okan59
- 28 Şub 2019
- 5
- 1
Türk firması olan A Plus Plastik dünyada tek olan yeni ürün geliştirdi. Lighted Buoy (Işıklı Şamandıra) olarak adlandırılan şamandıranın içinde güneş paneli ve led var. Denize bırakılan duba güneş enerjisi ile şarj ettiği piliyle 10-12 saat verimli şekilde led ışıklarını aydınlatıyor.
Web Sitesi: Lighted Buoy
Teknik Özellikleri:
LIGHT SPECIFICATIONS
Ligt Source
7 smd 28/35 leds
Lumens Output
100 lumens
Available LED Colors
White,Green,Red,Blu,RGB
Light Mode Options
1-2+Natutical Millle*Vriaewhit LED
Visible Range
Color&Brightness Settings
Horizontal Output (degrees)
360 Degree
Vertical Divergence (degrees)
100-180 Deg.Various whit Mounting
LED Life Expectancy (hours)
100,000 hrs
SOLAR SPECIFICATIONS
Solar Module Type
Multicrystalline or Policrystalline
Power (watts)
4w
Solar Module Efficiency(%)
16-17 %
Battery Type
Li –ion
Battery Size
1 pcs li-ion
Battery Capacity (mAh)
2200 mA
Nominal Voltage(v):
3,7v
PHYSICAL SPECIFICATIONS
Body Material
Polietilen
Water Proof Rating
IP68
Mounting
Fits on Piling or Flat Surfaces 8inc Diameter
Height
600 mm
Width
200 mm
Weight
2Kg
CE Compliant & 2 Years Warranty
Luminous floating marker buoy has 2 years warranty and CE Compliant
ELECTRICAL SPECIFICATIONS
Circuit Protection
Integrated
Nominal Voltage (v)
3,7 v
Autonomy (hours)
7,8 hrs
Temperature Range
-10 to 70 c
Teknik Özellikleri:
Ligt Source
7 smd 28/35 leds
Lumens Output
100 lumens
Light Mode Options
Visible Range
360 Degree
100,000 hrs
Solar Module Type
Power (watts)
4w
16-17 %
Battery Type
Li –ion
Battery Size
1 pcs li-ion
2200 mA
Nominal Voltage(v):
3,7v
Body Material
Polietilen
Water Proof Rating
IP68
Mounting
Height
600 mm
Width
200 mm
Weight
2Kg
Circuit Protection
Integrated
Nominal Voltage (v)
3,7 v
Autonomy (hours)
7,8 hrs
Temperature Range
-10 to 70 c
