Siemens'in sitesinden indirdiğim dosya da neden .exe yok?
mathcover
13 Kas 2007
cok tesekkür ederim arkadaslar yanliz bir sorum olacak, ben resmi siteden bir klasör dowload ettim ama icinde exe dosyasi yok yani kurulumu yapamadim
Greater Performance, more Panels, increased Productivity
SIMATIC WinCC flexible is the innovative HMI software under Windows for all machine-oriented and process-oriented applications of the machine, series machine and plant construction. The engineering software enables the integrated configuration of all HMI operator devices ranging from the Micro Panel up to the PC-based visualization -all of this with the highest level of configuration efficiency.
The new SIMATIC WinCC flexible 2007 version comes up with a couple of interesting innovations
On this page:
Performance optimization in the Engineering
Central user administration with SIMATIC LOGON
New operator interfaces and Soft-PLC SIMATIC WinAC MP
Funcion expansions for the smaller Panels
New communication possibilities
Performance Increase for the Engineering
WinCC flexible 2007 2007 contains extensive optimizations, which further increase the performance of the Engineering. The new version, for example, reduces the generation time of a project by avoiding complete generation runs as far as possible in favor of a delta compilation.
Furthermore, if there are multiple devices in a project, each one can be generated separately.
In the integrated mode, WinCC flexible and STEP7 now work even faster, for example when opening an HMI project from STEP7 or when creating, copying or deleting an HMI device.
The WinCC flexible setup as well was made faster thanks to an optimized installation scope. The user now only installs those programs, which he or she needs for the work with WinCC flexible.
Burada anlatilmak istenen nedir arkadaslar ingilizcesi olan bir meslekdas yardimci olabilir mi ??
exe lisanslı olmadıgından yok .Çünkü Parayla satıldığı İçin demo koynuşlar siteye..
hubbig
