Dtmf ile kontrol devresi
  • Konbuyu başlatan Konbuyu başlatan seko74
seko74
29 Ara 2013
arkadaşlar elimde dtmf ile kontrol devresi var asm kodunda göreceğiniz gibi kod doğru yazılırsa roleyi çekiyor ancak ben bu rolenin 5 saniye sonra kapatma kodu olmadan bırakmasını yani otomatik olarak bırakmasını istiyorum asm ye nasıl bir ek yapmam gerek.
asm kodu
Kod:
    list    p=16f84a
    include "p16f84a.inc"
    __FUSES _CP_OFF & _XT_OSC  & _WDT_OFF & _PWRTE_ON
OPTREG    equ    01
TRIS_A    equ    05
TRIS_B    equ    06
relays    equ    10
mfcode    equ    11
cntdown    equ    12
timeout    equ    13
slocnt1    equ    14
slocnt2    equ    15
numa    equ    16
numb    equ    17
numc    equ    18
numd    equ     19
    org 0000            ;tell assembler to start at 000H
init    goto start
    org 0004            ;interrupt vector
rtc_interrupt
    decfsz slocnt1,F        ;decrement 1st prescaler
    goto rtc_int_1
    decfsz slocnt2,F        ;decrement 2nd prescaler
    goto rtc_int_1
    bcf relays,4            ;turn relay 6 off
    bcf PORTB,4
rtc_int_1
    decfsz cntdown,F        ;count down and skip next if = 0
    goto counting            ;still counting if not reached zero
    bsf timeout,0            ;set timed out bit
    bcf INTCON,2            ;clear interrupt flag
    retfie                ;return
counting
    bcf timeout,0            ;clear timed out bit
    retfie                ;return
; subroutines
wait_strobe
    btfsc timeout,0            ;see if timed out
    goto set_z            ;set Z flag if timeout ocurred
    btfss PORTA,4            ;see if Strobe is active on RA4
    goto wait_strobe        ;loop until it is
    movfw PORTA            ;retreive the code from the 8870
    movwf mfcode            ;store it in mfcode
    bcf mfcode,4            ;ensure strobe isn't seen as data
    bcf STATUS,2            ;return with Z=0 if tone decoded
    return
set_z    bsf STATUS,2            ;return with Z=1 if timed out waiting
    return
wait_no_strobe
    btfsc PORTA,4            ;see if strobe is active on RA4
    goto wait_no_strobe        ;loop until it isn't
    return
start_timer
    movlw H'54'            ;software prescaler for 7 seconds
    movwf cntdown
    return
; Start of setup and decode routines:
start    movlw B'00100000'        ;select register page 1
    movwf STATUS
    clrf TRIS_B            ;set all port B pins to output mode
    movlw B'00011111'        ;set all port A pins to input mode
    movwf TRIS_A
    movlw B'10000111'
    movwf OPTREG            ;sets:     pull-up on port B OFF
                    ;    RTCC counts internal clock
                    ;    prescaler connected to RTCC
                    ;    prescaler divides by 256
                    ;    (other bits unimportant)
    clrw                ;clear the working register
    movwf STATUS            ;switch back to register page 0
    clrf PORTB            ;all outputs off
    clrf relays
    clrf timeout
    movlw B'10100000'
    movwf INTCON            ;global and RTCC interrupts enabled
set_sec    movlw H'01'            ;put the 4 access codes into memory
    movwf numa            ;note for a 0 the hex is H'0A'
    movlw H'02'
    movwf numb
    movlw H'03'
    movwf numc
    movlw H'04'
    movwf numd
decode    call wait_no_strobe        ;start running when no tone present
    clrf timeout            ;set timeout condition until later
    call wait_strobe        ;wait for a tone to be received
    movlw H'0B'            ;0B is the code for DTMF "*"
    subwf mfcode,W            ;set zero flag if "*" was received
    btfsc STATUS,2            ;skip next if it was not a "*"
    goto got_star
    goto decode            ;look for another one
got_star
    call start_timer        ;start time-out timer
    call wait_no_strobe        ;wait for second tone
    call wait_strobe
    btfsc STATUS,2            ;abort if timed out
    goto decode
    movf numa,W
    subwf mfcode,W                  ;set zero flag if second tone was 1
    btfsc STATUS,2            ;skip next if it was not a 1
    goto got_A
    goto get_#
got_A    call wait_no_strobe        ;wait for third tone
    call wait_strobe
    goto decode
    movf numb,W
    goto got_B
    goto get_#
got_B    call wait_no_strobe        ;wait for third tone
    call wait_strobe
    goto decode
    movf numc,W
    goto got_C
    goto get_#
got_C    call wait_no_strobe        ;wait for third tone
    call wait_strobe
    goto decode
    movf numd,W
    goto got_D
    goto get_#
got_D    call wait_no_strobe        ;wait for third tone
    call wait_strobe
    goto decode
    movlw H'01'
    goto got_1
    movlw H'02'
    subwf mfcode,W                  ;set zero flag if second tone was 0
    btfsc STATUS,2            ;skip next if it was not a 0
    goto get_#            ;wait for # to end invalid sequence
; to reach here, the tone sequence "*<numa><numb><numc><numd>1" has been found, now decode request
; according to the next 2 tones but don't action it until a "#" is seen.
got_1    call wait_no_strobe
    call wait_strobe        ;wait for third tone
    goto decode
    call wait_no_strobe        ;wait for tone to finish
    movf mfcode,W            ;pick up keyed digit
    addwf PCL,F            ;jump ahead to vector
    goto decode            ;5D (mf code 0000)
    goto got_11
    goto decode            ;*
    goto decode            ;#
    goto decode            ;5A
    goto decode            ;5B
    goto decode            ;5C (mf code 1111)
got_11    bsf relays,0            ;set output 1 on
    goto get_#
get_#    call wait_strobe        ;wait for 7th tone
    goto decode
    movlw H'0C'            ;0C is the DTMF code for "#"
    subwf mfcode,W            ;if # received set Z flag
    btfsc STATUS,2            ;skip next if not a #
    goto got_#
    call wait_no_strobe
    goto get_#            ;only # is valid, loop until found
                            ;or timeout
got_#   call wait_no_strobe        ;wait for the tone to finish
    movfw relays            ;use the "relays" variable to set RB
    movwf PORTB
    goto decode            ;all done, check for new sequence
    end
boş cevrimin döndügü kısımda röle çekilimi diye kontrol yapacaksın.eger role cekili ise 5 saniyelik boş dongü yazıp,döngünün bitişinde röleyi bıraktıracaksın.
Benim gördügüm kadarıyla:
COUNTER1 equ 20 //ekle
COUNTER2 equ 21 //ekle
org 0000 ;tell assembler to start at 000H =====>SATIRININ USTUNE yukardaki iki satırı ekle
Kod:
    goto got_star
//*************bu kısım sonradan eklendi************************************
   btfss relays,0   // role cekili ise asagı dallan
   goto decode
//***5 saniye bekleme kısmı
clrf COUNTER1
  movlw  0x20  // bu degeri deneyerek degistir(sure için)
  movwf  COUNTER2
bosdongu   nop               // 5 sanıye bekleme için bos dongu yapıyoruz
                    decfsz COUNTER1,f
                     goto   bosdongu
                     decfsz COUNTER2,f
                     goto   bosdongu
                      bcf relays,0  //roleyi bıraktır
//*************ekleme sonu***************************************************
işallah calısır.
kolay gelsin.
Eger assambler ile ugrasıyorsan kendini biraz daha geliştirdikten sonra arm ye geçmeni öneririm
tşkler akşam derleyip deneyeceğim umarım çalışır
hocam kodu ekledim ancak aşağıdaki hataları verdi dosyalar ekte.
  • asm.rar
    asm.rar
    6.8 KB · Görüntüleme: 5
Kod:
list    p=16f84a
OPTREG    equ    01
TRIS_A    equ    05
TRIS_B    equ    06
relays    equ    10
mfcode    equ    11
cntdown    equ    12
timeout    equ    13
slocnt1    equ    14
slocnt2    equ    15
numa    equ    16
numb    equ    17
numc    equ    18
numd    equ     19
COUNTER1 equ 20
COUNTER2 equ 21
init    goto start
rtc_interrupt
    goto rtc_int_1
    goto rtc_int_1
    bcf PORTB,4
rtc_int_1
    retfie                ;return
counting
    retfie                ;return
; subroutines
wait_strobe
    return
    return
wait_no_strobe
    return
start_timer
    movwf cntdown
    return
    movwf STATUS
    movwf TRIS_A
    movlw B'10000111'
    clrf relays
    clrf timeout
    movlw B'10100000'
    movlw H'02'
    movwf numb
    movlw H'03'
    movwf numc
    movlw H'04'
    movwf numd
    goto got_star
    btfss relays,0
        goto decode
clrf COUNTER1
  movlw  0x20
  movwf  COUNTER2
bosdongu   nop
                    decfsz COUNTER1,f
                     goto   bosdongu
                     decfsz COUNTER2,f
                     goto   bosdongu
                      bcf relays,0
got_star
    call wait_strobe
    goto decode
    movf numa,W
    goto got_A
    goto get_#
    call wait_strobe
    goto decode
    movf numb,W
    goto got_B
    goto get_#
    call wait_strobe
    goto decode
    movf numc,W
    goto got_C
    goto get_#
    call wait_strobe
    goto decode
    movf numd,W
    goto got_D
    goto get_#
    call wait_strobe
    goto decode
    movlw H'01'
    goto got_1
    movlw H'02'
    goto decode
    goto got_11
    goto decode            ;*
    goto decode            ;#
    goto decode            ;5A
    goto decode            ;5B
    goto get_#
    goto decode
    goto got_#
    call wait_no_strobe
                            ;or timeout
    movwf PORTB
    end
yav arkadas birazda gayret gosterin,hatanın oldugu satırlar acıklama satırlarıymıs, // ları silince duzeldi.
derleme tamam ancak programın ne iş yapacagına emin degilim.senin düzenleme yapman gerekebilir.
üstat öncelikle cevabın için tşk.ler.
ancak ben bu işi iyi biliyorum demedim ayrıca zaten bilsem yardım istemezdim. herneyse derledim pic e yazdım fakat fark yok. doğru kodu yazınca role çekiyor buraya kadar sorun yok kodun devamıda var fakat kapatma şifresi girilince kapatıyordu ben şifre girerek kapatmak istemiyorum role aktif olunca 5 sn. sonra kendisi kapansın istiyorum. yinede ilgi ve yardımına minnettarım. kolay gelsin.
assambler i iyi kötü bildiginizi veya biraz anladıgınızı varsaymıstım,o yüzden üstünkörü acıklama yapıp gecmistim.kusura bakma.
önceki yazdıgımda süre cok kısa imiş,6ms de roleyi bıraktırıyormus.içiçe bir tane daha bos dongü ekleyince süre uzuyor.birde cihazınızda kac mhz lik kristal kullandıgınız bilmiyorum.4 mhz lik kristal için
bosdongu NOP
decfsz COUNTER3,F
goto bosdongu
decfsz COUNTER1,f
goto bosdongu
decfsz COUNTER2,f
goto bosdongu
bcf relays,0
olarak düzeltin,takriben 8 sn sonra rölenin bırakması lazım.
süreyi degistirmek için movlw 0x20 deki 20 rakamı ile oynayın.
birde en üste COUNTER3 equ 22 tanımlaması yapmayı unutmayın.
birde böyle deneyin bakalım ne olacak.
kodu anlattığınız gibi değiştirdim umarım yanlışlık yoktur ancak yine olmadı role çekiyor ama süreyle oyamama rağmen bırakmıyor
Kod:
    list    p=16f84a
OPTREG   equ     01
TRIS_A   equ     05
TRIS_B   equ     06
relays  equ    10
mfcode  equ    11
cntdown equ    12
timeout equ    13
slocnt1 equ    14
slocnt2 equ    15
numa    equ    16
numb    equ    17
numc    equ    18
numd    equ    19
COUNTER1 equ 20
COUNTER2 equ 21
COUNTER3 equ 22
init    goto start
rtc_interrupt
        goto rtc_int_1
        goto rtc_int_1
        bcf PORTB,4
rtc_int_1
        retfie                          ;return
counting
        retfie                          ;return
; subroutines
wait_strobe
        return
        return
wait_no_strobe
        return
start_timer
        movwf cntdown
        return
        movwf STATUS
        movwf TRIS_A
        movlw B'10000111'
        clrf relays
        clrf timeout
        movlw B'10100000'
        movlw H'02'
        movwf numb
        movlw H'03'
        movwf numc
        movlw H'04'
        movwf numd
        goto got_star
        btfss relays,0
        goto decode
        clrf COUNTER1
        movlw  0x20
        movwf  COUNTER2
bosdongu   nop
        decfsz COUNTER3,F
        goto bosdongu
        decfsz COUNTER1,f
        goto   bosdongu
        decfsz COUNTER2,f
        goto   bosdongu
        bcf relays,0
got_star
        call wait_strobe
        goto decode
        movf numa,W
        goto got_A
        goto get_#
        call wait_strobe
        goto decode
        movf numb,W
        goto got_B
        goto get_#
        call wait_strobe
        goto decode
        movf numc,W
        goto got_C
        goto get_#
        call wait_strobe
        goto decode
        movf numd,W
        goto got_D
        goto get_#
        call wait_strobe
        goto decode
        movlw H'01'
        goto got_1
        movlw H'02'
        goto decode
        goto got_11
        goto decode                     ;*
        goto decode                     ;#
        goto decode                     ;5A
        goto decode                     ;5B
        goto get_#
        goto decode
        goto got_#
        call wait_no_strobe
                                       ;or timeout
        movwf PORTB
    end
projeci3363
