Isı Kontrolde Sorun Çözümü yardım.
derwer
5 Eki 2010
pıc16f84a ve ds1621 ıle röle kontrolu olan ısı kontrol devresinin pıcbasic'inde hatalar yaşıyoruz ds6121 ısı ölçümünü göremiyoruz nasıl yapabiliriz yardım edermisiniz?
Kod:
'**************************************************************[/B] [B]
'*  Name    : PIC-Temp.BAS                                    *
'*  Author  : F. San                                          *
'*  Date    : 10.10.2003                                      *
'*  Notes   : Temperature control, -55°C to +125°C            *
'*          : Using the PIC16F84 and DS1621 temp.sens         *
@ device
Define LCD_DREG PORTB[/B] [B]
Define LCD_DBIT 0
Define LCD_EREG PORTB
Define LCD_EBIT 4
Define LCD_RSREG PORTB
Define LCD_RSBIT 5
Temp        var word    'DS1621 Temperature   [/B] [B]
TempLo      var byte    'DS1621 Temp. Low byte
TempHi      var byte    'DS1621 Temp. High byte
TempX       var byte    'misc. storage variables
TempNeg     var byte    ' "
SetTemp     var bit     ' "
i2c_sda     var PortA.2 'DS1621 Data pin
i2c_scl     var PortA.3 'DS1621 Clock pin
RelayOut    var PortA.0 'Relay output pin
Sw_SET      var PortA.1 'Set temp. switch
Sw_DEC      var PortB.6 'Dec temp. switch
Sw_INC      var PortB.7 'Inc temp. switch
TrisA     =    %11110[/B] [B]
PortA = 0
TrisB     =    %11000000
PortB = 0
SetTemp = 0
EEPROM 0,[22,0]  'Default temp. 22.0°C, stored at EEprom location 0 and 1[/B] [B]
Read 0, TempHi   'Get Temp. High.byte from EEprom address 0
Read 1, TempLo   'Get Temp. Low.byte from EEprom address 1
Main:[/B] [B]
   gosub Read_Temp
   gosub Chk_RelayOut
   gosub Chk_Switches
   if not settemp then gosub Disp_Temp
   pause 100
goto Main
Read_Temp:[/B] [B]
   i2cwrite i2c_sda,i2c_scl,$90,$ac,[0]   'Access Config [ACh]
   Pause 1
   I2CWrite i2c_sda, i2c_scl,$90,[$ee]    'Start Convert T [EEh]
   Pause 1
   I2CRead i2c_sda, i2c_scl, $90,$aa,[Temp],Error  'Read Temperature [AAh]
   TempNeg = " "
   TempX = Temp.HighByte
   if TempX >= 128 then
      TempNeg = "-"
      TempX = 256 - (TempX + Temp.7)
   endif
return
Disp_Temp:    [/B] [B]
   Lcdout $fe, 1, TempNeg, Dec TempX,".", Dec (Temp.7/1*50/10),223,"C  Role:",dec Relayout
   Lcdout $fe, $c0, "(",SDec TempHi,".",Dec(TempLo/1*50/10),223,"C) Y. BICEN"
return
Disp_SetTemp: [/B] [B]
   Lcdout $fe,1,TempNeg, Dec TempX,".", Dec (Temp.7/1*50/10),223,"C  Role:",dec Relayout
   Lcdout $fe, $c0, sDec TempHi,".",Dec(TempLo/1*50/10),223,"C Y. BICEN"
return
Error:[/B] [B]
   Lcdout $fe, 1, "HATA", $fe, $C0, "TEKRAR DENE"
goto Main
Chk_RelayOut:[/B] [B]
   if Temphi < 128 then 'Set Temp = pos.temp.
      if temp.highbyte < 128 then 'Temp = pos.temp
         if temp.highbyte = temphi then
            if temp.7 < Templo then
               RelayOut = 1
            else
               RelayOut = 0
            endif
         else
            if temp.highbyte < temphi then
               RelayOut = 1
            else
               RelayOut = 0
            endif
         endif
      else  'Set Temp = neg.temp.
         RelayOut = 1
      endif
      if temp.highbyte > 128 then 'Temp = neg.temp
            if temp.7 > Templo then
               RelayOut = 1
            else
               RelayOut = 0
            endif
         else
            if temp.highbyte > temphi then
               RelayOut = 0
            else
               RelayOut = 1
            endif
         endif
      else  'Set Temp = pos.temp.
         RelayOut = 0
      endif
   endif
return
Chk_Switches: [/B] [B]
   if Sw_SET = 0 then
      if SetTemp then
         gosub Disp_Temp
      else
         gosub Disp_SetTemp
      endif
      while SW_SET = 0 : wend
      if SetTemp then
         Write 0, TempHi     'Store TempHi to EEprom location 0
         Write 1, TempLo     'Store TempLo to EEprom location 1
      endif
      settemp = not Settemp
   endif
   if not settemp then return[/B] [B]
   if Sw_DEC = 0 then [/B]    [B]
      if TempHi > 128 then
         if Temphi > 201 then
            TempLo = TempLo ^ 1 'invert state of TempLo
            if TempLo = 1 then TempHi = TempHi - 1
         endif
      else
         TempLo = TempLo ^ 1
      endif
   endif
   if Sw_INC = 0 then[/B]    [B]
      if TempHi < 128 then
         if TempHi < 125 then
            TempLo = TempLo ^ 1
            if TempLo = 0 then TempHi = TempHi + 1
         endif
      else
         TempLo = TempLo ^ 1
      endif
   endif
      gosub Disp_SetTemp
return
end
ds1621.dll ısıs gore ayarlıyıp çalıştırdık genede ısısdede ölçümde sensör devamlı 0 derece göstermekte
murat0938
