TB5MAA
- 29 Tem 2011
- 15
- 1
- Yaş
- 44
Kod:
'* Name : UNTITLED.BAS *
'* Author : [A.T.A] *
'* Notice : Copyright (c) 2011 ata] *
'* : All Rights Reserved *
'* Date : 02.06.2011 *
'* Version : 1.0 *
'* Notes : *
PORTA=0:PORTB=0
TRISB=%11111111 'PortB.0 giriş diğerleri çıkış yapıldı.
TRISA=%00000000 'A portu tamamı çıkış yapıldı.
@ DEVICE pic16F628A 'işlemci 16F628
@ DEVICE pic16F628A, WDT_OFF 'Watch Dog timer açık
@ DEVICE pic16F628A, PWRT_ON 'Power on timer açık
@ DEVICE pic16F628A, PROTECT_OFF 'Kod Protek kapalı
@ DEVICE pic16F628A, MCLR_OFF 'MCLR pini kullanılıyor.
@ DEVICE pic16F628A, INTRC_OSC_NOCLKOUT 'Dahili osilatör kullanılacak
CMCON=7 '16F628 de komparatör pinleri iptal hepsi giriş çıkış
SIFRE VAR WORD
RAKAM var WORD
TEMP VAR WORD
BASKA VAR WORD
ZAMAN VAR WORD
SURE VAR word
SAYI VAR BYTE
DURUM VAR BYTE
BIRLER VAR BYTE
ONLAR VAR BYTE
YUZLER VAR BYTE
BINLER VAR BYTE
CIK VAR BIT
SYMBOL CIKIS1=PORTA.1
SYMBOL CIKIS2=PORTA.2
SYMBOL CIKIS3=PORTA.3
symbol CIKIS4=PORTA.4
SYMBOL CIKIS5=PORTA.5
SYMBOL ISD =PORTA.6
SYMBOL ROLE=PORTB.7
SYMBOL VALDAT=PORTB.0
SYMBOL BUZZER=PORTA.7
DATA @ 0,1,4,5,3
PAUSE 200
CLEAR
read 0,SAYI:PAUSE 10
IF SAYI=$FF THEN
SIFRE=1453
GOSUB SIFREYAZ
endIF
READ 0,BINLER
READ 1,YUZLER
READ 2,ONLAR
READ 3,BIRLER
SIFRE=BINLER*1000+YUZLER*100+ONLAR*10+BIRLER
'--------------------------------------ANA--------------------------------------
BASLA:
PASWORD: RAKAM=0:GOSUB SIFREAL
IF CIK=1 THEN BITIR
IF RAKAM=7676 THEN
SIFRE=1453
GOSUB SES2
GOSUB SES1
GOSUB SES2:gosub ses1
GOSUB SIFREYAZ
GOTO ROLEKONTROL
ENDIF
IF RAKAM=SIFRE THEN
GOSUB SES2:pause 50
GOSUB SES1:pause 50
GOSUB SES1:gosub ses1
GOTO ROLEKONTROL
ENDIF
ROLEKONTROL: GOSUB ALBILGI
IF CIK=1 THEN BITIR
IF SAYI=12 THEN ACMA '#
IF SAYI=11 THEN KAPAT '*
gosub ses2
GOTO BASLA
ACMA:
GOSUB ALBILGI
IF CIk=1 THEN BITIR
IF SAYI=0 THEN
gosub ses3
GOSUB EXIT
GOTO BASLA
ENDIF
DURUM=PORTA
IF SAYI=1 THEN
IF durum.1=0 THEN
GOSUB SES1
PORTA=DURUM | %00000001
goto ROLEKONTROL
ENDIF
ENDIF
IF SAYI=2 THEN
IF durum.2=0 THEN
GOSUB SES1:GOSUB SES1
PORTA=DURUM | %00000010
goto ROLEKONTROL
ENDIF
ENDIF
IF SAYI=9 THEN '#9
GOSUB SIFREAL
GOSUB SES1:gosub ses2
IF CIK=1 THEN BITIR
IF RAKAM=SIFRE THEN
GOSUB SES1:GOSUB SES1:GOSUB SES2
GOSUB SIFREAL
IF CIK=1 THEN BITIR
SIFRE=RAKAM
gosub SIFREYAZ
ENDIF
ENDIF
GOTO ROLEKONTROL
KAPAT: GOSUB ALBILGI
IF CIK=1 THEN BITIR
durum=PORTA
IF SAYI=0 THEN
GOSUB SES3
PORTA=DURUM & %11000000 '*0
ENDIF
IF SAYI=1 THEN
IF durum.1=1 THEN
GOSUB SES2
PORTA=DURUM & %11111110
goto ROLEKONTROL
ENDIF
ENDIF
IF SAYI=2 THEN
IF durum.2=1 THEN
GOSUB SES2:GOSUB SES2
PORTA=DURUM & %11111101
goto ROLEKONTROL
ENDIF
ENDIF
SIFREAL: GOSUB ALBILGI
IF CIK=1 THEN RETURN
RAKAM=SAYI*1000
GOSUB ALBILGI
RAKAM=RAKAM+SAYI*100
GOSUB ALBILGI
RAKAM=RAKAM+SAYI*10
GOSUB ALBILGI
RAKAM=RAKAM+SAYI
RETURN
ALBILGI:
SURE=0:ZAMAN=0
WHILE VALDAT=0
SURE=SURE+1
PAUSEus 270
IF SURE=65500 THEN
CIK=1:RETURN
ENDIF
WEND
SAYIAL: SAYI=0
WHILE VALDAT=1
SAYI.0=PORTA.4
SAYI.1=PORTA.3
SAYI.2=PORTA.2
SAYI.3=PORTA.1
WEND
IF SAYI=10 THEN SAYI=0
RETURN
SIFREYAZ:TEMP=SIFRE
BINLER=TEMP DIG 3
YUZLER=TEMP DIG 2
ONLAR =TEMP DIG 1
BIRLER=TEMP DIG 0
WRITE 0,BINLER:PAUSE 10
WRITE 1,YUZLER:PAUSE 10
WRITE 2,ONLAR :PAUSE 10
WRITE 3,BIRLER:PAUSE 10
RETURN
SES1: SOUND BUZZER,[110,12]:pause 30:RETURN
SES2: SOUND BUZZER,[95,12] :pause 30:RETURN
SES3: SOUND BUZZER,[85,25] :Pause 30:RETURN
BITIR: GOSUB EXIT:GOTO BASLA:RETURN
EXIT : SURE=0
CIK=0
RAKAM=0
LOW ROLE
LOW ISD
gosub ses2
gosub ses2
GOSUB SES3
GOSUB SES3
RETURN
End
Bu yazılıma son halini verdiğimde algoritmanın şu şekilde
1453 ilk açma şifresi 1numaralı röle için
1071 ilk kapama şifresi 1numaralı röle için
1453#yeni şifre 1numaralı röle için açma şifresi değişti
1071#yeni şifre 1numaralı röle için kapama şifresi değişti
aynı işlemi 2numaralı röle içinde farklı şifrelerle yapmak istiyorum.
Yardımcı olacak arkadaşlara teşekkürler.
sistemin çalışma algoritması
bir numaralı röleyi açmak için 1453 şifresi tuşlanır.
bir numaralı röleyi kapatmak için 1076 şifresi tuşlanır.
iki numaralı röleyi açmak için 1571 şifresi tuşlanır.
iki numaralı röleyi kapatmak için 1929 şifresi tuşlanır.
sistem ilk programlandığında yukarıdaki şifre değerleriyle çalışmaktadır. Siz bu şifreleri aşağıdaki şekilde değiştirebilirsiniz.
bir numaralı rölenin açma şifresini 1453#yeni bir şifre
bir numaralı rölenin kapama şifresini 1071#
yeni bir şifrer=#000000
iki numaralı rölenin açma şifresini 1571#yeni bir şifre
iki numaralı röleninb kapama şifresini 1929#yeni bir şifre
yani kısaca eski şifreyi girip kare tuşuna bastığımızda sistem bizden yeni şifreyi bekler yeni şifrenin geçerli süre zarfında girilmesiyle sistemin şifresi değişir. Birdahaki şifre değiştirme işlemi enson sizin belirlemiş olduğunuz şifrenin sonuna # simgesi eklenerek yapılır. örneğin 1453#6666 girdiniz ve 1453 olan şifreyi 6666 olarak değiştirdiniz. Bir daha şifre değiştirmek isterseniz 6666#yeni bir şifre şeklinde değiştirirsiniz.
sistemin şifreleriyle ilgili bir unutma problemi yaşadığınızda 7676* olarak belirlenmiş olan bir master şifre vardır. Bu şifreyi girmenizle sistem de yaptığınız tüm değişiklikler sıfırlanarak bizden almış olduğunuz ilk değerlere döner. Buradan hareketle tekrar istediğiniz değişiklikleri yapabilirsiniz.
sistemde yapılan tüm işlemler size bir sesli uyarı ile bildirilir.
örneğin 1 numaralı rölenin şifresini tuşladık şifre doğru ise röle çeker ve beep sesi çıkar eğer şifre yanlış ise kalın bir beep sesiyle sizi uyarır. şifre değiştirme menüsüne gelindiğinde bir meleodi üretir ve yeni şifrenin girilmesine mütakiben şifre değişme işleminin başarılı olması durumunda onay sesi üretir. Başarısız olması durumunda kalın bir sesle uyarı verir.
Bu kodları yazdım çalıştıramadım hata verdi microcodestdio....bu yazılımda hata var ama bulamadım ....
