- 13 Ocak 2007
- 2,267
- 1,866
- Yaş
- 47
- In the case of an offline/online comparison one project is online in a CPU and the other project is offline on a data medium.
- In the case of an offline/offline comparison both projects are on a data medium.
To make an offline/offline comparison you must first enable the Reference projects view (see Fig. 1).
Fig. 1
Now the Reference projects view is available.
Fig. 2
You call the Compare function via the menu.
Fig. 3
Then you can run the comparison between two locally located projects. For this the reference project must also be in the Compare editor offline.
Fig. 4
https://support.industry.siemens.co...cts-offline-in-the-tia-portal-?dti=0&lc=en-WW
