derwer
- 5 Eki 2010
- 20
- 1
- Yaş
- 34
pıc16f84a ve ds1621 ıle röle kontrolu olan ısı kontrol devresinin pıcbasic'inde hatalar yaşıyoruz ds6121 ısı ölçümünü göremiyoruz nasıl yapabiliriz yardım edermisiniz?
ds1621.dll ısıs gore ayarlıyıp çalıştırdık genede ısısdede ölçümde sensör devamlı 0 derece göstermekte
Kod:
'**************************************************************[/B] [B]
'* Name : PIC-Temp.BAS *
'* Author : F. San *
'* Date : 10.10.2003 *
'* Notes : Temperature control, -55°C to +125°C *
'* : Using the PIC16F84 and DS1621 temp.sens *
@ device
Define LCD_DREG PORTB[/B] [B]
Define LCD_DBIT 0
Define LCD_EREG PORTB
Define LCD_EBIT 4
Define LCD_RSREG PORTB
Define LCD_RSBIT 5
Temp var word 'DS1621 Temperature [/B] [B]
TempLo var byte 'DS1621 Temp. Low byte
TempHi var byte 'DS1621 Temp. High byte
TempX var byte 'misc. storage variables
TempNeg var byte ' "
SetTemp var bit ' "
i2c_sda var PortA.2 'DS1621 Data pin
i2c_scl var PortA.3 'DS1621 Clock pin
RelayOut var PortA.0 'Relay output pin
Sw_SET var PortA.1 'Set temp. switch
Sw_DEC var PortB.6 'Dec temp. switch
Sw_INC var PortB.7 'Inc temp. switch
TrisA = %11110[/B] [B]
PortA = 0
TrisB = %11000000
PortB = 0
SetTemp = 0
EEPROM 0,[22,0] 'Default temp. 22.0°C, stored at EEprom location 0 and 1[/B] [B]
Read 0, TempHi 'Get Temp. High.byte from EEprom address 0
Read 1, TempLo 'Get Temp. Low.byte from EEprom address 1
Main:[/B] [B]
gosub Read_Temp
gosub Chk_RelayOut
gosub Chk_Switches
if not settemp then gosub Disp_Temp
pause 100
goto Main
Read_Temp:[/B] [B]
i2cwrite i2c_sda,i2c_scl,$90,$ac,[0] 'Access Config [ACh]
Pause 1
I2CWrite i2c_sda, i2c_scl,$90,[$ee] 'Start Convert T [EEh]
Pause 1
I2CRead i2c_sda, i2c_scl, $90,$aa,[Temp],Error 'Read Temperature [AAh]
TempNeg = " "
TempX = Temp.HighByte
if TempX >= 128 then
TempNeg = "-"
TempX = 256 - (TempX + Temp.7)
endif
return
Disp_Temp: [/B] [B]
Lcdout $fe, 1, TempNeg, Dec TempX,".", Dec (Temp.7/1*50/10),223,"C Role:",dec Relayout
Lcdout $fe, $c0, "(",SDec TempHi,".",Dec(TempLo/1*50/10),223,"C) Y. BICEN"
return
Disp_SetTemp: [/B] [B]
Lcdout $fe,1,TempNeg, Dec TempX,".", Dec (Temp.7/1*50/10),223,"C Role:",dec Relayout
Lcdout $fe, $c0, sDec TempHi,".",Dec(TempLo/1*50/10),223,"C Y. BICEN"
return
Error:[/B] [B]
Lcdout $fe, 1, "HATA", $fe, $C0, "TEKRAR DENE"
goto Main
Chk_RelayOut:[/B] [B]
if Temphi < 128 then 'Set Temp = pos.temp.
if temp.highbyte < 128 then 'Temp = pos.temp
if temp.highbyte = temphi then
if temp.7 < Templo then
RelayOut = 1
else
RelayOut = 0
endif
else
if temp.highbyte < temphi then
RelayOut = 1
else
RelayOut = 0
endif
endif
else 'Set Temp = neg.temp.
RelayOut = 1
endif
if temp.highbyte > 128 then 'Temp = neg.temp
if temp.7 > Templo then
RelayOut = 1
else
RelayOut = 0
endif
else
if temp.highbyte > temphi then
RelayOut = 0
else
RelayOut = 1
endif
endif
else 'Set Temp = pos.temp.
RelayOut = 0
endif
endif
return
Chk_Switches: [/B] [B]
if Sw_SET = 0 then
if SetTemp then
gosub Disp_Temp
else
gosub Disp_SetTemp
endif
while SW_SET = 0 : wend
if SetTemp then
Write 0, TempHi 'Store TempHi to EEprom location 0
Write 1, TempLo 'Store TempLo to EEprom location 1
endif
settemp = not Settemp
endif
if not settemp then return[/B] [B]
if Sw_DEC = 0 then [/B] [B]
if TempHi > 128 then
if Temphi > 201 then
TempLo = TempLo ^ 1 'invert state of TempLo
if TempLo = 1 then TempHi = TempHi - 1
endif
else
TempLo = TempLo ^ 1
endif
endif
if Sw_INC = 0 then[/B] [B]
if TempHi < 128 then
if TempHi < 125 then
TempLo = TempLo ^ 1
if TempLo = 0 then TempHi = TempHi + 1
endif
else
TempLo = TempLo ^ 1
endif
endif
gosub Disp_SetTemp
return
end
