Elektronik Devreler İçin Simülasyon
sust
21 May 2006
programın resmi:
Kullanışlı Olması Dileği İle
Programı ve ingilizde kullanım kılavuzunu ekten indirebilirsiniz.
Circuit Shop
Circuit Shop
allows you to design, simulate and learn about digital and analog electronic circuits. Circuit Shop is an easy to use graphical CAD tool to allow simple digital and analog electronic circuits to be constructed and simulated.
Circuit Shop includes:
  • Drawing tools to construct simple electronic circuit schematics consisting of digital and analog devices such as ICs, logic gates, flip-flops, op amps, dependent sources, transistors, resistors, batteries, etc.
  • A tutorial which teaches basic analog and digital electronic concepts.
  • Digital circuit design and analysis capability using digital sources, logic gates, flip-flops, timers, sequence generators, digital displays, ICs and digital oscilloscopes.
  • Analog circuit design and simulation capability to perform DC analysis and sinusoidal steady state analysis and frequency response. Frequency response includes magnitude, Bode, phase, dB and group delay plots.
  • Custom symbol support. A simple paint toolkit allows text, lines, ovals and rectangles to be added as circuit annotations or used to create custom symbols.
  • A printable version of Circuit Shop's on-line help file can be downloaded (see below). The fully indexed PDF document consists of a reference manual and a basic electronics tutorial.
Keywords: Keywords: circuit, tutorial, electronics, basic, schematic, custom symbol, design, analysis, simulation, optimize, electric, electrical, educational, digital, analog, logic gate, flip flop, timer, sequence generator, digital oscilloscope, diode, LED, transistor, resistor, capacitor, inductor, transformer, hybrid-pi model, op amp, dependent source, switch, SPST, SPDT, DPDT, DPDT, lamp, DC, AC, sinusoidal steady state, frequency response, Bode, phase, dB, group delay, IC, CAD, drawing, paint, toolkit
  • Circuit-Shop.rar
    3 MB · Görüntüleme: 18
Acaba bu Programın adı nedir ? veya boyutu nedir. bunlar hakkında da bilgi verirmisiniz.
eyw kanka güzel çalışma ayrıca EleCtRox_ program 2.1mb ;) emeğe saygı;)
Program sadece devrelerin çizimini yapmanızı sağlıyor simulasyon yada analiz gibi özellikleri yok
sadece çizim amaclı kullananabilirsiniz lisans gerektirmiyor
Peki sadece schematic mi yoksa PCB de çizebiliyor mu...
Vista için uyumlumudur..? Malum vista sıkıntılıda...
sorun yok vistada guncellemeleriniz tam ise vistada sikinti yasanmiyor
proteus öneririm
bu program visio dur arkadaşlar kullanımı da kolaydır.Öneririm
kivanc0zsoy
