murtkenan
- Katılım
- 13 Ocak 2008
- Mesajlar
- 24
- Puanları
- 1
- Yaş
- 42
Arkadaşlar merhaba. CPU 315 2PN/DP PLC kullanıyorum. Ve im 365 send ve receive modulüm var. Şu an CPU çalışınca BF2 ledini yakıyo. Diagnostic buffer raporu aşağıda. Yardımcı olursanız sevinirim.
Kod:
Diagnostic buffer of module CPU 315-2 PN/DP
Order No./ Description Component Version
6ES7 315-2EH13-0AB0 Hardware 4
- - - Firmware V 2.6.5
Boot Loader Firmware expansion A 10.13.9
Rack: 0
Slot: 2
Event 1 of 10: Event ID 16# 4302
Mode transition from STARTUP to RUN
Startup information:
- Time for time stamp at the last backed up power on
- Single processor operation
Current/last startup type:
- Warm restart triggered via MPI; last power on backed up
Permissibility of certain startup types:
- Manual warm restart permitted
- Automatic warm restart permitted
Last valid operation or setting of automatic startup type at power on:
Previous operating mode: STARTUP (warm restart)
Requested operating mode: RUN
Incoming event
06:49:56.938 PM 05/01/1994
Event 2 of 10: Event ID 16# 1381
Request for manual warm restart
STOP due to: STOP caused by PG stop operation or by SFB 20 "STOP"
- Startup without modified system configuration
- No difference between setpoint and actual configuration
Requested OB: Startup OB (OB100)
Priority class: 27
Incoming event
06:49:56.934 PM 05/01/1994
Event 3 of 10: Event ID 16# 4301
Mode transition from STOP to STARTUP
Last valid operation or setting of the automatic startup type at power on:
Previous operating mode: STOP (internal)
Requested operating mode: STARTUP (warm restart)
Incoming event
06:49:56.852 PM 05/01/1994
Event 4 of 10: Event ID 16# 596D
The existing network configuration do not correspond to the system requirements or configuration
logical address of the error-detecting module 2045
cause of error: Bps not suitable for PROFINET IO
External error, Incoming event
06:49:20.431 PM 05/01/1994
Event 5 of 10: Event ID 16# 4304
Previous operating mode: RUN
Requested operating mode: STOP (internal)
Incoming event
06:49:17.265 PM 05/01/1994
Event 6 of 10: Event ID 16# 2521
BCD conversion error
Affected register: accumulator 1
Requested OB: Programming error OB (OB121)
Priority class: 1
Internal error, Incoming event
03:09:36.689 AM 05/01/1994
Event 7 of 10: Event ID 16# 2521
Priority class: 1
03:09:36.686 AM 05/01/1994
Event 8 of 10: Event ID 16# 2521
Priority class: 1
03:09:36.684 AM 05/01/1994
Event 9 of 10: Event ID 16# 2521
Priority class: 1
03:09:36.681 AM 05/01/1994
Event 10 of 10: Event ID 16# 2521
Priority class: 1
03:09:36.678 AM 05/01/1994
