Mach4 çıktı - mach4 released ͏͏͏͏͏͏͏͏͏͏͏͏͏͏***
sparkk
11 Tem 2012
Arkadaşlar bir çoğumuzun beklediği mach4 tamamen çıkmak üzere.şimdilik hobiciler için demosunu yayınladıkları bu sürümdeki asıl amacın yeni arayüz ve özelliklere alışılmasını sağlamak olduğunu söylüyorlar.
2 farklı sürüm olarak gelecek olan programın basit olano 200$ gibi mach3ün yerini alması , profesyonel olan ise daha çok işletmeler için 1000-2000$ arası bir fiyat belirlemişler.
Demo için http://www.machsupport.com/wp-content/uploads/2014/04/Mach4Hobby Installer-1723.exe
MACH4 Demo Released!
We have released a Demo version of Mach4 Hobby. This Demo does Not include motion control.
About the Demo: The purpose of this Demo is to give users a look at Mach4 Hobby and the ability to test the screen designer. The screen designer will be nearly identical in all versions of Mach4 and this version allows for the layout of GUI’s. Scripting examples will be included in the next Demo. Many Motion control plug-ins (software driver for motion control boards) are not 100% complete. We are working with many different groups to help them complete and test their plug-ins for Mach4. A version with motion control will be released depending on the time to make improvements from the feedback received from this version.
Mach4 Information: Mach4 is our newest version of CNC motion control software. While the core software is completed, it will take time to complete the software plug-ins that allow Mach4 to communicate with specific hardware devices. OEM’s and equipment manufacturers that have committed resources to developing their software plug-ins, will be the first to take advantage of Mach4’s benefits. Much of the development of the plug-ins is completed by the manufacturer of the hardware.
For this reason, Mach3 will continue to be sold for a year or more, while the number of compatible hardware devices is expanded through plug-in development.
Mach4 is completely new software and has less than 1% of the programming code in common with Mach3. It was written from the ground up to be expandable, flexible, and extremely responsive for use with very large files on any operating system; including Windows, Apple, and Linux. While there was only one version of Mach3, Mach4 will be offered in different versions (not including the many customized OEM versions).
Please read the tabs below for more information.
Screen Shots of the Standard Mach4 Hobby User Interface. Tab controls are used in Mach4 to switch quickly between different screens. Users may modify the standard screen or create a new tab that contains the buttons, graphics, and indicators they need.
hemen indirdim
arayüz bence mach3 den şahane olmuş
grafiksel olarak ucun dolaştığını gördüğümüz ekran gayet başarılı düzgünce olmuş
ama motor ayarları falan aktif değil demo olduğu için.
bence başarılı
mach3 öğrenemeden 4 çıktı :)
şimdi bunu öğrenemeden 5 çıkar
koşarak bile yetişemiyoruz ,
4 de ne yenilikler ne gibi kolaylıklar var acaba
olmuş olmuş. analog sistemden digitale geçişde olmuş sanırım. modbus bilmeyen kalmayacak bu gidişle :)
Mach3 ün altyapisi tamamen alinmis mi? arayüz tasarlamak eskisi gibi mümkün mü?
Hardware Interface de USB davasi tam olarak cözülmeden Mach ürünleri hobi olarak kalmak durumunda.
..Hardware Interface de USB davasi tam olarak cözülmeden Mach ürünleri hobi olarak kalmak durumunda.
Boş versene , cnc dünyasını bu günlere taşıyan en önemli yazılımlardan biridir.
O kadar ucuzu da EMC2 hariç olmadı.
Kaç milyon tanesi çalışıyor sanayi dünyasında haberin var mı ?
Usb çok da sorun değil.
Nasıl çözüleceği forumda bir çok yerde tartışıldı.
Ayrıca paralel port öyle kolay terk edilecek bir şey değil.
Yeni nesil denilenlerin bazılarına yeniden konmaya başlandı.
Ayrıca pci express to paralel de olur
Eski laptoplara nur yağdı
Eski masaüstülerde bedavaya yakın almayanı dövüyorlar...
Fiyatı da çok artmadı 200 dolar , yakında tanışırız inşa Allah..
http://www.machsupport.com/software/mach4/
Birşey sorabilirmiyim. Bu fabrikalardaki otomasyon yazılımlarını arayüzleri neden böyle kırmızı, yeşil,mavi gibi 98'den kalma yapılıyor. Mühendislik ile alakalı birşey mi? hani yeşil=geç, kırmızı=dur gibi gibi birşey mi? Bununla ilgili bir standart filan mı var?
Dikkat çekmesi gereken şeyler zıt renklerde olur.
Sıcak / soğuk dedikleri spektrumdaki birbirinden uzak dalga boyları yan yana geldiklerinde göz tarafından çok rahat fark edilir.
Ne demek rahat , kötü ortamlarda - az ışık olduğunda - çok ışık olduğunda - gözü az gören olsa da kısmi renk körlüğü sorunları olsa da ... ayırt edilmeleri kolay olur.
Koyu renklerin özellikle siyahın ve de pütürlü yüzeyin çooook özel bir yeri var.
Araba göğüsleri bir kaç zırtabozunkiler hariç kesin siyahtır.
Yoksa cama yansır , siyah olunca da yansır ama çook az ve beyin , etkisini yokmuş gibi yapabilir.
Bunu önlemenin yolu var ama bu sefer o dizayn aerodinamik olmaz....
Bu etkiyi bilse de bilmese de bir kaç deneme yanılma ile sanki profesörü gibiymiş gibi bulur hazırlayanlar.
yani bu benim öylesine salladığım bir şey , belki diğer arkadaşlarımız farklı yorumlar getirirler.
Bir ara makina firmasında çalışmıştım. İnşaat makinaları yapıyorlar. Yazılım arayüzü var PLC'yi yöneten. Sarı kırmızı dahil olmayan renk yoktu. 25'in üzerinde renk kesin vardı. Belki kullanıcı kılavuzunda anlatırken işi kolaylaştırmak içindir. Bu makinaların başına hep uzman koymuyorlar. Önce sarı, sonra kırmızı, sonra pembe gibisinden ezber sistemle üretimde kullanılabilir.
Bahsettiğim makina beton üretim makinasıydı. Çimento, kum, su vs.yi belirli oranda karışrıyor. Gerçi renkli bile olsa yine daha düzgün tasarımlar yapılabilir. Bence sadece mühendisler yapıyor diye böyle. Tasarımcılarda dahil edilse sürece alternatif ama yine renk ve hatta ikon kolaylığı olan arayüzler çıkabilir. Atıyorum tüm dünyada stop, start ikonu sabittir.
Bazı standartların dışına çıkmak kullanımı ya da verimi düşürür. Bugün siz mavi kabarcıklı tuşlar olsun güzel görünüyor diyebilirsiniz,başkası onu görmeye tahammül edemez.
Hocanın ısrarla söylediği G M kodlarını öğrenin bunun gibi. G90 yerine yerine K90 yazıp bunu universal olarak tezgahların %90unda kullanılabilir dersen, kırmızı yerine de mavi kullanabilirsin. çoğu ekran dizaynını değişiik kullananlarımız var,çoğu zaman da bu kuralları atlıyoruz, daha afilli olsun diye, aslında yapmamak lazım.
2bin liralık televizyonunda aynı yeşil/kırmızı ,200liralık su sebilinin arkasında da aynı yeşil kırmızı bulunması bundandır. yanlış takılmadıysa, musluğun mavi işaretli kısmından sıcak su gelmesini beklemeyiz. gibi.
mustafatlanm
