çizgi izleyen robot
  • Konbuyu başlatan Konbuyu başlatan haspro
haspro
13 May 2020
AŞŞAĞIDAKİ KODUMU ÇALIŞTIRINCA ŞU HATAYI ALIYORUM: 'hafifsagadon' was not declared in this scope
Kod:
#include <QTRSensors.h>
#define sagtabanhiz 200
#define soltabanhiz 200
#define sagmotoryon 13
#define sagmotorpwmpin 11
#define solmotoryon 12
#define solmotorpwmpin 3
int sensor=10;
QTRSensorsRC qtrrc((unsigned char[]){2,4,5,6,7,8,9,10},8,2500,QTR_NO_EMITTER_PIN);
unsigned int sensorValues[8];
void setup()
   delay(2000);
   pinMode(sensor,INPUT);
   pinMode(sagmotoryon,OUTPUT);
   pinMode(sagmotorpwmpin,OUTPUT);
   pinMode(solmotoryon,OUTPUT);
   pinMode(solmotorpwmpin,OUTPUT);
   int i;
   digitalWrite(13,HIGH);
for (int i=0;i<200;i++)
    if( 0 <=i&&i< 5 ) hafifsagadon();
    if( 5 <=i&&i< 15 ) hafifsoladon();
    if( 15 <=i&&i< 25 ) hafifsagadon();
         if( 25 <=i&&i< 35 ) hafifsoladon();
         if( 35 <=i&&i< 45 ) hafifsagadon();
         if( 45 <=i&&i< 55 ) hafifsoladon();
         if( 55 <=i&&i< 65 ) hafifsagadon();
         if( 65 <=i&&i< 75 ) hafifsoladon();
         if( 75 <=i&&i< 85 ) hafifsagadon();
         if( 85 <=i&&i< 90 ) hafifsoladon();
    if(i>=90 ) {
      frenle();delay(5);
    qtrrc.calibrate();
        delay(4);
    digitalWrite(13,LOW);
    delay(2000);
  Serialbegin(9600);
  int sonhata = 0;
  float Kp = 0.06;
  float Kd = 0.8;
  int sagmotorpwm = 0;
  int solmotorpwm = 0;
  int zemin=0;
  void loop()
  unsigned int position = qtrrc.readLine(sensorValues,1,zemin);
  int hata = position-3500;
  if ( sensorValues[0]<100 && sensorValues[7]<100 ){zemin=0; }
  if ( sensorValues[0]>500 && sensorValues[7]>500 ){zemin=1; }
  int duzeltmehizi = Kp * hata + Kd*(hata - sonhata);
  sonhata = hata;
  sagmotorpwm = sagtabanhiz + duzeltmehizi ;
  solmotorpwm = soltabanhiz - duzeltmehizi ;
  sagmotorpwm = constrain(sagmotorpwm,-100,110);
  solmotorpwm = constrain(solmotorpwm,-100,110);
  motorkontrol(sagmotorpwm,solmotorpwm);
  void motorkontrol( int sagmotorpwm, int solmotorpwm){
   if(sagmotorpwm<=0){
      sagmotorpwm=abs(sagmotorpwm);
      digitalWrite(sagmotoryon,LOW);
      analogWrite(sagmotorpwmpin, sagmotorpwm);
   else{
      analogWrite(sagmotorpwmpin,sagmotorpwm);
   if(solmootrpwm<=0){
      solmotorpwm=abs(solmotorpwm);
      digitalWrite(solmotoryon,LOW);
      analogWrite(solmotorpwmpin,solmotorpwm);
   else{
      digitalWrite(solmotoryon,HIGH);
    void frenle(){
      motorkontrol(0,0);
    void hafifsagadon(){
      motorkontrol(-100,100);
    void hafifsoladon(){
      motorkontrol(100,-100);
Kod sağlam gözüküyor ama yine de hafifsagadon() ve hafifsoladon olan kısımları süslü parantez içinde de bir dene
pepinot
