TB6560 dip switch ve limit switch e-stop ayarları acil yardım
arkadaslar konum dağılmadı mı boyle fıkrı olan baska kımse yokmu
Kartın standart tb6560 kartı olmadığı için cevap bulamıyorsun..
Bu arada son yaptığım araştırmaya göre tb6560 input sinyali maximum 20khz imiş.. böyle olunca yüksek hız imkansız..
[QUOTE = "nbozkurt16, post: 725 759, member: 351 899"] Hello my brothers and sisters brother
At the end of the engine are talking about a lot mach3 tb6560 my card I was reading threads in the forum to give press movement
I'm not finished, but unfortunately I could not find this problem issues ICs AC's not gonna unfortunately somewhere hıc
My problem with limit switches, e-stop connection locations and dip switch settings I Are Br detailed pictures to the card if you can help yield of ideas glad I thank you in advance
In the above the card 4l j3-5l the pin has a pin j10-12l pin J11
Ekli dosyayı görüntüle 38327
Ekli dosyayı görüntüle 38328[/QUOTE]
You can use J10, its pins are as follows(from left to right):
GND
Pin 13
Pin 12
Pin 11
Pin 10
The GND is common for all of them. Simply connect your limit switch, one end to the GND and the other to one of the pins as you want
yenil
