TİA V15.1 Modify system kısmında kurulum hatası
20 May 2020
İşe yaramayan denemelerim: SQL Server 2014’ü kaldırıp yeniden kurulum denedim, ancak sorun devam etti. İnternet güvenlik duvarını ve güncelleştirmeleri kapattım, yine çözüm olmadı. Yardımcı olursanız sevinirim. Saygılarımla.
2026.06.03 10:17:36 - Year.Month.Day - Log start
BUNDLE: SIMATIC TIA Portal STEP 7 Professional V15.1 Upd5 - WinCC Advanced V15.1 Upd5
SEBU Version: Advanced:TIA.rgs.RTM_15010005:V15.01.00.05_03.01.00.01
OS: Microsoft Windows 11 Home Single Language Home Premium Edition, 64-bit, build 26200
COMMANDLINE: C:\Program Files (x86)\Common Files\Siemens\Automation\Siemens Installer Assistant\407\SIA2.exe /l1033 /starter /bundlepath=C:\USERS\YAZIL\APPDATA\LOCAL\TEMP\TIA PORTAL STEP 7 PROFESSIONAL WINCC ADVANCED V15.1 UPD5\InstData
INSTALLDIR: C:\Program Files\Siemens\Automation
SETUPLANGUAGE: 1033
PRODUCTLANGUAGES: 1033
CHANGES: (+)DotNet_Updater;(o)SQLNCLI;(+)INSTSQL2014EXP;(+)CONFSQL2014EXP;(+)SYMLINK;(+)SYMLINKADD;(+)OPCCORECOMP;(+)OPCCORECOMP64;(+)OPCNETAPI;(+)OPCNETAPI45;(+)NCMGPRS64;(+)NCMFWL64;(+)OPC;(+)SECON;(+)S7DOS64;(+)S7DOS;(+)S7EDB;(+)Automation Software Updater;(+)TIA_Portal;(+)MU_Client;(+)HWCN-HWCOL;(+)SUPBASEH02;(+)SUPBASEH03;(+)SUPBASEH04;(+)SUPBASETO01;(+)SUPBASETO02;(+)SUPBASEWCF01;(+)TIAP_SIMATIC;(+)TIAP_SIMATIC32;(+)STEP7;(+)WinCC Runtime Advanced Simulator;(+)PTSymLib;(+)PTTouchInput;(+)HM_AllEditions;(+)HM_NoBasic;(+)UMC64;(+)LicenseManager;(+)STOP_ALMSERVICE;(+)AlmPanelPlugin64;(+)Prosave;(+)TIA_ES;(+)TIA_ES32;(+)WinCC_Tr_Mandatory;(+)WinCC_TrC_All;(+)WinCC_TrC_CAP;(+)CoRtHmiRTmDriver64;(+)HMIRTMV11;(+)RT_Adv_Sim;(+)TIACOMPCHECK;(+)TIA_Opns;(+)TIAADMIN;(+)AWB_SOFT;(+)AWB_ALM;(+)AWB_TIAUMAC;(+)MUSERVER
There are NO severe messages before the installation
10:17:36 | BEGIN. Execution started.
10:17:40 | OK RunningProcesses () Complete
10:17:40 | OK InventoryBefore (A) Complete
10:17:40 | OK Citamis (Before) Complete
10:17:55 | OK SecurityControlFeature (ReturnFeatures) Complete
10:17:55 | OK StartApplBefore (TIAP15_1::[INSTALLDIR]BIN\SIEMENS.AUTOMATION.OBJECTFRAME.FILESTORAGE.SERVER.EXE)Complete
10:17:55 | OK StartApplBefore (TIAADMIN::[INSTALLDIR]SERVER\NODE.EXE)Complete
10:17:55 | OK StartApplBefore (TIAP15_1::[INSTALLDIR]X64\BIN\SIEMENS.AUTOMATION.OBJECTFRAME.FILESTORAGE.SERVER.EXE)Complete
10:17:55 | OK ClassicCompPrepare () Complete
10:17:55 | OK ProductRegistration (Before) Complete
10:17:55 | OK ClassicCompAfterUninstall () Complete
10:17:55 | OK SetupUnit (DotNet_Updater) Complete Foreign AddLocal
10:17:55 | OK Checkpoint (RE) Complete
10:17:56 | OK SetupUnit (SQLNCLI) Complete Foreign Reinstall
10:19:32 |ERROR AdsWorkerClassicProduct::OnWorkerCompleted(): - ClassicProduct setup result: 1: Info: SQL Installation was not Successful
10:19:32 | FAIL! SetupUnit (INSTSQL2014EXP) Failed ClassicProductAddLocal
10:19:32 | FAIL! Checkpoint (E) Complete
10:19:32 |ERROR ExecutionEngine::StartNextStepAsync(): - Execution has been cancelled. Probably because of some process(es) running on the machine
10:19:32 | SKIP! SetupUnit (CONFSQL2014EXP) Skip ClassicProductAddLocal
10:19:32 | SKIP! Checkpoint (E) Skip
10:19:32 | SKIP! SetupUnit (SYMLINK) Skip Foreign AddLocal
10:19:32 | SKIP! SetupUnit (SYMLINKADD) Skip Foreign AddLocal
10:19:32 | SKIP! SetupUnit (OPCCORECOMP) Skip Foreign AddLocal
10:19:32 | SKIP! SetupUnit (OPCCORECOMP64) Skip Foreign AddLocal
10:19:32 | SKIP! SetupUnit (OPCNETAPI) Skip Foreign AddLocal
10:19:32 | SKIP! SetupUnit (OPCNETAPI45) Skip Foreign AddLocal
10:19:32 | SKIP! SetupUnit (NCMGPRS64) Skip ClassicComponentAddLocal
10:19:32 | SKIP! SetupUnit (NCMFWL64) Skip ClassicComponentAddLocal
10:19:32 | SKIP! SetupUnit (OPC) Skip ClassicComponentAddLocal
10:19:32 | SKIP! SetupUnit (SECON) Skip ClassicComponentAddLocal
10:19:32 | SKIP! SetupUnit (S7DOS64) Skip ClassicComponentAddLocal
10:19:32 | SKIP! SetupUnit (S7DOS) Skip ClassicComponentAddLocal
10:19:32 | SKIP! SetupUnit (S7EDB) Skip ClassicComponentAddLocal
10:19:32 | SKIP! SetupUnit (Automation Software Updater)Skip ClassicComponentAddLocal
10:19:32 | SKIP! SecurityControl (TIA_Portal) Skip
10:19:32 | SKIP! SetupUnit (TIA_Portal) Skip PlusMain AddLocal
10:19:32 | SKIP! SetupUnit (MU_Client) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (HWCN-HWCOL) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (SUPBASEH02) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (SUPBASEH03) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (SUPBASEH04) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (SUPBASETO01) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (SUPBASETO02) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (SUPBASEWCF01) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (TIAP_SIMATIC) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (TIAP_SIMATIC32) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (STEP7) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (WinCC Runtime Advanced Simulator)Skip ClassicComponentAddLocal
10:19:32 | SKIP! SetupUnit (PTSymLib) Skip ClassicComponentAddLocal
10:19:32 | SKIP! SetupUnit (PTTouchInput) Skip ClassicComponentAddLocal
10:19:32 | SKIP! SetupUnit (HM_AllEditions) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (HM_NoBasic) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SecurityControl (UMC64) Skip
10:19:32 | SKIP! SetupUnit (UMC64) Skip PlusMain AddLocal
10:19:32 | SKIP! SecurityControl (LicenseManager) Skip
10:19:32 | SKIP! SetupUnit (LicenseManager) Skip ClassicProductAddLocal
10:19:32 | SKIP! SetupUnit (STOP_ALMSERVICE) Skip Foreign AddLocal
10:19:32 | SKIP! SetupUnit (AlmPanelPlugin64) Skip ClassicComponentAddLocal
10:19:32 | SKIP! SetupUnit (Prosave) Skip ClassicProductAddLocal
10:19:32 | SKIP! SetupUnit (TIA_ES) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (TIA_ES32) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (WinCC_Tr_Mandatory) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (WinCC_TrC_All) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (WinCC_TrC_CAP) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (CoRtHmiRTmDriver64) Skip ClassicComponentAddLocal
10:19:32 | SKIP! SecurityControl (HMIRTMV11) Skip
10:19:32 | SKIP! SetupUnit (HMIRTMV11) Skip PlusMain AddLocal
10:19:32 | SKIP! SetupUnit (RT_Adv_Sim) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (TIACOMPCHECK) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SecurityControl (TIA_Opns) Skip
10:19:32 | SKIP! SetupUnit (TIA_Opns) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (TIAADMIN) Skip PlusMain AddLocal
10:19:32 | SKIP! SetupUnit (AWB_SOFT) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (AWB_ALM) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (AWB_TIAUMAC) Skip PlusOptionalAddLocal
10:19:32 | SKIP! SetupUnit (MUSERVER) Skip PlusMain AddLocal
10:19:32 | SKIP! ClassicCompAfterInstall () Skip
10:19:32 | SKIP! ClassicCompRollback () Skip
10:19:32 | SKIP! HspInstall () Skip
10:19:32 | SKIP! MspInstall () Skip
10:19:32 | SKIP! StartApplAfter (TIAP15_1::[INSTALLDIR]BIN\INSTALLROOTCERTIFICATE.EXE)Skip
10:19:32 | SKIP! StartApplAfter (TIAADMIN::[INSTALLDIR]SERVER\NODE.EXE)Skip
10:19:32 | SKIP! StartApplAfter (TIAP15_1::[INSTALLDIR]BIN\SIEMENS.AUTOMATION.GENERATOR.FRAMEWORK.EXE)Skip
10:19:32 | SKIP! StartApplAfter (TIAP15_1::C:\WINDOWS\SYSWOW64\S7EPATSX.EXE)Skip
10:19:32 | SKIP! StartApplAfter (TIAP15_1::C:\WINDOWS\SYSWOW64\S7EPAESX.EXE)Skip
10:19:32 | SKIP! StartApplAfter (TIAP15_1::[INSTALLDIR]BIN\SIEMENS.SIMATIC.HWCN.INTERPRETER.IG.GSD.GENERATOR.EXE)Skip
10:19:32 | SKIP! ProductRegistration (After) Skip
10:19:32 | SKIP! InventoryAfter (Z) Skip
10:19:32 | SKIP! LicenseTransfer (False) Skip
10:19:32 | SKIP! SetupReport () Skip
10:19:32 | OK SetupIsComplete () Complete
10:19:32 | OK Citamis (After) Complete
10:19:33 | OK SetupSummary () Complete
10:19:33 | END. Execution completed.
Intermediate ExitCode after execution queue : 1603 - Exit code means: Installation failed (InstallFailure)
Errors: 2
Warnings: 0
KahramanmarasliMühendis
