SFC dilinde import problemi
SGoral
25 Eki 2007
SFC İLE YAZILMIŞ PROGRAM BLOĞUNU FARKLI BİR PROGRAMA IMPORT ETMEYE ÇALIŞIRKEN
3409
"No successing transition for step '<´name>' "
In the .exp file a transition is missing, which requires step <name> as preceeding
step.
3411
"Step '<name>' not reachable from initial step"
In the .exp file the connection between step <name> and the initial step is missing.
3403
"Could not import <name>"
The section for object <name> in the .exp file is not correct.
BU HATALARI ALIYORUM.NORMAL SFC BLOKLARIYLA YAZILMIŞ BİR PROGRAMI IMPORT EDİYOR.FAKAT KUTULARIN İÇERİSİNE GÖMÜLÜ OLAN PROGRAMCIKLAR OLDUĞU İÇİN HATA VERİYOR.ASLINDA ŞİFRELENMİŞ Mİ ONDANDA ŞÜPELENİYORUM.BU DURUMU AŞMAMDA YARDIMCI OLURSANIZ SEVİNİRİM.TEŞEKKÜRLER.KOLAY GELSİN
arimn
