ANADOLU
- 31 Ocak 2008
- 26
- 1
- Yaş
- 40
MALZEME KODU | MALZEME AÇIKLAMA | ADET |
6AV6381-2BH07-0AX0 | WinCC system software V7.0 SP3, RT 8192 (8192 Power Tags), Runtime, on DVD, single license, 5 languages (de,en,fr,es,it), executable in XP Prof/ Windows 7 (32/64 bit) | 1 |
6NH9910-0AA20-0AB0 | TELECONTROL SERVER BASIC 64; SINGLE LICENSE FOR 1 INSTAL- LATION; OPC SERVER FOR GPRS COMMUNICATION WITH S7-1200 AND S7-200; CONNECTION MANAGEMENT 64 REMOTE GPRS STATIONS; ROUTING BETWEEN S7 STATIONS; MULTI PROJECT-CAPABLE; WIRING DIAGNOSTICS; STATION MONITORING TELESERVICE GATEWAY FOR STEP7; IMPORT OF SINAUT MICRO SC PROJECTS; GERMAN AND ENGLISH USER INTERFACE; DOCUMENTATION ON CD IN GERMAN AND ENGLISH, | 1 |
6AV2105-0DA01-0AA0 | WINCC RUNTIME PROFESSIONAL 512 POWERTAGS V11 SP2 RUNTIME-SW, SINGLE LICENSE SW AND DOCUMENTATION ON DVD, LICENSE KEY ON USB STICK, CLASS A, 5-SPRACHIG (DE,EN,IT,FR,SP), EXECUTABLE UNDER WINDOWS XP (32 BIT) / WINDOWS 7 (32/64 BIT) | 1 |
6ES7954-8LC02-0AA0 | SIMATIC S7, memory card for S7-1x 00 CPU/SINAMICS, 3, 3 V flash, 4 MB | 9 |
6ES7195-7HA00-0XA0 | SIMATIC DP, bus module f. ET200M for holding a PS and an IM153 for the function Pulling and plugging during RUN operating mode incl. bus module cover | 1 |
6GK5008-0BA00-1AB2 | SCALANCE XB008 unmanaged Industrial Ethernet Switch for 10/100 Mbps; for setting up small star and line topologies; LED diagnostics, IP20, 24 V DC power supply, with 8x 10/100 Mbps twisted pair ports with RJ45 sockets; manual available as a download | 1 |
6NH9720-3AA00 | SINAUT MD720-3 GSM/GPRS Modem; mobile radio modem with RS232 interface; for the GSM services CSD, GPRS, SMS; Quadband GSM; AT command interface; observe national approvals! autom. GPRS connection setup; incl. gender changer for RS232/PPI adapter Manual on CD-ROM, in German and English | 2 |
6ES7332-5HF00-0AB0 | SIMATIC S7-300, Analog output SM 332, isolated, 8 AO, U/I; diagnostics; resolution 11/12 bits, 40-pole, removing and inserting possible with active backplane bus | 2 |
6ES7392-1AM00-0AA0 | SIMATIC S7-300, Front connector with screw contacts, 40-pole | 1 |
6GK5874-3AA00-2AA2 | SCALANCE M874-3 3G router; for the wireless IP communication from Ethernet-based Programmable controllers via 3G mobile radio HSPA+, VPN, Firewall, NAT; 2-port switch; 1x digital input, 1x digital output; observe national approvals! | 1 |
6ES7321-1BL00-0AA0 | SIMATIC S7-300, Digital input SM 321, Isolated 32 DI, 24 V DC, 1x 40-pole | 1 |
6ES7972-0BB52-0XB0 | SIMATIC DP, Connection plug for PROFIBUS up to 12 Mbit/s 90° cable outlet, 15.8x 59x 35.6 mm (WxHxD), Insulation displacement method FastConnect, With PG receptacle 100 units per packing unit | 1 |
6ES7241-1CH32-0XB0 | SIMATIC S7-1200, Communication module CM 1241, RS422/485, 9-pole D-sub (socket) supports Freeport | 2 |
6ES7392-1AJ00-0AA0 | SIMATIC S7-300, Front connector for signal modules with screw contacts, 20-pole | 1 |
6ES7331-7SF00-0AB0 | SIMATIC S7, analog input SM 331, isolated, 8 AI thermocouples/4 AI Pt100, for signals from the hazardous area, diagnostics-capable, PTB tested 1 x 20-pole | 1 |
