erenuz40
- 1 Ocak 2021
- 6
- 1
- Yaş
- 21
Esp32 bluetooth modülünü kullanarak bir erişim noktası oluşturdum. Android telefonların bluetooth listesinde gözüküyor fakat ios'larda gözükmüyor.Bunun için yardım edebilecek var mı?
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEServer.h>
#define SERVICE_UUID "0000FFE0-0000-1000-8000-00805F9B34FB"
#define CHARACTERISTIC_UUID "0000FFE1-0000-1000-8000-00805F9B34FB"
//const int led = 2;
#define ONBOARD_LED 22
BLEServer* pServer = NULL;
BLECharacteristic* pCharacteristic = NULL;
bool deviceConnected = false;
bool oldDeviceConnected = false;
uint32_t value = 0;
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define CHARACTERISTIC_UUID "beb5483e-36e1-4688-b7f5-ea07361b26a8"
class MySecurity : public BLESecurityCallbacks { // BLE 클래스 pin code 함수
uint32_t onPassKeyRequest(){
ESP_LOGI(LOG_TAG, "PassKeyRequest");
return 123456;
void onPassKeyNotify(uint32_t pass_key){
ESP_LOGI(LOG_TAG, "The passkey Notify number:%d", pass_key);
bool onConfirmPIN(uint32_t pass_key){
ESP_LOGI(LOG_TAG, "The passkey YES/NO number:%d", pass_key);
vTaskDelay(5000);
return true;
bool onSecurityRequest(){
ESP_LOGI(LOG_TAG, "SecurityRequest");
return true;
void onAuthenticationComplete(esp_ble_auth_cmpl_t cmpl){
ESP_LOGI(LOG_TAG, "Starting BLE work!");
delay(1000);
digitalWrite(ONBOARD_LED,HIGH);
delay(100);
digitalWrite(ONBOARD_LED,LOW);
void onConnect(BLEServer* pServer) {
deviceConnected = true;
BLEDevice::startAdvertising();
void onDisconnect(BLEServer* pServer) {
class MyCallbacks: public BLECharacteristicCallbacks {
void onWrite(BLECharacteristic *pCharacteristic) {
std::string value = pCharacteristic->getValue();
if (value.length() > 0) {
for (int i = 0; i < value.length(); i++)
Serial.print(value);
void setup() {
Serial.begin(115200);
// pinMode(led,OUTPUT);
pinMode(ONBOARD_LED,OUTPUT);
BLEDevice::init("ESP32");
BLEDevice::setEncryptionLevel(ESP_BLE_SEC_ENCRYPT);
BLEDevice::setSecurityCallbacks(new MySecurity());
pServer = BLEDevice::createServer();
BLEService *pService = pServer->createService(SERVICE_UUID);
pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID,
BLECharacteristic:
ROPERTY_READ |
BLECharacteristic:
ROPERTY_WRITE
pCharacteristic->setValue("Hello World");
pService->start();
BLEAdvertising *pAdvertising = pServer->getAdvertising();
pAdvertising->start();
BLESecurity *pSecurity = new BLESecurity(); // pin code 설정
uint8_t rsp_key = ESP_BLE_ENC_KEY_MASK | ESP_BLE_ID_KEY_MASK;
uint32_t passkey = 123456; // PASS
uint8_t auth_option = ESP_BLE_ONLY_ACCEPT_SPECIFIED_AUTH_DISABLE;
esp_ble_gap_set_security_param(ESP_BLE_SM_SET_STATIC_PASSKEY, &passkey, sizeof(uint32_t));
pSecurity->setAuthenticationMode(ESP_LE_AUTH_REQ_SC_MITM_BOND);
pSecurity->setCapability(ESP_IO_CAP_OUT);
pSecurity->setKeySize(16);
esp_ble_gap_set_security_param(ESP_BLE_SM_ONLY_ACCEPT_SPECIFIED_SEC_AUTH, &auth_option, sizeof(uint8_t));
pSecurity->setInitEncryptionKey(ESP_BLE_ENC_KEY_MASK | ESP_BLE_ID_KEY_MASK);
esp_ble_gap_set_security_param(ESP_BLE_SM_SET_RSP_KEY, &rsp_key, sizeof(uint8_t));
Serial.println("Characteristic defined! Now you can read it in your phone!");
void loop() {
// put your main code here, to run repeatedly:
// notify changed value
if (deviceConnected) {
pCharacteristic->setValue((uint8_t*)&value, 4);
pCharacteristic->notify();
value++;
delay(10); // bluetooth stack will go into congestion, if too many packets are sent, in 6 hours test i was able to go as low as 3ms
// disconnecting
if (!deviceConnected && oldDeviceConnected) {
delay(500); // give the bluetooth stack the chance to get things ready
pServer->startAdvertising(); // restart advertising
Serial.println("start advertising");
oldDeviceConnected = deviceConnected;
// connecting
if (deviceConnected && !oldDeviceConnected) {
// do stuff here on connecting
// / Blink led when connected
delay(1000);
delay(100);
uint32_t value = 0;
return 123456;
vTaskDelay(5000);
return true;
return true;
delay(1000);
delay(100);
void setup() {
BLECharacteristic:
BLECharacteristic:
pService->start();
void loop() {
value++;
// disconnecting
// connecting
delay(1000);
delay(100);
