LİBNODAVE İLE S71200-VB HABERLEŞMESİ
kurusaray
14 Tem 2008
Merhaba. Arkadaşlar libnodave kütüphanesi ile TCP/IP üzerinden basic 2010 ile haberleşmek istiyorum. İnternetteki bazı kodları denedim ama haberleşmiyor. Elinde örnek uygulama olan arkadaş paylaşabilirse çok sevinirim. Ayırca plc tarafına kod yazmak gerekiyormu?
Denediğim kod:
Public Class Form1
'Dim b As Integer
Private Sub Form1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
ToolStripStatusLabel1.Text = "Disconnected."
ComboBox1.SelectedItem = 0
Timer1.Enabled = True
End Sub
Private Sub ExitToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ExitToolStripMenuItem.Click
If Connection Then
dc.disconnectPLC()
End If
Me.Close()
End Sub
Private Sub ConnectPLCToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ConnectPLCToolStripMenuItem.Click
fds.rfd = libnodave.openSocket(102, IP)
fds.wfd = fds.rfd
If fds.rfd > 0 Then ' if step 1 is ok
di = New libnodave.daveInterface(fds, "IF1", 0, libnodave.daveProtoISOTCP, libnodave.daveSpeed187k)
di.setTimeout(5000) ' Make this longer if you have a very long response time
res = di.initAdapter
If res = 0 Then ' init Adapter is ok
dc = New libnodave.daveConnection(di, 0, 0, 1) ' rack amd slot don't matter in case of MPI
res = dc.connectPLC()
If res = -1 Then
Connection = True
ToolStripStatusLabel1.Text = "Connected " + IP
End If
End If
End If
End Sub
Private Sub DisconnectPLCToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles DisconnectPLCToolStripMenuItem.Click
dc.disconnectPLC()
End Sub
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
'd As Single
Dim a, c As Byte
If Connection Then
res = dc.readBytes(libnodave.daveFlags, 0, 1, 16, buf)
If res = 0 Then
Data1.Text = Str(dc.getS32)
Data2.Text = Str(dc.getS32)
Data3.Text = Str(dc.getS32)
Data4.Text = Str(dc.getFloat)
Else
ToolStripStatusLabel1.Text = "Read data. " + libnodave.daveStrerror(res)
End If
res = dc.readBytes(libnodave.daveInputs, 0, 1, 16, buf)
If res = 0 Then
a = Str(dc.getS8)
If IsBitSet(a, 0) Then
Panel1.BackColor = Color.Lime
Else
Panel1.BackColor = Color.DarkGreen
End If
If IsBitSet(a, 1) Then
Panel2.BackColor = Color.Lime
Else
Panel2.BackColor = Color.DarkGreen
End If
If IsBitSet(a, 2) Then
Panel3.BackColor = Color.Lime
Else
Panel3.BackColor = Color.DarkGreen
End If
If IsBitSet(a, 3) Then
Panel4.BackColor = Color.Lime
Else
Panel4.BackColor = Color.DarkGreen
End If
Else
End If
res = dc.readBytes(libnodave.daveOutputs, 0, 1, 16, buf)
If res = 0 Then
a = Str(dc.getS8)
Panel5.BackColor = Color.Lime
Else
Panel5.BackColor = Color.DarkGreen
End If
Panel6.BackColor = Color.Lime
Else
Panel6.BackColor = Color.DarkGreen
End If
Panel7.BackColor = Color.Lime
Else
Panel7.BackColor = Color.DarkGreen
End If
Panel8.BackColor = Color.Lime
Else
Panel8.BackColor = Color.DarkGreen
End If
Else
End If
If res = 0 Then
c = Str(dc.getS8)
If IsBitSet(c, 0) Then
Panel9.BackColor = Color.Lime
Else
Panel9.BackColor = Color.DarkGreen
End If
If IsBitSet(c, 1) Then
Panel10.BackColor = Color.Lime
Else
Panel10.BackColor = Color.DarkGreen
End If
If IsBitSet(c, 2) Then
Panel11.BackColor = Color.Lime
Else
Panel11.BackColor = Color.DarkGreen
End If
If IsBitSet(c, 3) Then
Panel12.BackColor = Color.Lime
Else
Panel12.BackColor = Color.DarkGreen
End If
Else
End If
Else
Data1.Text = "****"
Data2.Text = "****"
Data3.Text = "****"
Data4.Text = "****"
Panel1.BackColor = Color.Gray
Panel2.BackColor = Color.Gray
Panel3.BackColor = Color.Gray
Panel4.BackColor = Color.Gray
Panel5.BackColor = Color.Gray
Panel6.BackColor = Color.Gray
Panel7.BackColor = Color.Gray
Panel8.BackColor = Color.Gray
Panel9.BackColor = Color.Gray
Panel10.BackColor = Color.Gray
Panel11.BackColor = Color.Gray
Panel12.BackColor = Color.Gray
End If
End Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim a As Integer
a = Int(TextBox1.Text)
buf(0) = Int(TextBox2.Text)
If ComboBox1.SelectedItem = "Inputs" Then
res = dc.writeBytes(libnodave.daveInputs, 0, a, 1, buf)
End If
If ComboBox1.SelectedItem = "Outputs" Then
res = dc.writeBytes(libnodave.daveOutputs, 0, a, 1, buf)
End If
If ComboBox1.SelectedItem = "Flags" Then
res = dc.writeBytes(libnodave.daveFlags, 0, a, 1, buf)
End If
End Sub
Private Sub MenuStrip1_ItemClicked(ByVal sender As System.Object, ByVal e As System.Windows.Forms.ToolStripItemClickedEventArgs) Handles MenuStrip1.ItemClicked
End Sub
Private Sub StatusStrip1_ItemClicked(ByVal sender As System.Object, ByVal e As System.Windows.Forms.ToolStripItemClickedEventArgs) Handles StatusStrip1.ItemClicked
End Sub
End Class
Arkadaşlar elimde yeni bir iş var pc ile plc den aldığı analog bilgileri xy grafiğinde çizdirmem lazım.Kullanacağım plc siemes marka sizce libnodave kullanmak için s7-1200 mü yoksa s7-300 mü kullanayım?
SudeN1903
