Eplan electric p.8 2.4 kurulumu
30 Ocak 2025
Set Eplan;
Copy the license files from a folder EPLAN in the folder C: \ User \ Public \ Eplan \ Common \;
Remove driver protection HL Hasp in Control Panel. Uninstalling the program;
Set a new driver haspdinst.exe-install (see readme.html);
5189.reg runs the file and add data to the register;
Can start the installation driver Multikey - emulator folder Release \ MultiKey64 \ install.cmd;
We include a test mode in Windows 7 x64 running the program dseo13b.exe and the radio button for "Enable Test Mode". By the way, just note that there is provided a reverse action "Disable Test Mode", the cut-off test mode;
Restart the computer. In the corner you will see "Test Mode Windows 7 v 7600;
Start the animation dseo13b.exe;
Add a digital signature for the driver Multikey. To do this, select the "Sign a System File" and enter the file name, including the full path C: \ Windows \ System32 \ Drivers \ multikey.sys.
Restart the computer;
Run Eplan 2.0 and enjoy his work.
For normal installation, you must disable UAC.
Böyle yazıyor. Yardımcı olur musunuz ? Nasıl kurcam ?
nasıl kurcam Allah rızası için bir yardım edin
Kaveli arda
Şu anda çevrimiçi üye yok.
