Arduino PWM frekansı
selcuk1010
13 Ara 2017
Merhaba arkadaşlar bu arduino kodundaki pwm'in frekansı kaç HZ?
#include <LiquidCrystal.h> #define buck 9 #define boost 6 #define output A0 #define POT A1 bool boostMode = 0; bool buckMode = 0; uint8_t PWM = 0; const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2; LiquidCrystal lcd(rs, en, d4, d5, d6, d7); void setup() { lcd.begin(16, 2); pinMode( buck, OUTPUT ); pinMode( boost, OUTPUT ); pinMode( output, INPUT ); pinMode( POT, INPUT ); digitalWrite( buck, LOW ); digitalWrite( boost, LOW ); } void loop() { float voltage = 0; uint16_t adc = analogRead( output ); uint16_t potAC = analogRead( POT ); adc = map( adc, 0 , 1023, 0, 5 ); potAC = map( potAC, 0, 1023, 0, 255 ); voltage = adc / 0.2083; lcd.setCursor(0, 0); lcd.print(voltage); if( potAC <= 125 ) { boostMode = false; buckMode = true; } if( potAC > 125 ) { boostMode = true; buckMode = false; } if( buckMode ) { PWM = map( potAC, 0, 125, 35, 255 ); analogWrite( buck, PWM ); analogWrite( boost, 0 ); } if( boostMode ) { PWM = map( potAC, 125 , 255, 10, 47 ); analogWrite( buck, 255 ); analogWrite( boost, PWM ); } }
fevzican
