Arduino nano compiling hatası
gparadiso
24 Tem 2007
Merhabalar ben bu kodu dün nanoya atıp çalıştırdım fakat bugün aynı kodu derlemek isteyince
text section exceeds available space in boardSketch uses 30918 bytes (100%) of program storage space. Maximum is 30720 bytes.
Global variables use 617 bytes (30%) of dynamic memory, leaving 1431 bytes for local variables. Maximum is 2048 bytes.
Sketch too big; see https://support.arduino.cc/hc/en-us/articles/360013825179 for tips on reducing it.
Error compiling for board Arduino Nano.
böyle bir hata alıyorum nasıl düzeltebilirim?
//MAX72xx Dot Matrix Display & BME280 Sensor
#include <Wire.h>
#include <MD_MAX72xx.h>
#include <MD_Parola.h>
#include <SPI.h>
#include <Adafruit_BME280.h>
MD_Parola disp = MD_Parola(MD_MAX72XX::FC16_HW, 10, 4);
Adafruit_BME280 bme;
int temp, hum, pres; String tempString, humString, presString;
void setup()
pinMode(2,INPUT); pinMode(3,INPUT); pinMode(4,INPUT);
disp.begin(); bme.begin(0x76, &Wire);
disp.displayText("BME280 Sensor", PA_LEFT, 40, 40, PA_SCROLL_LEFT,PA_SCROLL_LEFT);
void loop()
// while(!disp.displayAnimate());
// disp.displayText("T * H * P", PA_LEFT, 20, 20, PA_SCROLL_LEFT,PA_SCROLL_LEFT);
if(digitalRead(2) == HIGH) dispTemp();
if(digitalRead(3) == HIGH) dispHum();
if(digitalRead(4) == HIGH) dispPres();
disp.displayClear();
void dispTemp()
disp.displayText("Temperature", PA_LEFT, 30, 30, PA_SCROLL_LEFT,PA_SCROLL_LEFT);
delay(500);
for(int i=1; i<=7; i++)
temp = bme.readTemperature();
tempString = " " + String(temp) + " C";
disp.print(tempString);
delay(1000);
void dispHum()
disp.displayText("Humidity", PA_LEFT, 30, 30, PA_SCROLL_LEFT,PA_SCROLL_LEFT);
delay(500);
hum = bme.readHumidity();
humString = " " + String(hum) + " %";
disp.print(humString);
delay(1000);
void dispPres()
disp.displayText("Pressure", PA_LEFT, 30, 30, PA_SCROLL_LEFT,PA_SCROLL_LEFT);
delay(500);
pres = bme.seaLevelForAltitude(705, bme.readPressure())/100;
presString = "" + String(pres) + " H";
disp.print(presString);
delay(1000);
ismail.51
