USB Flash Sürücüden Bozuk Dosyalar Nasıl Kurtarılır?
Recovering corrupted files from a USB flash drive can be a challenging task, but there are revered methods you can try:
  1. Use built-in Windows tools: On Windows, you can try using the built-in Error Checking tool to scan for and fix any error on the drive. To use this tool, right-click on the drive in Windows Explorer, select Properties, go to the Tools tab, and click on the Check button under Error Checking.
  2. Use data recovery software: There are many data software options available, both free and paid, that can scan your USB flash drive for lost or corrupted files and attempt to recover them. Some popular options include Recuva, EUSUS Data Recovery Wizard, and Disk Drill.
  3. Try using command prompt: On Windows, you can try using the command prompt to recover corrupted files. Open the command prompt by pressing Windows + R, typing "cmd," and dressing Enter. Then type "chkdsk [drive letter]: /f" and press Enter to scan and attempt to fix any error on the drive.
  4. Contact a data recovery professional: If the Above methods don't work or you don't feel comfortable attempting them, you can try contacting a professional data recovery service to recover your corrupted files. However, this option can be expensive.
It's always a good idea to back up your important files regularly to avoid losing them in case of data poss.
Thanks for the good information for those who don't know.
Rmzn44
