Troid Legrand 260 92/93/94/94
kkkmert
4 Eki 2009
Ajustment of I∆n
Ajustment : ayarlama fakat burda I:Akım ama üçgen (∆) işareti ve n ne anlama geliyor acaba.
Arkadaşlar bu konuda bilgisi olan arkadaşımız yok mu birde bu troid ayarı nasıl olmalı
Arkadaşlar şu an çeviri yapıyorum ama I∆n bu ne demek bilen var mı acaba?
Ajustment of I∆n
Ayarlamak ve I∆n
Test buton
Reset buton
Voltage presence indicator (green)
Gerilim varlığı göstergesi (yeşil)
RC relay tripping indicator (red)/relay-coil connection interruption (flashing red)
röle-bobin bağlantı kesintisi (kırmızı yanıp sönen) RC röle açma göstergesi (kırmızı)
Time delay setting
Zaman ayarı gecikme
Selection of I∆n rating
Seçim ve kataogori
Selection of reset mode
Reset modu seçimi
Selection of output relay status.
Çıkış rölesi durumu seçimi.
Indication of fault current in %I∆n
Position of the contacts when the device is switched on.
Caution: When there is on coil/relay connection the contact closes between terminals 18 and 17 regardless of the position set on the selector switch.Also if there is a power cut,the contact closes between 18-17 opening the switch.
Caution: When there is on coil/relay connection the contact closes between terminals 18 and 19 regardless of the position set on the selector switch.
Reduce the distance between coil and relay to a minimum.
Use screened or braided cables for their connection.
Do not place the coil/real connection cables paralel to the powe conductors.
Do not install coil and relay close to sources of intense electromagnetic fields (big transformans).
Programming the reset mode.
MANUAL (Man)=Alarm status continues until the operator actuates the RESET btton.
AUTOMATIC 8Aut)=When the alarm is trpped,the device automatically resets making three attempts(1 every 60 seconds).If after 3 attemps there is no reset,the device goes to a final alarm status and has to be reset manually.
N.B.
Resettings is impossible for a fault current>50% of programmed I∆n
Ajustment of I∆n
motorun üzerinde yazıyorsaki eğer, motor üçgen bağlanacak demektir
troıd kaçak akım rolesi 2 parçadan oluşur 1 bobin 2 röle role üzerindeki ayarlar hassasiyet ayarlaıdı yani mili amper ayarlarını tesisatı durumuna göre ayarlanacak bazı yerlerde çok hassas ayarlanırsa problem çıkıyor..
vecihi01
