s7-200 hata
nbasarici
7 Mar 2007
MicroWinCC üzerinde ekte vermiş olduğum modbus slave komutlarını yazıp kompile ettiğimde birçok hata mesajı alıyorum. Nasıl düzeltebilirim.
Hata mesajları ;
Compiling Program Block...
MAIN (OB1)
SBR_0 (SBR0)
MBUS_INIT (SBR1)
Network 2, line 6, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 2, line 8, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 2, line 9, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 2, line 9, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 3, line 3, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 9, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 9, line 3, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 12, line 5, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 29, line 2, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 29, line 3, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 29, line 4, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 29, line 5, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 29, line 7, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 29, line 8, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 32, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 37, line 3, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
MBUS_SLAVE (SBR2)
Network 1, line 1, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 2, line 1, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 3, line 1, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 3, line 2, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 4, line 8, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 5, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 6, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 16, line 4, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 18, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 19, line 4, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 19, line 6, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 28, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 28, line 3, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 28, line 5, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 28, line 6, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 31, line 8, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 31, line 12, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 33, line 1, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 34, line 3, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 37, line 3, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 39, line 1, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 39, line 5, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 39, line 9, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 42, line 4, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 45, line 1, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 45, line 8, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 48, line 4, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 49, line 4, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 51, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 51, line 7, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 57, line 2, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 57, line 3, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 59, line 3, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 59, line 4, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 59, line 5, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
MBUS1 (SBR3)
Network 1, line 2, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 1, line 3, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 1, line 13, ERROR 18: (operand 1) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
INT_0 (INT0)
MBUS2 (INT1)
Network 1, line 4, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
Network 1, line 6, ERROR 18: (operand 2) V-Memory not allocated for library. Select right mouse menu item 'Library Memory...' from the Program Block in the instruction tree.
MBUS3 (INT2)
Block Size = 0 (bytes), 58 errors
    241.8 KB · Görüntüleme: 53
Compile sonrası resimde yeşil olarak görünen kısımlar compile sonucu hatalı olan kısımlar olabilir. Adres 1 demişsiniz bu port adresi ise seçtiğiniz CPU üzerinde port1 varmı ona bakmanızı varsada girmiş olduğunuz haberleşme ayarlarının birbirini tutup tutmadığını kontrol edin derim.
V hafıza alanını tahsis edemiyor. sorun bundan yana gerekirse L hafıza alanını kullan problemin kalmaz
&VB0 yerine &VL0 yazdım. Fakat yine birebir aynı hataları aldım. Ayrıca hataları MBUS_INIT (SBR1) - MBUS_SLAVE (SBR2) - MBUS1 (SBR3) - MBUS2 (INT1) ve MBUS3 (INT2) alt programlarında veriyor fakat bunlar Siemens'in kendi kilitli alt programları ve hiçbir değişiklik yapılamıyor.
Librariy'lerde bir skıntı olabilir mi? Library'ler için Klevyeah'ın linkini verdiği Tollbox V1.1'i yüklemiştim.
Herhangi bir sonuca ulaşabildiniz mi ? aynı sorun ile ben de karşılaştım. Birebir aynı hatayı alıyorum.
Mucothex
