG
Clock, Code One Alarm, and Ground Fault Meter for use with Nurse Consoles 16761-6 DWF DWG
Nurse Call and Code One Call Unit 16761-7 DWF DWG
"Code One" Call Unit (Type 3A) 16761-8 DWF DWG
Code One Call Unit (Type 3B) 16761-9 DWF DWG
Code One Annuciator Panel 16761-10 DWF DWG
Nurse Call Staff Station 16761-11 DWF DWG
Typical Intensive Care Systems Elevation Diagram 16761-12 DWF DWG
I.V. Track Grounding Details 16761-13 DWF DWG
Gas Failure Alarm 16761-14 DWF DWG
Color Coding of Outlet Boxes for Each System
