Exit status 1 hatası alıyorum
  • Konbuyu başlatan Konbuyu başlatan ceku7878
ceku7878
28 May 2020
KODUM AŞAĞIDAKİ GİBİ
Kod:
#include <Servo.h>
Servo servo_z_axis;
Servo servo_x_axis;
Servo servo_y_axis;
Servo servo_clamp;
int x_axis_degree = 90;
int y_axis_degree = 90;
int z_axis_degree = 85;
int clamp_degree = 90;
#define left_joystick_x = A0;
#define left_joystick_y = A1;
#define right_joystick_x = A2;
#define right_joystick_y = A3;
void setup() {
Serial.begin(9600);
servo_z_axis.attach(3);
servo_clamp.attach(5);
servo_x_axis.attach(6);
servo_y_axis.attach(9);
void loop() {
int left_joystick_x_value = analogRead(left_joystick_x);
int left_joystick_y_value = analogRead(left_joystick_y);
int right_joystick_x_value = analogRead(right_joystick_x);
int right_joystick_y_value = analogRead(right_joystick_y);
if(left_joystick_x_value < 340) y_axis_degree -=7;
else if(left_joystick_x_value > 680) y_axis_degree +=7;
if(left_joystick_y_value < 340) clamp_degree -=5;
else if(left_joystick_y_value > 680) clamp_degree +=5;
if(right_joystick_x_value < 340) x_axis_degree -=7;
else if(right_joystick_x_value > 680) x_axis_degree +=7;
if(right_joystick_y_value < 340) z_axis_degree -=7;
else if(right_joystick_y_value > 680) z_axis_degree +=7;
z_axis_degree = min(145, max(15, z_axis_degree));
x_axis_degree = min(175, max(40, x_axis_degree));
y_axis_degree = min(150, max(5, y_axis_degree));
clamp_degree = min(90, max(75, clamp_degree));
Serial.print("x_axis_degree : ");
Serial.print(x_axis_degree);
Serial.print(", y_axis_degree : ");
Serial.print(y_axis_degree);
Serial.print(", z_axis_degree 4 : ");
Serial.print(z_axis_degree);
Serial.print(", clamp_degree : ");
Serial.println(clamp_degree);
servo_clamp.write(clamp_degree);
servo_x_axis.write(x_axis_degree);
servo_y_axis.write(y_axis_degree);
servo_z_axis.write(z_axis_degree);
VERDİĞİ HATA ŞU ŞEKİLDE
c:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2021222-13984-j6x48n.59ma\sketch_mar22a\sketch_mar22a.ino: In function 'void loop()':
c:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2021222-13984-j6x48n.59ma\sketch_mar22a\sketch_mar22a.ino:15:25: error: expected primary-expression before '=' token
c:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2021222-13984-j6x48n.59ma\sketch_mar22a\sketch_mar22a.ino:30:42: note: in expansion of macro 'left_joystick_x'
c:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2021222-13984-j6x48n.59ma\sketch_mar22a\sketch_mar22a.ino:30:57: error: expected primary-expression before ')' token
c:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2021222-13984-j6x48n.59ma\sketch_mar22a\sketch_mar22a.ino:16:25: error: expected primary-expression before '=' token
c:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2021222-13984-j6x48n.59ma\sketch_mar22a\sketch_mar22a.ino:31:42: note: in expansion of macro 'left_joystick_y'
c:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2021222-13984-j6x48n.59ma\sketch_mar22a\sketch_mar22a.ino:31:57: error: expected primary-expression before ')' token
c:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2021222-13984-j6x48n.59ma\sketch_mar22a\sketch_mar22a.ino:17:26: error: expected primary-expression before '=' token
c:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2021222-13984-j6x48n.59ma\sketch_mar22a\sketch_mar22a.ino:32:43: note: in expansion of macro 'right_joystick_x'
c:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2021222-13984-j6x48n.59ma\sketch_mar22a\sketch_mar22a.ino:32:59: error: expected primary-expression before ')' token
c:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2021222-13984-j6x48n.59ma\sketch_mar22a\sketch_mar22a.ino:18:26: error: expected primary-expression before '=' token
c:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2021222-13984-j6x48n.59ma\sketch_mar22a\sketch_mar22a.ino:33:43: note: in expansion of macro 'right_joystick_y'
c:\Users\user\AppData\Local\Temp\.arduinoIDE-unsaved2021222-13984-j6x48n.59ma\sketch_mar22a\sketch_mar22a.ino:33:59: error: expected primary-expression before ')' token
Compilation error: Error: 2 UNKNOWN: exit status 1
sol joystick zaten tanımlı ne demek istediğinizi anlamadım
Makro kullanımında hata var.
C++:
Bu kodun içinde iki tane right_joystick_x var derleyici ikisini de A2 ile değiştiriyor sonuç:
C++:
A2_value = analogRead(A2);
Oluyor. Sence çalışır mı? Makro kullanmayı öğrenmelisin.
Hataları düzeltip çalıştırabildim ancak kendi etrafında dönmüyor. Her şeyi denedim ama kendi etrafında döndüremiyorum.Diğer hareketlerinde bir sıkıntı yok.Bu konuda ne yapmam gerekir?
Dönmez çünkü bu şekilde tasarlanmış. Açıları belirli aealıklarta sınırlandırmışsın aşağıdaki satırlarla.
C++:
Kusura bakmayın bu ilk projem o yüzden zorlanıyorum.Sınırlamaları genişletsem bile değişiklik olmuyor.Bütün hareketleri çalışıyor ama kendi etrafında dönmüyor
Hobi Servolar kendi etrafında dönemez zaten maksimum 359 derece dönebilir.
projeci3363
