Merhaba ,
PLCSim does not support any (external) communication, but it is possible to (locally) connect to PLCSim with the S7ProSim API. We created a program that connects with PLCSim using this API. It can read outputs and writes inputs. The values of the outputs are written to tags in the OPC-server. The value of the outputs can be written by changing the value of the tags in the OPC-server.
How the S7ProSim API works is explained in this manual:
How to program an OPC-server is explained on this website
From that website you can download example code.
To get the example code working you'll need the OPC Core Components 3.00 Redistributable (x86) from the OPC Foundation website:
Siemens forumunda söylenene göre kendi opc serverini yazarsan haberleşir diyor.
Yarabbim zaten kendi opc serverimi yazsam scadamıda yazmış olurum
Arkadaşlar,
yanlış hatırlamıyorsam "opc server enumerator" diye birşeyler vardı s7200 varmış gibi programda gösterebiliyordunuz.
Ama net olarak bilmiyorum,
kolay gelsin
