muratmert4
Usta Üye
Benim kullandığım kesme böyle. Kopyalayıp yapıştırarak bir kontrol edin lütfen. Kolay gelsin.
Kod:
#include <18F45k22.h>
#device *=16
#device ADC=10
#fuses NOMCLR,INTRC,PLLEN,WDT256,PROTECT
#use delay(clock=64m,internal=16m,restart_wdt)
//---------------------------PORT ADRES AYARI----------------------------------
#define SLAVE_ADRES 1
#define P_BAUD 9600
#define P_PARITY N
#define P_BIT 8
#define P_STOP 1
#define KEYHIT_DELAY 1000
#use rs232 (baud=BAUDD, xmit=pin_C6, rcv=pin_C7, parity=PARITYY, stop=STOPP,enable=pin_c5,errors,restart_wdt,bits=BITT,timeout=KEYHIT_DELAY)
//=========================UART1 HABERLESME KESMESİ============================
#int_rda
void serihaberlesme_kesmesi ()
//disable_interrupts(int_rda);
modbus.rx_buffer[modbus.read_counter]=getc(); modbus.read_counter++;
modbus.time=1;
//enable_interrupts(int_rda);
//=========================PIC MODBUS INIT=====================================
void modbus_init(void)
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1|RTCC_8_bit); //51.2 us overflow
enable_interrupts(INT_TIMER0);
setup_adc_ports(sAN0|sAN1|sAN2);
setup_adc(ADC_CLOCK_DIV_64);
set_adc_channel(0);
enable_interrupts(GLOBAL);
