Klavyeah
- Katılım
- 28 Ağu 2006
- Mesajlar
- 269
- Puanları
- 1
- Yaş
- 39
A&I
ACRONYM - Assembly and Installation
A&R
ACRONYM - Automation and Robotics
Absolute efficiency
An arbitrary filter efficiency rating.
Absolute micron rating
All (not just 98%) particles larger than the stated micron size have been removed from the fluid being filtered.
Absolute pressure
The total pressure measured from absolute zero ( i.e., from an absolute vacuum).
Absolute temperature
The temperature of a body referred to the absolute zero, at which point the volume of an ideal gas theoretically becomes zero. (Fahrenheit scale is minus 459.67°F / Celsius scale is minus 273.15°C).
Absolute viscosity ( Dynamic )
Is the force in newton required to move a fluid layer of one square meter area and a thickness of one meter with a velocity of one meter per second.
Absorb
A method to trap liquids or gases by causing them to penetrate into the absorbent material.
AC
ACRONYM - An electrical current that periodically reverses its direction. Standard in US and Canada is 60 cycles per second. Europe and other countries is 50 cycles per second. Alternating current
Acidity
The quality, state or degree of being acid. In oils, acidity denotes the presence of acid-type constituents whose concentration is usually defined in terms of neutralization number.
ACFM
ACRONYM - Actual cubic feet per minute.
ACT
ACRONYM - Activate, Activation
Activated alumina
An adsorption type desiccant.
ACTR
ACRONYM - Actuator
Actual capacity
Quantity of gas actually compressed and delivered to the discharge system at rated speed of the machine and under rated pressure conditions.
Adiabatic compression
A type of compression where no heat is transferred to or from the gas during the compression process.
Adiabatic efficiency
Ratio between measured shaft power and the adiabatic compression power, referring to measured mass flow.
Adsorb
A method causing a liquid or gas to condense on the surface only of an adsorbing material.
Adsorbent filter
a filter medium primarily intended to hold soluble and insoluble contaminants on its surface by molecular adhesion.
Adsorptive filtration
the attraction to, and retention of particles in, a filter medium by electrostatic forces, or by molecular attraction between the particles and the medium.
Aeration
To combine or charge with gas.
Aerosol
A suspension of fine solid or liquid particles in a gas.
Aftercooler
Heat exchangers for cooling air or gas discharge from compressors. Designed to reduce the temperature and liquefy condensate vapors. Both air cooled and water cooled units are available.
Aftercooling
The removal of heat from a gas after compression is completed.
Air
A colorless, odorless, tasteless gas. A mixture of individual gases. The gaseous mixture surrounding the earth. Standard density of dry air free of carbon dioxide (0°C, 101,325 kPa) is equal to 1,292 8 g/L. Standard conditions for air in spectroscopy are 101,325 kPa, 15°C, 0,03 % CO2, dry.
Air actuator
An elastomeric bellow with specially designed metal end closures used in place of pneumatic or hydraulic cylinders. A device which induces action or motion with compressed air being the medium through which the power is transmitted.
Air amplifier
A component on a compressed air line designed to increase in magnitude the flow by releasing small amounts of compressed air at high velocity through an internal, ring shaped nozzle. This column of air released through the front creates a vacuum behind, thus pulling ambient air through the rear and pushing ambient air in front.
Air borne
Supported or transported by air.
Air brush
a device for applying a fine spray by compressed air.
Air bubble technique
When compressed air is forced through a submerged perforated hose or pipe. Some applications include; ice prevention, reduction of salt intrusion, underwater basting, pneumatic breakwaters and general mixing and agitation
Air cooled compressor
A compressor cooled by atmospheric air circulated around the cylinders or casing.
Air curtain
A component on a compressed air line that provides wide are coverage with a thin sheet of air. Also amplifies compressed air flow, reduces noise. Used in blowing, cooling. Also known as air knife.
Air cylinder
A component made up of a cylinder barrel, end covers, a piston rod, a steel or stainless steel piston. A device which induces action or motion with compressed air being the medium through which the power is transmitted.
Air dryer
A device for drying compressed air by means of condensation obtained by over-compression or cooling, absorption, adsorption or a combination of the above methods.
Air flow
The motion of air relative to a body in it.
Air knife
A component on a compressed air line that provides wide are coverage with a thin sheet of air. Also amplifies compressed air flow, reduces noise. Used in blowing, cooling. Also known as air curtain.
Air leak
A crack or hole that accidentally admits a gas or lets it escape.
Air lock
device that permits passage between regions of differing air pressures, most often used for passage between atmospheric pressure and chambers in which the air is compressed. A typical modern air lock consists of a cylinder of steel plate with airtight doors located at both ends, one opening from the outside into the lock, the other from the lock into the compressed-air chamber, together with valves to admit or to exhaust compressed air. One of the doors must always be closed; before the other is opened, the pressure within the air lock must be equalized with that on the opposite side.
Air motor
Is a compact, low mass unit giving smooth, non-vibrating power. Several types include vane, piston, percussion and turbine type motors
Air nozzle
A projecting aperture at the end of a tube, pipe etc. serving as an outlet for compressed air. Reduces the demand on the compressor by generating the highest thrust and volume for the lowest possible air consumption.
Air preheater
Indirect heat exchanger designed to transfer heat from combustion gas to the air stream added to the combustion zone.
Air pressure
The total gas pressure (static plus velocity).
Air pump
A pump which is used to deliver air to the aquarium. The pump pushes air through silicon tubing and to air stones or other aquatic decor. They are also an essential for UGF's (undergravel filters). An air stone is placed in each clear tube. When the air bubbles travel upward, they generate steady current which brings water from the bottom, through the tubes and to the surface.
Air receiver
A receptacle which serves to store compressed air for heavy demands in excess of compressor capacity.
ALT
ACRONYM - Altitude
Altitude
The elevation of a compressor above sea level.
Alternating current (AC)
A&R
Absolute efficiency
Absolute pressure
Absorb
AC
Acidity
ACFM
ACT
Activated alumina
ACTR
ACRONYM - Actuator
Actual capacity
Adsorb
Adsorbent filter
Aeration
Aerosol
Aftercooler
Aftercooling
Air
Air actuator
Air amplifier
Air borne
Air brush
Air curtain
Air cylinder
Air dryer
Air flow
Air knife
Air leak
Air lock
Air motor
Air nozzle
Air preheater
Air pressure
Air pump
Air receiver
ALT
ACRONYM - Altitude
Altitude
