Arduino MQ-5 Kodlama
18 Mar 2021
Elimdeki kodu buraya bırakıyorum. Her şey çalışıyor ancak, açar açmaz kodlayıp buzzer 900 lü seviyelerde ötmeye başlıyor. Ne yapmalıyım ?
Kod:
#include <LiquidCrystal.h>
LiquidCrystal lcd(2, 3, 4, 5, 6, 7);
int sensorPin = A0; // choose the input pin (for GAS sensor)
int buzzer = 13; // choose the pin for the Buzzer
int G_led = 8; // choose the pin for the Green LED
int R_led = 9; // choose the pin for the Red Led
int read_value; // variable for reading the gaspin status
int set = 50;  // we start, assuming Smoke detected
void setup(){
pinMode(sensorPin, INPUT); // declare sensor as input
pinMode(buzzer,OUTPUT); // declare Buzzer as output
pinMode(R_led,OUTPUT); // declare Red LED as output
pinMode(G_led,OUTPUT); // declare Green LED as output
lcd.begin(16, 2);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("   WELCOME To   ");
lcd.setCursor(0,1);
lcd.print("  GAS Detector  ");
delay(2000);
lcd.clear();
void loop(){
read_value = (analogRead(sensorPin)); // read input value
read_value = read_value - 50;
if(read_value<0){read_value=0;}
lcd.setCursor(0, 0);
lcd.print("Smoke Level: ");
lcd.print(read_value);
lcd.print("  ");
if(read_value>set){ // check if the Smoke variable is High
lcd.setCursor(0, 1);
lcd.print("Alert....!!!    ");
digitalWrite(buzzer, HIGH); // Turn LED on.
digitalWrite(R_led, HIGH); // Turn LED on.
digitalWrite(G_led, LOW); // Turn LED off.
delay(1000);
if(read_value<set){ // check if the Smoke variable is Low
lcd.print(".....Normal.....");
digitalWrite(buzzer, LOW); // Turn LED on.
digitalWrite(R_led, LOW); // Turn LED on.
digitalWrite(G_led, HIGH); // Turn LED on.
delay(100);
projeci3363
