InteropServices.COMException
22 Eyl 2010
merhaba arkadaşlar, S7-300 PLC ye Cp5611 kart ile bağlandım. "Softing OPC" server a VS2010 express C# ile Client yazıp SQL e veri kaydetmek istiyorum. internette dolaşan şu örnek kodu derliyorum ama hata veriyor.
Kod:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using OPCAutomation;
namespace OPC2
    public partial class Form1 : Form
        public OPCAutomation.OPCServer AnOPCServer;
        public OPCAutomation.OPCServer ConnectedOPCServer;
        public OPCAutomation.OPCGroups ConnectedServerGroup;
        public OPCAutomation.OPCGroup ConnectedGroup;
        public string Groupname;
        int ItemCount;
        Array OPCItemIDs = Array.CreateInstance(typeof(string), 10);
        Array ItemServerHandles = Array.CreateInstance(typeof(Int32), 10);
        Array ItemServerErrors = Array.CreateInstance(typeof(Int32), 10);
        Array ClientHandles = Array.CreateInstance(typeof(Int32), 10);
        Array RequestedDataTypes = Array.CreateInstance(typeof(Int16), 10);
        Array AccessPaths = Array.CreateInstance(typeof(string), 10);
        Array WriteItems = Array.CreateInstance(typeof(object), 10);
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
        private void btnConnect_Click(object sender, EventArgs e)
            try
                string IOServer = "Kepware.KEPServerEX.V5";
                string IOGroup = "OPCGroup1";
                ConnectedOPCServer = new OPCAutomation.OPCServer();
                ConnectedOPCServer.Connect(IOServer, "");
                ConnectedGroup = ConnectedOPCServer.OPCGroups.Add(IOGroup);
                ConnectedGroup.DataChange += new DIOPCGroupEvent_DataChangeEventHandler(ObjOPCGroup_DataChange);
                ConnectedGroup.UpdateRate = 1000;
                ConnectedGroup.IsSubscribed = ConnectedGroup.IsActive;
                ItemCount = 2;
                OPCItemIDs.SetValue("Channel2.Device1.R1", 1);
                ClientHandles.SetValue(1, 1);
                OPCItemIDs.SetValue("Channel2.Device1.R2", 2);
                ClientHandles.SetValue(2, 2);
                ConnectedGroup.OPCItems.DefaultIsActive = true;
                ConnectedGroup.OPCItems.AddItems(ItemCount, ref OPCItemIDs, ref ClientHandles, out ItemServerHandles, out ItemServerErrors, RequestedDataTypes, AccessPaths);
            catch (Exception ex)
                MessageBox.Show(ex.ToString());
        private void btnDisconnect_Click(object sender, EventArgs e)
            ConnectedOPCServer.Disconnect();
        private void ObjOPCGroup_DataChange(int TransactionID, int NumItems, ref Array ClientHandles, ref Array ItemValues, ref Array Qualities, ref Array TimeStamps)
            try
                for (int i = 1; i <= NumItems; i++)
                    if ((Convert.ToInt32(ClientHandles.GetValue(i)) == 1))
                        textBox1.Text = ItemValues.GetValue(i).ToString();
                    if ((Convert.ToInt32(ClientHandles.GetValue(i)) == 2))
                        textBox2.Text = ItemValues.GetValue(i).ToString();
        private void textBox1_TextChanged(object sender, EventArgs e)
        private void btnWrite1_Click(object sender, EventArgs e)
            try
                WriteItems.SetValue(textBox4.Text, 1);
                ConnectedGroup.SyncWrite(ItemCount, ref ItemServerHandles, ref WriteItems, out ItemServerErrors);
Hata mesajı :
Kod:
System.Runtime.InteropServices.COMException (0x80040154): Retrieving the COM class factory for component with CLSID {28E68F9A-8D75-11D1-8DC3-3C302A000000} failed due to the following error: 80040154 Sınıf kaydedilmemiş (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
   at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck)
   at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache)
   at System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipVisibilityChecks, Boolean skipCheckThis, Boolean fillCache)
   at System.Activator.CreateInstance(Type type, Boolean nonPublic)
   at System.Activator.CreateInstance(Type type)
   at WindowsFormsApplication1.Form1.button1_Click(Object sender, EventArgs e) in C:\Documents and Settings\plc\belgelerim\visual studio 2010\Projects\WindowsFormsApplication1\WindowsFormsApplication1\Form1.cs:line 45
hata mesajıyla ilgili internette 32bit/64 bit derleyici ayarlarına atıfta bulunulmuş, derleyiciyi x86 olarak ayarladım mesaj değişmedi. regasm ile automation.dll in registry'ye kayıt edilmesiyle alakalı yazılar mevcut. framework 4 klasöründen kayıt etmeyi denedim yine olmadı. daha önce benzer kodlarla TCP den kepware le schneider PLC ye baglandığımı hatırlıyorum. registry ile ilgili hiç bir ayar yapmadan değer okumuştum sanırım. fikri olan?
Arkadaşlar regsvr32.exe ile OPCautomation.dll i kayıt ederken hata veriyor. DCOM güvenlik ayarlarıyla ilgili bir problem var sanırım.
Bilgisayarında kurulu herhangi bir opc server mevcut mu ? Yok ise kurup denermisin eğer sorun dcom dan kaynaklanıyor ise diğer opc server larda çalışmayacaktır.
Softing OPC server kullanıyorum. demo versiyon.
komut satırına "C:\Windows\System32\regsvr32.exe /i OPCAutomation.dll" şeklinde giriş yapıca şöyle bir hata mesajı alıyorum
"DLLREGISTERSERVER GİRİŞ NOKTASI BULUNAMADI BU DOSYA KAYDETTİRİLEMEZ."
DCOM ayarlarıyla ilgili bir durum var... Mideme ağrı girdi :)
kod içersinde bu satırda:string IOServer = "Kepware.KEPServerEX.V5";
Keepware'e bağlanmaya çalışıyor. Oysa softing olmalı. uygulama'yı x86 seçmeniz gerekliydi zaten yapmışsınız. Daha söylenecek bir çok şey var ama bence bu kodla uğraşma, Keepware'den clientace satın alın tüm opc serverlara bağlanırsınız. Sizin kodunuz sadece version 1.1 opc serverlara bağlanır. Ver.1.1 için için graybox opc wrapper kullansanız daha iyi olur. Madem bu işe para harcanacak bence profinet ile haberleşin. Mpi protokolü çok kötü bir protokol. Seçtiğiniz protokole göre .net component'de bulabilirsiniz. Daldan dala atladım umarım kafanızı karıştırmamışımdır. Ama Siemens plc'ler ile haberleşmek gerçekten çok zor, benzer şekilde opc server ile de aynı şekilde zor. Not: Sizin kodunuzun daha gelişmişini keepware sitesinden indirebilirsiniz. Fakat oda softlink'e bağlanmayacaktır. Opc server versiyonlarını kontrol edin.
Ümitgüçlü71
