nbasarici
- 7 Mar 2007
- 17
- 1
- Yaş
- 39
MicroWinCC üzerinde ekte vermiş olduğum modbus slave komutlarını yazıp kompile ettiğimde birçok hata mesajı alıyorum. Nasıl düzeltebilirim.
Hata mesajları ;
Compiling Program Block...
MAIN (OB1)
SBR_0 (SBR0)
MBUS_INIT (SBR1)
Network 2, line 6, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 2, line 8, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 2, line 9, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 2, line 9, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 3, line 3, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 9, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 9, line 3, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 12, line 5, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 29, line 2, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 29, line 3, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 29, line 4, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 29, line 5, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 29, line 7, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 29, line 8, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 32, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 37, line 3, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
MBUS_SLAVE (SBR2)
Network 1, line 1, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 2, line 1, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 3, line 1, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 3, line 2, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 4, line 8, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 5, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 6, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 16, line 4, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 18, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 19, line 4, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 19, line 6, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 28, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 28, line 3, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 28, line 5, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 28, line 6, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 31, line 8, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 31, line 12, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 33, line 1, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 34, line 3, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 37, line 3, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 39, line 1, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 39, line 5, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 39, line 9, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 42, line 4, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 45, line 1, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 45, line 8, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 48, line 4, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 49, line 4, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 51, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 51, line 7, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 57, line 2, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 57, line 3, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 59, line 3, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 59, line 4, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 59, line 5, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
MBUS1 (SBR3)
Network 1, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 1, line 3, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 1, line 13, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
INT_0 (INT0)
MBUS2 (INT1)
Network 1, line 4, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 1, line 6, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
MBUS3 (INT2)
Block Size = 0 (bytes), 58 errors
Hata mesajları ;
MAIN (OB1)
SBR_0 (SBR0)
MBUS_INIT (SBR1)
MBUS_SLAVE (SBR2)
MBUS1 (SBR3)
INT_0 (INT0)
MBUS2 (INT1)
MBUS3 (INT2)
