b5t
- 12 Tem 2023
- 1
- 0
- Yaş
- 13
arduino 2 kod birleştirmeyi denedim ama kod
BU KODLARI NASIL BİRLEŞTİRİLİR
A function-definition is not allowed here before '{' token hatası veriyor
C++:
#include <SoftwareSerial.h>
#include <DFRobotDFPlayerMini.h>
SoftwareSerial mySoftwareSerial(2, 3); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
String readSerial;
void setup() {
mySoftwareSerial.begin(9600);
Serial.begin(9600);
Serial.println(F("Voice Controlled mp3 player Demo."));
Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
if (!myDFPlayer.begin(mySoftwareSerial)) { //Use softwareSerial to communicate with mp3.
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
while (true);
Serial.println(F("DFPlayer Mini online."));
myDFPlayer.setTimeOut(500); //Set serial communictaion time out 500ms
//----Set volume----
myDFPlayer.volume(30); //Set volume value (0~30).
//----Set different EQ----
myDFPlayer.EQ(DFPLAYER_EQ_CLASSIC);
myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD);
void loop() {
if (Serial.available()) {
readSerial = Serial.readStringUntil('#');
Serial.println(readSerial);
if (readSerial == "play song number 1") myDFPlayer.play(1);
else if (readSerial == "play song number 2") myDFPlayer.play(2);
else if (readSerial == "play song number 3") myDFPlayer.play(3);
else if (readSerial == "play song number 4") myDFPlayer.play(4);
else if (readSerial == "stop song") myDFPlayer.stop();
else if (readSerial == "pause song") myDFPlayer.pause();
else if (readSerial == "resume song") myDFPlayer.start();
else if (readSerial == "play next song") myDFPlayer.next();
////////////////////////////////////////////////////////////////////// 2. KOD
/[CODE=cpp]/
String voice; // voice değişkeni tanımlanıyor
int
led1 = 2, //led'lerin bağlı olduğu pinler
led2 = 3,
led3 = 4,
led4 = 5,
led5 = 6;
//--------------------------Fonksiyonların tanımlanması-------------------------------//
void allon(){ // allon,hepsini aç fonksiyonu,tüm çıkışlar aktif
digitalWrite(led1, HIGH);
digitalWrite(led2, HIGH);
digitalWrite(led3, HIGH);
digitalWrite(led4, HIGH);
digitalWrite(led5, HIGH);
void alloff(){ //allof,hepsini kapa fonksiyonu,tğm çıkışlar pasif
digitalWrite(led1, LOW);
digitalWrite(led2, LOW);
digitalWrite(led3, LOW);
digitalWrite(led4, LOW);
digitalWrite(led5, LOW);
void setup() {
Serial.begin(9600); // seri iletişim başlar
pinMode(led1, OUTPUT); // led'ler çıkış elemanı
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
void loop() {
while (Serial.available()){ //bilgi geldiği sürece
delay(10); //güvenlik gecikmesi uygula
char c = Serial.read(); //verileri oku c karekterine at
if (c == '#') {break;} //# işareti gelirse,yani okuma bitmişse döngüyü durdur.
voice += c; //gelen her karekteri ekle ve komut cümlesini tamamla
if (voice.length() > 0) {
Serial.println(voice);
//----------Tüm ledlerin kontrolü----------//
if(voice == "*all on") {allon();} //all on denirse ledlerin hepsini aç
else if(voice == "*all off"){alloff();} //all off denirse ledlerin hepsini kapa
bu kodları nasıl birleştirilir
//----------Adım Adım Açma komutlar----------//
else if(voice == "*TV on") {digitalWrite(led1, HIGH);} //tv açma komutu
else if(voice == "*fan on") {digitalWrite(led2, HIGH);} // fan çalıştırma komutu
else if(voice == "*computer on") {digitalWrite(led3, HIGH);} // bilgisayar açma komutu
else if(voice == "*bedroom lights on") {digitalWrite(led4, HIGH);} // yatak odası lambasını açma
else if(voice == "*bathroom lights on") {digitalWrite(led5, HIGH);} // banyo lambasını açma
//----------Adım Adım Kapatma komutları----------//
else if(voice == "*TV off") {digitalWrite(led1, LOW);}
else if(voice == "*fan off") {digitalWrite(led2, LOW);}
else if(voice == "*computer off") {digitalWrite(led3, LOW);}
else if(voice == "*bedroom lights off") {digitalWrite(led4, LOW);}
else if(voice == "*bathroom lights off") {digitalWrite(led5, LOW);}
voice="";}} //komutlar bitincce voice değişkenini sıfırla
