Paradox Programlama klavuzu
serkanspy
13 Ağu 2009
PARADOX PANELLER
PARADOX 728 - 738
PARADOX 728 için Fabrikasyon Şifresi : 2828
PARADOX 738 için Fabrikasyon Şifresi : 3838
KISMİ PROGRAMLAMA:
ENTER/282828/208/1/4/7/9/12/ ENTER/ ENTER
ŞİFRE DEĞİŞTİRME:
ENTER/ESKİ ŞİFRE /10/10/YENİ ŞİFRE/ ENTER/ ENTER
ENTER/ESKİ ŞİFRE /10/1/YENİ ŞİFRE/ ENTER/ ENTER
ENTER/ESKİ ŞİFRE /10/17/YENİ ŞİFRE/ ENTER/ ENTER
ÇIKIŞ SÜRESİ:
ENTER/2828/247/000(SN) / ENTER/ ENTER
GİRİŞ SÜRESİ:
ENTER/2828/248/000(SN) / ENTER/ ENTER
SİREN ÇALMA SÜRESİ:
ENTER/2828/250/000(DK) / ENTER/ ENTER
ANİ ZOON:
ENTER/2828/224/ANİ OLACAK ZOONLAR YAKILIR / ENTER/ ENTER
ZAMAN SAATİ:
ENTER/2828/MEM/00:00(SAAT) / ENTER/ ENTER
ZON ARTTIRMA:
ENTER/2828/208/(mem yanıyorsa söndür) / ENTER/ ENTER
ENTER/2828/210/8/ ENTER/ ENTER
OTOMATİK DEVREYE ALMA:
ENTER/2828/245/000(SAAT)/
ENTER/246/000(DAKİKA)/
ENTER/206/5/ ENTER/ ENTER
24 SAAT ZOON’U:
ENTER/2828/220/ANİ OLACAK ZOONLAR YAKILIR / ENTER/ ENTER
HIZLI ALGILAMA:
ENTER/2828/010/ ENTER/ ENTER
SIRALI GECİKME:
ENTER/2828/228/(giriş dedektör’ü hariç sıralı geçilecek detektörler)/ENTER/ ENTER
YATAKBAŞI BUTONU:
ENTER/2828/206/2/3/8/ENTER/ ENTER
YATAKBAŞI ŞİFRE:
ENTER/2828/202/1/ENTER
/200/1/ENTER/ ENTER
GÖZÜN GÖRÜP ALARM VERMEMESİ:
ENTER/2828/240/1/2/ENTER
212/gecikecek zoon/ENTER/ENTER
DUMAN DEDEKTÖRÜ RESETİ:
ENTER/2828/195/BYP/ENTER
/196/5/10/ENTER
/198/2ND/6/ENTER
/254/10/10/ENTER/ENTER
NOT:DUMAN DEDEKTÖRÜ 3 NOLU ZOON’a BAĞLANIR.EĞER 4 KULLANILIYORSA İPTAL EDİLİR.
ENTER/2828/210/1/ENTER/ENTER
SİSTEM A ve B :
ENTER/2828/200/1/ENTER(SİSTEM A)
/202/2/ENTER/ENTER(SİSTEM B)
ENTER/2828/206/8/ENTER/ENTER(11ve12 için)
ENTER/2828/240/1/8/ENTER/ENTER(zoon ve keyped zoon)
ENTER/2828/242/2/ENTER/ENTER(8.zoon yerine 2.zoon geçer)
728 AS 290 PGM ÇIKIŞI:
ENTER/2828/195/8/2ND/ENTER
/196/2ND/6/ENTER
/198/2/2ND/ENTER/ENTER
728 AS 295 PGM ÇIKIŞI:
ENTER/2828/195/2ND/2ND/ENTER
/196/2ND/6/ENTER
738 AS 89 PGM ÇIKIŞI:
/196/2/12/ENTER
/198/2ND/4/ENTER/ENTER
AKILLI ZOON:
GECİKME SÜRESİ:1-16SN 2-32SN 3-48SN 4-64SN 5-80SN 6-96SN
7-112SN 8-128SN 9-144SN 10-160SN 11-176SN 12-192SN
BYP-208SN MEM-224SN TRBL-208SN 2ND-208SN
ENTER/2828/059/ZAMAN KODU GİRİLİR/2ND/ENTER/ENTER
ENTER/2828/212/AKILLI OLARAK ÇALIŞACAK ZOON /ENTER/ENTER
İKİNCİ GECİKMELİ ZOON:
ENTER/2828/232/2. GECİKECEK ZOON /ENTER/ENTER
KURULMADA SİREN SÜRESİ:
ENTER/2828/206/MEM/ENTER/ENTER (Kurulur ve iptal edilirken)
DUBLE ZOON:
ENTER/2828/210/6/ENTER/ENTER
ARIZA UYARISI:
ENTER/2828/210/9/ENTER/ENTER
TRBL:
1. AKÜ
2. ELEKTİRİK
3. SİREN
4. SİREN LİMİT
5. AUX
6. HABERLEŞME
7. ZAMAN SAATİ
8. TAMPER
9. TEL HATTI
10. YANGIN ZOONU
PARADOX 3.10 Haberleşme Programı
HABELEŞME PIROGRAMI:7272 / 7 / 04 / (ŞEHİR İÇİ ) (telno)[ 9X TRBL ]
(telno)[ 9X TRBL ]
(ŞEHİR DIŞI) 0(alankodu) (telno)[ 5X TRBL ]
0(alankodu) (telno) [ 5X TRBL ]
0000 / 0000 ABONE NO / ENTER
11 / 31 32 33 34 35 36 2ND 2ND 2ND 2ND / ENTER
23 / 37 38 39 41 42 43 / ENTER
36 / 21 22 23 24 25 26 2ND 2ND 2ND 2ND /ENTER
42 / 81 82 83 84 85 86 2ND 2ND 2ND 2ND /ENTER
60 / 44 45 46 47 48 49 2ND 2ND 2ND 2ND 51 52 53 54 55 56 57 58 59 61 71 72 62 73 74 75 / ENTER
/ ENTER / ENTER / 7272 / 086 / 5 7 12 ( YAK ) / ENTER / 038 / 3 3 /ENTER /ENTER
PARADOX ESPRİT 727
İkinci Rakam Olarak ( 2. PGM )
0 yazılırsa = Çıkış Süresince eksi Çıkış verir.
1 yazılırsa = Kurulu durumda eksi Çıkış verir.
2 yazılırsa = Kurulu değilken eksi çıkış verir.
3 yazılırsa = 2ND Tuşuna basılı olduğu sürece eksi Çıkış verir.
4 yazılırsa = Yangın Alarmında eksi Çıkış verir.
5 yazılırsa = Alarm hallinde eksi Çıkış verir.
6 yazılırsa = Sabotaj Alarmı hallinde eksi Çıkış verir.
7 yazılırsa = Çıkış Süresi içinde ve Alarm durumda eksi çıkış verir.
8 yazılırsa = Alarm halinde eksi Çıkış verir.
9 yazılırsa = Kurulu iken Alarm halinde eksi Çıkış verir.
MONTAJ KODUNUN DEĞİŞTİRİLMESİ : ENTER’e bas. 0000 ( dört tane sıfır ) yaz.
00 yaz. Yeni Montaj Kodunun ilk iki Rakamını yaz ( 46 gibi ).
ENTER’E bas. 01 yaz. Yeni Montaj Kodunun üç ve dördüncü
Rakamını yaz ( 21 gibi ). ENTER’e bas. 02 yaz. Yazdığın son
İki Rakamı bir daha yaz ( 21 gibi ). İki kere ENTER’e bas.
KULLANICI ŞİFRE PROGRAMI : Sadece birinci Şifre tüm konularda yetkilidir. 2. 3. ve 4. Şifreler
Sistemi kurar, Bypass ve Kısımlandırma yapabilir.
5. 6. Ve 7. Şifreler sadece Sistemi Kurar ve İptal eder.
8. Şifre sadece sistemi Kurar, İptal edemez.
1. Adam Şifresi : ENTER’e bas. 0101 yaz. 1 yaz. Yeni 4 Haneli Patron Şifre yaz. İki defa ENTER’e bas.
2 – 8. Şifreler : ENTER’e bas. Patron Şifresini yaz. 2 yaz. İkinci kişi Şifresini yaz. İki kere ENTER’e bas.
Şifre İptali : ENTER’e bas. Patron Şifresini yaz. İptal edilecek Şifrenin Numarasını yaz.
2nd Tuşuna bas. İki defa ENTER’e bas.
BAYPASS : BYP Tuşuna bas. Patron Şifresini yaz. Bypass edilecek Zon Numarasını yak. ENTER’e bas. Sisteme Şifre girerek kur. Yapılan işlem tek sefer içindir.
KISIMLANDIRMA YAPILMIŞSA KURMA İŞLEMİ : A kısmını kurmak için 11 tuşuna bas. Şifreni yaz. B kısmını kurmak için 12 tuşuna bas. Şifreni yaz.
TEK TUŞLA KURMA : 10 Numaralı Tuşa yaklaşık 2 Saniye basılı tutunuz. Sistem Otomatik olarak kurulur.
ZON UYARISI : Zonların her algılayışta Uyarı sesi vermesi istenirse; İstenilen Zon’nun Numarasına yaklaşık 2 saniye basılı tutulur. İptali için yine yaklaşık 2 saniye Aynı tuşa basılır.
SİREN BAĞLANTISI : Panel üstünde Boll + ile en baştaki COM arasına Kablo ile Köprü yapılır.
Sirene Boll + yazan Kablo ucunu Paneldeki NO ucuna bağla.
Sirendeki P Akü + ucunu Panel Aküsünün + sına,
Sirendeki P Akü – ucunu Panel Aküsünün – sine bağlanır.
Siren içersindeki Sabotaj boş kalacaktır.
Dostum eline sağlık birde DGP-848 Panelin programlamasını varsa versen dahada iyi olacak tşk.ler
arkadaşlar paradox 738 bağlantı şeması olan buraya ekleyebilirmi birde ben bu paneli programlayamadım bir türlü,birde alarmı dewreyede alamadım anlıycanız kuramadım yardımcı olurmusunuz lütfen
Başta Paradox Olmak Üzere (Bütün Modeller) ve Bir Çok Marka İçin yardımcı Olurum Pm Atabilirsiniz...
arkadaşlar elinizde kullanım klavuzu yok mu? atarsanız sevinirim.
burada yardımcı olmaya çalışan arkadaşların ellerine sağlık.
Arkadaşlar herkese iyi günler. Benim bu işin üstadlarına bazı sorularım olacak. Acil cevaplayabilirseniz sevinirim. Bende ultra 728 panel var, keypadi, pırı bağlıyorum. Paneli açıyorum sürekli bir alarm veriyor, kayped üzerindeki tüm ışıklar alarm gibi yanıp sönüyor, ama kaypad aktif hale gelmiyor. READY ışığı yanmıyor. Bundan dolayı keypadden şifre mifre girmeyi deniyorum 272727,484848 vb ama nafile. Sorunuma bir çözümmmm ... Şimdiden teşekkürler............
Paradox hırısz alarmı kaypad tan kurulum yapmak yerine pc ye baglayıp kurulum yada ayar yapabilmek için program yok mu ? yardımcı olabilirmisin ? şimdiden teşekkur ederim
merhaba ...Tabiki var
Winload programını kullanabilirsiniz...Daha başka programlar da var ...ama yaygın olan winload dır...Panelinizin modeline göre değişiklik gösterebilir..Ara birim olarakta ;( yani panel ile bilgisayar arasında )
306 usb kullanman gerekir.
Özellikler
60m mesafeden anakartla bağlantı kurabilme,
Bağlantı için PC'nizin seri veya usb portlarını kullanabilirsiniz,
Bağlantı hızları ve veri aktarım seviyesi;
Magellan MG-6060 için 57.6k band genişliği
Digiplex DGP-NE96 için 38.4k band genişliği
Digiplex DGP-848 için 19.2k band genişliği.
ilayda.ugur
Şu anda çevrimiçi üye yok.
