Arduıno role
Keypad ve lcd çalıştıysa gerisi sizde. "C" öğrenmeye
devam edin.
#include <LiquidCrystal.h>
#include <DS3231.h>
#include <ds3231.h>
#define relay1 0
#define relay2 1
#define relay3 2
#define relay4 3
#define relay5 10
#define relay6 11
#define relay7 12
#define relay8 13
// define pins of RTC module
#define rtcVCC A5
#define rtcGND A4
#define rtcSCLK A3
#define rtcIO A2
#define rtcCE A1
DS3231 clock;
RTCDateTime myRTC;
// creation of RTC object
//virtuabotixRTC myRTC(rtcSCLK, rtcIO, rtcCE);
// keypad definitions
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
// mode definitions
#define modeSETUP 1
#define modeNORMAL 2
int mode = 1; // set default mode
// EEPROM adrressing
#define adr1ON 2
#define adr1OF 4
#define adr2ON 6
#define adr2OF 8
#define adr3ON 10
#define adr3OF 12
#define adr4ON 14
#define adr4OF 16
#define adr5ON 18
#define adr5OF 20
#define adr6ON 22
#define adr6OF 24
#define adr7ON 26
#define adr7OF 28
#define adr8ON 30
#define adr8OF 32
int eepromMin = 0;
int eepromHour = 0;
int eepromHourON = 0;
int eepromHourOF = 0;
int eepromMinON = 0;
int eepromMinOF = 0;
// pins used on LCD Keypad Shield
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
int lcd_key = 0;
int adc_key_in = 0;
void setup() {
// inisialisasi serial utk debugging
Serial.begin(9600);
// Initialize DS3231
Serial.println(“Initialize DS3231”);;
clock.begin();
// Set sketch compiling time
clock.setDateTime(__DATE__, __TIME__);
// digital pin sbg output
for (int i = 0; i <= 13; i++) {
pinMode(i, OUTPUT);
// activate RTC module
pinMode(rtcVCC, OUTPUT);
pinMode(rtcGND, OUTPUT);
pinMode(rtcSCLK, OUTPUT);
pinMode(rtcIO, OUTPUT);
pinMode(rtcCE, OUTPUT);
digitalWrite(rtcVCC, HIGH);
digitalWrite(rtcGND, LOW);
delay(500);
// lcd initialization
lcd.begin(16, 2);
void loop() {
lcd.setCursor(4, 0);
displayTime();
// set data eeprom
lcd.setCursor(0, 1);
lcd.print("1");
relayAction(adr1ON, adr1OF, 1, relay1);
lcd.setCursor(2, 1);
lcd.print("2");
relayAction(adr2ON, adr2OF, 3, relay2);
lcd.setCursor(4, 1);
lcd.print("3");
relayAction(adr3ON, adr3OF, 5, relay3);
lcd.setCursor(6, 1);
lcd.print("4");
relayAction(adr4ON, adr4OF, 7, relay4);
// lcd.setCursor(8, 1);
// lcd.print("5");
// relayAction(adr5ON, adr5OF, 9, relay5);
// lcd.setCursor(10, 1);
// lcd.print("6");
// relayAction(adr6ON, adr6OF, 11, relay6);
// lcd.setCursor(12, 1);
// lcd.print("7");
// relayAction(adr7ON, adr7OF, 13, relay7);
// lcd.setCursor(14, 1);
// lcd.print("8");
// relayAction(adr8ON, adr8OF, 15, relay8);
if (read_LCD_buttons() == btnSELECT) {
while (read_LCD_buttons() == btnSELECT);
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Check Real Time");
lcd.print("Time Setting");
while (read_LCD_buttons() == btnNONE);
if (read_LCD_buttons() == btnUP) {
while (read_LCD_buttons() == btnUP);
setRTC(); //menu setting RTC
else if (read_LCD_buttons() == btnDOWN) {
while (read_LCD_buttons() == btnDOWN);
setPin(); // user DOWN, menu setting PIN
// Send me some Bicoin @ 3GUEZPhUWQtHF7WJ1ZTEP9BET7KHskn2vS
void relayAction(int adrON, int adrOF, int pos, int pin) {
myRTC = clock.getDateTime();
int MinToday = (myRTC.hour * 60) + myRTC.minute;
int MinEprON = (EEPROM.read(adrON) * 60) + EEPROM.read(adrON + 1);
int MinEprOF = (EEPROM.read(adrOF) * 60) + EEPROM.read(adrOF + 1);
lcd.setCursor(pos, 1);
if (MinEprON == MinEprOF) {
lcd.print(" ");
digitalWrite(pin, LOW);
else if (MinEprON < MinEprOF) {
if ((MinEprON MinToday)) {
lcd.print(“*”);
else {
lcd.print(“-“);
digitalWrite(pin, HIGH);
else if (MinEprON > MinEprOF) {
if ((MinEprON >= MinToday) || (MinEprOF = 24) eepromHour = 0;
if (eepromMin >= 60) eepromMin = 0;
setupShowValue(eepromHour, eepromMin, 0);
setupChooseValue(eepromHour, eepromMin, adr1ON, 0);
lcd.print(“PIN 1 OFF”);
eepromHour = EEPROM.read(adr1OF);
eepromMin = EEPROM.read(adr1OF + 1);
if (eepromHour >= 24) eepromHour = 0;
setupShowValue(eepromHour, eepromMin, 1);
setupChooseValue(eepromHour, eepromMin, adr1OF, 1);
lcd.clear();
lcd.print(“PIN 2 ON”);
eepromHour = EEPROM.read(adr2ON);
eepromMin = EEPROM.read(adr2ON + 1);
setupChooseValue(eepromHour, eepromMin, adr2ON, 0);
lcd.print(“PIN 2 OFF”);
eepromHour = EEPROM.read(adr2OF);
eepromMin = EEPROM.read(adr2OF + 1);
setupChooseValue(eepromHour, eepromMin, adr2OF, 1);
lcd.clear();
lcd.print(“PIN 3 ON”);
eepromHour = EEPROM.read(adr3ON);
eepromMin = EEPROM.read(adr3ON + 1);
setupChooseValue(eepromHour, eepromMin, adr3ON, 0);
lcd.print(“PIN 3 OFF”);
eepromHour = EEPROM.read(adr3OF);
eepromMin = EEPROM.read(adr3OF + 1);
setupChooseValue(eepromHour, eepromMin, adr3OF, 1);
lcd.clear();
lcd.print(“PIN 4 ON”);
eepromHour = EEPROM.read(adr4ON);
eepromMin = EEPROM.read(adr4ON + 1);
setupChooseValue(eepromHour, eepromMin, adr4ON, 0);
lcd.print(“PIN 4 OFF”);
eepromHour = EEPROM.read(adr4OF);
eepromMin = EEPROM.read(adr4OF + 1);
setupChooseValue(eepromHour, eepromMin, adr4OF, 1);
// lcd.clear();
// lcd.setCursor(0, 0);
// lcd.print(“PIN 5 ON”);
// eepromHour = EEPROM.read(adr5ON);
// eepromMin = EEPROM.read(adr5ON + 1);
// if (eepromHour >= 24) eepromHour = 0;
// if (eepromMin >= 60) eepromMin = 0;
// setupShowValue(eepromHour, eepromMin, 0);
// while (read_LCD_buttons() == btnNONE);
// setupChooseValue(eepromHour, eepromMin, adr5ON, 0);
// lcd.setCursor(0, 1);
// lcd.print(“PIN 5 OFF”);
// eepromHour = EEPROM.read(adr5OF);
// eepromMin = EEPROM.read(adr5OF + 1);
// setupShowValue(eepromHour, eepromMin, 1);
// setupChooseValue(eepromHour, eepromMin, adr5OF, 1);
// lcd.clear();
// lcd.print(“PIN 6 ON”);
// eepromHour = EEPROM.read(adr6ON);
// eepromMin = EEPROM.read(adr6ON + 1);
// setupChooseValue(eepromHour, eepromMin, adr6ON, 0);
// lcd.print(“PIN 6 OFF”);
// eepromHour = EEPROM.read(adr6OF);
// eepromMin = EEPROM.read(adr6OF + 1);
// setupChooseValue(eepromHour, eepromMin, adr6OF, 1);
// lcd.clear();
// lcd.print(“PIN 7 ON”);
// eepromHour = EEPROM.read(adr7ON);
// eepromMin = EEPROM.read(adr7ON + 1);
// setupChooseValue(eepromHour, eepromMin, adr7ON, 0);
// lcd.print(“PIN 7 OFF”);
// eepromHour = EEPROM.read(adr7OF);
// eepromMin = EEPROM.read(adr7OF + 1);
// setupChooseValue(eepromHour, eepromMin, adr7OF, 1);
// lcd.clear();
// lcd.print(“PIN 8 ON”);
// eepromHour = EEPROM.read(adr8ON);
// eepromMin = EEPROM.read(adr8ON + 1);
// setupChooseValue(eepromHour, eepromMin, adr8ON, 0);
// lcd.print(“PIN 8 OFF”);
// eepromHour = EEPROM.read(adr8OF);
// eepromMin = EEPROM.read(adr8OF + 1);
// setupChooseValue(eepromHour, eepromMin, adr8OF, 1);
lcd.clear();
void setupChooseValue(int HourNew, int MinNew, byte Address, byte Pos) {
while (read_LCD_buttons() != btnSELECT) {
if (read_LCD_buttons() == btnRIGHT) {
if (HourNew 0) {
HourNew–;
else if (read_LCD_buttons() == btnUP) {
if (MinNew 0) {
MinNew–;
setupShowValue(HourNew, MinNew, Pos);
delay(150);
while (read_LCD_buttons() != btnNONE);
EEPROM.write(Address, HourNew);
EEPROM.write(Address + 1, MinNew);
delay(150);
void setupChooseValueSetRTC(int HourNew, int MinNew, byte Pos) {
if (HourNew 0) {
HourNew–;
if
(MinNew 0) {
MinNew–;
delay(150);
//myRTC.setDS1302Time(00, MinNew, HourNew, 25, 2, 1, 2021);
//Initialize DS3231
delay(150);
void setupShowValue(int Hour, int Min, int Pos) {
lcd.setCursor(11, Pos);
print2digits(Hour);
lcd.print(“:”);
print2digits(Min);
int read_LCD_buttons()
adc_key_in = analogRead(0); // read the value from the sensor
if (adc_key_in > 1000) return btnNONE;
if (adc_key_in <50) return btnRIGHT;
if (adc_key_in <250) return btnUP;
if (adc_key_in <450) return btnDOWN;
if (adc_key_in <650) return btnLEFT;
if (adc_key_in > 0) & 0xFF);
byte highByte = ((p_value >> 8) & 0xFF);
EEPROM.write(p_address, lowByte);
EEPROM.write(p_address + 1, highByte);
unsigned int eeprom_read_int(int p_address) {
byte lowByte = EEPROM.read(p_address);
byte highByte = EEPROM.read(p_address + 1);
return ((lowByte << 0) & 0xFF) + ((highByte <= 0 && number < 10)
lcd.print('0');
lcd.print(number, DEC);
HOCALARIM ABİLERİM.Elimde şöyle bi kod var ne yaptımsa bi türlü çalıştıramadım yardımcı olacak kimse yokmu. lcd.print(“:”); hatası veriyor stray 342 in program
#include <DS3231.h>
#include <ds3231.h>
#define relay1 0
#define relay2 1
#define relay3 2
#define relay4 3
#define relay5 10
#define relay6 11
#define relay7 12
#define relay8 13
#define rtcVCC A5
#define rtcGND A4
#define rtcSCLK A3
#define rtcIO A2
#define rtcCE A1
DS3231 clock;
RTCDateTime myRTC;
#define btnRIGHT 0
#define btnUP 1
#define btnDOWN 2
#define btnLEFT 3
#define btnSELECT 4
#define btnNONE 5
// mode definitions
#define modeSETUP 1
#define adr1ON 2
#define adr1OF 4
#define adr2ON 6
#define adr2OF 8
#define adr3ON 10
#define adr3OF 12
#define adr4ON 14
#define adr4OF 16
#define adr5ON 18
#define adr5OF 20
#define adr6ON 22
#define adr6OF 24
#define adr7ON 26
#define adr7OF 28
#define adr8ON 30
#define adr8OF 32
int eepromMin = 0;
int eepromHour = 0;
int lcd_key = 0;
int adc_key_in = 0;
void setup() {
Serial.begin(9600);
clock.begin();
pinMode(i, OUTPUT);
delay(500);
lcd.begin(16, 2);
void loop() {
displayTime();
// set data eeprom
lcd.print("1");
lcd.print("2");
lcd.print("3");
lcd.print("4");
// lcd.print("5");
// lcd.print("6");
// lcd.print("7");
// lcd.print("8");
lcd.clear();
lcd.print(" ");
lcd.print(“*”);
else {
lcd.print(“-“);
lcd.clear();
lcd.clear();
lcd.clear();
// lcd.clear();
// lcd.clear();
// lcd.clear();
// lcd.clear();
lcd.clear();
if (HourNew 0) {
HourNew–;
if (MinNew 0) {
MinNew–;
delay(150);
delay(150);
if (HourNew 0) {
HourNew–;
if
(MinNew 0) {
MinNew–;
delay(150);
//Initialize DS3231
delay(150);
print2digits(Hour);
lcd.print(“:”);
print2digits(Min);
lcd.print('0');
Yardimci olacak kimse yoktu.
Benzer Konular
canerakdeniiz
