Transistörel
- 7 Haz 2021
- 8
- 1
- Yaş
- 24
Öncelikle herkeze merhaba ben Aurdiuno ya yeni başlıyorum ve bi sıkıntım var wirales alıcısı ve servo motorla beraber bi sistem yaptım lakin kodlamada iyi olmadığım için bi sıkıntı çıktı kodu ve hatayı belirttim . Ne yapıcağımı bilmiyorum yardım ederseniz sevnirim : >
bu kodu aldığım kanal :
HATA KODUDA BU
C:\Users\bedredtin\Desktop\uzaktan kmanda\sketch_jun07c\sketch_jun07c.ino: In function 'void loop()':
sketch_jun07c:45:52: error: void value not ignored as it ought to be
done = radio.read( verilerim, sizeof(verilerim));
sketch_jun07c:47:21: error: request for member 'verilerim' in 'map', which is of non-class type 'long int(long int, long int, long int, long int, long int)'
servodegeri=map.verilerim[0],0,1023,0,179
sketch_jun07c:53:18: error: no matching function for call to 'HardwareSerial:
rint()'
Serial.print();
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Stream.h:26:0,
from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:29,
from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:233,
from sketch\sketch_jun07c.ino.cpp:1:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:65:12: note: candidate: size_t Print:
rint(const __FlashStringHelper*)
size_t print(const __FlashStringHelper *);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:65:12: note: candidate expects 1 argument, 0 provided
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:66:12: note: candidate: size_t Print:
rint(const String&)
size_t print(const String &);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:66:12: note: candidate expects 1 argument, 0 provided
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:67:12: note: candidate: size_t Print:
rint(const char*)
size_t print(const char[]);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:67:12: note: candidate expects 1 argument, 0 provided
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:68:12: note: candidate: size_t Print:
rint(char)
size_t print(char);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:68:12: note: candidate expects 1 argument, 0 provided
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:69:12: note: candidate: size_t Print:
rint(unsigned char, int)
size_t print(unsigned char, int = DEC);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:69:12: note: candidate expects 2 arguments, 0 provided
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:70:12: note: candidate: size_t Print:
rint(int, int)
size_t print(int, int = DEC);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:70:12: note: candidate expects 2 arguments, 0 provided
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:71:12: note: candidate: size_t Print:
rint(unsigned int, int)
size_t print(unsigned int, int = DEC);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:71:12: note: candidate expects 2 arguments, 0 provided
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:72:12: note: candidate: size_t Print:
rint(long int, int)
size_t print(long, int = DEC);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:72:12: note: candidate expects 2 arguments, 0 provided
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:73:12: note: candidate: size_t Print:
rint(long unsigned int, int)
size_t print(unsigned long, int = DEC);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:73:12: note: candidate expects 2 arguments, 0 provided
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:74:12: note: candidate: size_t Print:
rint(double, int)
size_t print(double, int = 2);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:74:12: note: candidate expects 2 arguments, 0 provided
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:75:12: note: candidate: size_t Print:
rint(const Printable&)
size_t print(const Printable&);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:75:12: note: candidate expects 1 argument, 0 provided
sketch_jun07c:67:3: error: expected '}' before 'else'
else
exit status 1
HATA KODUDA BU
Serial.print();
size_t print(char);
else
exit status 1
Kod:
#define KEY1 0
#define KEY2 0
#include <Servo.h>
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 8
const uint64_t pipe =0xE8E8F0F0E1LL;
RF24 radio(CE_PIN, CSN_PIN);
int verilerim [] = {KEY1 , KEY2};
int servodegeri, leddegeri;
Servo servoNesnesi;
int Led=2;
void setup() {
Serial.begin(57600);
delay (1000);
pinMode(Led, OUTPUT);
servoNesnesi.attach(10);
Serial.println("Nrf24L01 Alıcı Başlatılıyor");
radio.begin();
radio.openReadingPipe(1, pipe);
radio.startListening();
// put your setup code here, to run once:
void loop() {
if ( radio.available() )
bool done = false;
while (!done)
digitalWrite(Led,LOW);
leddegeri=map(verilerim[1],0,1023,0,255);
Serial.print("KEY1 = ");
Serial.print(servodegeri);
Serial.print(" Key2 = ");
Serial.print(leddegeri);
Serial.print();
servoNesnesi.write(servodegeri);
if ((leddegeri > 130) || (leddegeri <120))
digitalWrite(Led, HIGH);
else
digitalWrite(Led, LOW);
else
Serial.println("Verici Bulunmadı");
verilerim[0] = 0;
verilerim[1] = 0;
servoNesnesi.write(90);
// put your main code here, to run repeatedly:
