koddaki hatayı çözemedim YARDIM!!!
kaynakkod
13 Haz 2013
Kod:
#include<LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int  trig1=6;
const int echo1=7;
const int  trig2=8;
const int echo2=9;
const int  trig3=10;
const int echo3=13;
double sure1;
int sure2;
int sure3;
int X;
int Y;
int Z;
char d;
void setup()
 pinMode(trig1,OUTPUT);
 pinMode(echo1,INPUT);
 pinMode(trig2,OUTPUT);
 pinMode(echo2,INPUT);
 pinMode(trig3,OUTPUT);
 pinMode(echo3,INPUT);
lcd.begin(16,2);
lcd.clear();
Serial.begin(9600);
lcd.display();
void loop()
for(int o=0; o<200; o++)
  digitalWrite(trig1,HIGH);
  delay(1);
  digitalWrite(trig1,LOW);
  sure1=pulseIn(echo1,HIGH);
  Y=(((sure1/2)/28,5*10)-67)*-1;
  digitalWrite(trig2,HIGH);
  delay(1);
  digitalWrite(trig2,LOW);
  sure2=pulseIn(echo2,HIGH);
  X=(((sure2/2)/28.5*10)+10);
  digitalWrite(trig3,HIGH);
  delay(1);
  digitalWrite(trig3,LOW);
  sure3=pulseIn(echo3,HIGH);
  Z=(((sure3/2)/28,5*10)-35);
lcd.home();
lcd.clear();
lcd.setCursor(0,0);
lcd.print("X=");
lcd.print(Px);
Serial.println("X=");
Serial.println(X);
lcd.print("mm");
lcd.home();
lcd.setCursor(8.0);
lcd.print("Y=");
lcd.print(Py);
Serial.println("Y=");
Serial.println(Y);
lcd.print("mm");
lcd.home();
lcd.setCursor(0,1);
lcd.print("Z=");
lcd.print(Pz);
Serial.println("Z=");
Serial.println(Z);
lcd.print("mm");
lcd.setCursor(8,1);
lcd.print("PLATE 1");
if(Serial.available()>0)
  d=Serial.read();
  if(d=='a')
    Serial.print(X);
    Serial.print(Y);
    Serial.print(Z);
  delay(100);
YUKARIDAKİ KODDA BU HATAYI ALIYORUM .HATA AŞAĞIDA. ŞU LİNK'DEKİ PROJENİN AYNISINI YAPMAK İSTİYORUM FAKAT ARDUİNO KISMINDA BU HATAYI ALIYORUM VİDEODAKİ KOD ÇALIŞIYOR.
VİDEO LİNKİ =(
Kod:
C:\Users\doÄŸantekin\Documents\Arduino\PPP_kartezyen_robot\PPP_kartezyen_robot.ino: In function 'void loop()':
PPP_kartezyen_robot:68: error: 'Px' was not declared in this scope
PPP_kartezyen_robot:75: error: no matching function for call to 'LiquidCrystal::setCursor(double)'
C:\Users\doÄŸantekin\Documents\Arduino\PPP_kartezyen_robot\PPP_kartezyen_robot.ino:75:18: note: candidate is:
In file included from C:\Users\doÄŸantekin\Documents\Arduino\PPP_kartezyen_robot\PPP_kartezyen_robot.ino:1:0:
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:82:8: note: void LiquidCrystal::setCursor(uint8_t, uint8_t)
   void setCursor(uint8_t, uint8_t);
C:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src/LiquidCrystal.h:82:8: note:   candidate expects 2 arguments, 1 provided
PPP_kartezyen_robot:78: error: 'Py' was not declared in this scope
PPP_kartezyen_robot:88: error: 'Pz' was not declared in this scope
exit status 1
Bende tan bilmiyorum fakat Py Px Pz ne ise o tanımlanmamış diyor.Yada kütüphane eksik
Kod:
const int  trig1=6;
const int echo1=7;
const int  trig2=8;
const int echo2=9;
const int  trig3=10;
const int echo3=13;
double sure1;
int sure2;
int sure3;
int X;
int Y;
int Z;
[/QUOTE]
int Px,Py,Pz;
burada yer alabilir.
[QUOTE="kaynakkod, post: 751168, member: 289444"]
char d;
void setup()
lcd.begin(16,2);
lcd.clear();
Serial.begin(9600);
lcd.display();
void loop()
  delay(1);
  delay(1);
  delay(1);
lcd.home();
lcd.clear();
lcd.setCursor(0,0);
lcd.print("X=");
lcd.print(Px);
Serial.println(X);
lcd.print("mm");
lcd.home();
lcd.setCursor(8.0);
lcd.print("Y=");
lcd.print(Py);
Serial.println(Y);
lcd.print("mm");
lcd.home();
lcd.setCursor(0,1);
lcd.print("Z=");
lcd.print(Pz);
Serial.println(Z);
lcd.print("mm");
lcd.setCursor(8,1);
  d=Serial.read();
  if(d=='a')
    Serial.print(X);
    Serial.print(Y);
    Serial.print(Z);
  delay(100);
VİDEO LİNKİ =(
Kod:
exit status 1
lcd.print(Px); burada Px yukarıda tanımlanmamış, aynı şekide Pz ve Py de tanımlı değil.
burada gördüğüm Px = X ile aynı veya stringe çevrilmiş hali olmalı
kst1212
