video yu aciklayabilirmisniz acaba?
amant
4 Tem 2012
Tam olarak ne yapiyor yada nerede hata yapiyor merak ettim.
Western Power Blows fuses - YouTube
The problem is the muffler in the generator station is going bad. That and the watts are set too high for the local current to handle. Putting in a few more klystron tubes will fix things, along with tying maggots like yourself to the top of the pole before energizing.madisonelectronic in reply to ThePPPTrainAndCarFan (Show the comment) 10 months ago --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------this can be caused even by a short circuited 1hp motor, it happened on my street, someone hacked the line and put the motor directly from the post so he didnt pay electric bill, but one day the motor shortcircuited causing the near fuses like this one blow, the company checked didnt found anything so they tried to put the fuss back on and they blowd again and again and again, then they checked everyhouse in the phase till they found the motor, they charged like 50k usd penaltySmopuiM in reply to madisonelectronic (Show the comment) 10 months ago--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------must have a shorted transformer somewhere, I came home to no power one day they came out and seen the fuse blown and said the transformer was probably shorted he put a new fuse up and it blew like that and I thought a cannon just blew up over my head, they had to come out and put a new transformer on the poleLouManChu66 1 year ago-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Ben yüksek gerilimden anlamam ama yorumlarda yazana göre, hatta kısa devre olabilir sonucu çıkıyor, yorumların birinde " bizimde başımıza gelmişti kısa devre olabilir diye hattı kontrol ettik birşey yoktu fakat yine sigorta patlatıyordu en son bu hattan beslenen tüm evleri kontrol ettik bir tanesi kaçak çekmiş ve kaçak çektiği yerde bağlı olan bir hplık motor kısa devre olmuştu" sebep buymuş elemana 50 000 dolar para cezası verilmiş. Bazı yorumlardada trafolarda problem olabilir diye yazılmış, genel kanaat hatta kısa devre olduğu yönünde ayrıca adamın tekrar tekrar sigorta patlatıp zevke eldiğini :) aptallık ettiğini söylüyorlar, artık Türkiye deki arkadaşlarımızın başına benzer birşey geldiyse onlarında yorumlarını görelim, bilen tecrübe eden biri cevaplasa daha iyi olur.
Video batı Avustralya da çekilmiş. Görevli arkadaş ayırıcıyı kapatıyor. Birinci fazda sorun yok. İkinci fazı kapatınsa sigorta atıyor.
Hatta o fazda kısadevre olma ihtimali yüksek. Devrede arızalı bir trafo da olabilir.
Sayın Karaapak ın çevirisini yaptığı yorumda 1hp lik motorun kısadevre olmasından bahsedilmiş.Kısa devreden kasıt ortafaz B veya S toprakla teması ise bu olabilir.Arıza akımı hattı besleyen iletkeni koparttığına göre 1 hp lik elektrik motorunun besleme kablosunu ilk kısa devre arızasında çoktan eritip koparması lazım tabi şaseye veya C faza eriyip yapışıp kaynama ihtimalide var.Bana göre GENÇ ARKADAŞIN dediği gibi daha kuvvetli bir noktadan trafo gibi bir kısa devre sözkonusu.......
Ayırıcı yada sigortalar kesici olarak kullanılmaz ????
Böyle saçma işmi olur? Normalde o sigorta yüklü hatta ise atmamasına şaşırırım....
Ayırıcı yada sigortalar Kesici olarak kullanılmaz ????
kesinlikle katılıyorum.birde hattın enerjisini kesip meger testide yapılabilir diye düşünüyorum.
Unxpacted
