graski
- 28 Haz 2007
- 162
- 1
- Yaş
- 39
Arkadaşlar PLC1 imden Scada ya Haberleşme hatası geliyor.STOPA geçiyor.OLM yi değiştirdim halde CH1 sinyali hala yok.PLC1 Run yaptığımda SF ledi yanıyor Stopa GEçiyor.Diagnostic e Giremiyorum.ET200 den şüphem var ama normal çalışıyor görünüyor cihaz.Resetledikten Sonraki Eventler Şunlar:
MRES yapsam ne olur?
Event 5 of 10: Event ID 16# 3842
Module OK
Module type: Distributed I/O slave
Input address: 2045
Requested OB: Diagnostic interrupt OB (OB82)
OB not found, or disabled, or cannot be started in the current operating mode
External error, Outgoing event
10:28:09:348 am 10/05/09
Event 6 of 10: Event ID 16# 3942
Module fault present
Input address: 2045
Operating mode STOP
External error, Incoming event
10:28:09:318 am 10/05/09
Event 7 of 10: Event ID 16# 5371
Distributed I/Os: end of the synchronization with a DP master
Slot of the DP master: 2
Number of distributed stations: 1
Incoming event
10:28:09:299 am 10/05/09
Event 8 of 10: Event ID 16# 4358
All modules are ready for operation
Operating mode: STOP (internal)
Incoming event
10:28:07:151 am 10/05/09
Event 9 of 10: Event ID 16# 4357
Module monitoring time started
Incoming event
10:28:06:376 am 10/05/09
Event 10 of 10: Event ID 16# 494D
STOP caused by I/O error
No relevance for user (Z1): 0000
No relevance for user (Z2): 0050 (Z3): 4555
Previous operating mode: STOP (internal)
Requested operating mode: STOP (internal)
10:26:03:375 am 10/05/09
Module OK
Input address: 2045
Input address: 2045
Operating mode STOP
Incoming event
Incoming event
Incoming event
